[PATCH v2 29/32] bsp/leon3: Add specialized target hash
Fri Jun 16 06:01:26 UTC 2023
 bsps/sparc/leon3/start/gettargethash.c | 71 ++++++++++++++++++++++++++
 spec/build/bsps/sparc/leon3/obj.yml    |  2 +-
 2 files changed, 72 insertions(+), 1 deletion(-)
 create mode 100644 bsps/sparc/leon3/start/gettargethash.c
diff --git a/bsps/sparc/leon3/start/gettargethash.c b/bsps/sparc/leon3/start/gettargethash.c
new file mode 100644
index 0000000000..c51031dc4f
--- /dev/null
+++ b/bsps/sparc/leon3/start/gettargethash.c
@@ -0,0 +1,71 @@
+ * @file
+ * @ingroup RTEMSBSPsSPARCLEON3
+ * @brief This source file contains the sparc/leon3 implementation of
+ *   rtems_get_target_hash().
+ * Copyright (C) 2021, 2022 embedded brains GmbH & Co. KG
+ * are met:
+#include <rtems/config.h>
+#include <rtems/counter.h>
+#include <rtems/sysinit.h>
+#include <rtems/score/hash.h>
+#include <bsp/leon3.h>
+static Hash_Control bsp_target_hash;
+static void bsp_target_hash_initialize( void )
+  Hash_Context context;
+  uint32_t     frequency;
+  _Hash_Initialize( &context );
+  frequency = rtems_counter_frequency();
+  _Hash_Add_data( &context, &frequency, sizeof( frequency ) );
+  frequency = leon3_processor_local_bus_frequency();
+  _Hash_Finalize( &context, &bsp_target_hash );
+const char *rtems_get_target_hash( void )
+  return _Hash_Get_string( &bsp_target_hash );
+RTEMS_SYSINIT_ITEM(
+  bsp_target_hash_initialize,
+  RTEMS_SYSINIT_TARGET_HASH,
+  RTEMS_SYSINIT_ORDER_SECOND
diff --git a/spec/build/bsps/sparc/leon3/obj.yml b/spec/build/bsps/sparc/leon3/obj.yml
index fed50499b4..7a4ccaa0cb 100644
--- a/spec/build/bsps/sparc/leon3/obj.yml
+++ b/spec/build/bsps/sparc/leon3/obj.yml
@@ -32,7 +32,6 @@ source:
 - bsps/shared/dev/serial/console-termios.c
 - bsps/shared/irq/irq-default-handler.c
 - bsps/shared/start/bspreset-empty.c
-- bsps/shared/start/gettargethash-default.c
 - bsps/shared/start/sbrk.c
 - bsps/sparc/leon3/btimer/btimer.c
 - bsps/sparc/leon3/btimer/watchdog.c
@@ -49,6 +48,7 @@ source:
 - bsps/sparc/leon3/start/cpucounter.c
 - bsps/sparc/leon3/start/drvmgr_def_drivers.c
 - bsps/sparc/leon3/start/eirq.c
+- bsps/sparc/leon3/start/gettargethash.c
 - bsps/sparc/leon3/start/setvec.c
 - bsps/sparc/shared/gnatcommon.c
 - bsps/sparc/shared/irq/bsp_isr_handler.c
2.35.3
