[PATCH v2 32/32] bsp/leon3: Simplify shutdown
Fri Jun 16 06:01:29 UTC 2023
Do not wait for other processors to halt.
 bsps/sparc/leon3/start/bspclean.c             | 63 +------------------
 .../bsps/fatal-sparc-leon3-shutdown.yml       |  3 +-
 2 files changed, 4 insertions(+), 62 deletions(-)
diff --git a/bsps/sparc/leon3/start/bspclean.c b/bsps/sparc/leon3/start/bspclean.c
index d52eb65ecf..0324c45326 100644
--- a/bsps/sparc/leon3/start/bspclean.c
+++ b/bsps/sparc/leon3/start/bspclean.c
@@ -38,48 +38,6 @@
 #include <rtems/score/cpuimpl.h>
 #include <rtems/score/smpimpl.h>
-#if defined(RTEMS_SMP)
-static void leon3_wait_for_power_down(irqamp *regs)
-  uint32_t max_wait;
-  uint32_t cpu_self;
-  uint32_t cpu_count;
-  uint32_t halt_mask;
-  uint32_t i;
-  cpu_count = leon3_get_cpu_count(regs);
-  if (cpu_count > rtems_configuration_get_maximum_processors()) {
-    cpu_count = rtems_configuration_get_maximum_processors();
-  cpu_self = rtems_scheduler_get_processor();
-  halt_mask = 0;
-  for (i = 0; i < cpu_count; ++i) {
-    if (i != cpu_self && _SMP_Should_start_processor(i)) {
-      halt_mask |= UINT32_C(1) << i;
-   * Wait some time for secondary processors to halt.
-   * The value was chosen to get something in the magnitude of 1ms on a 200MHz
-   * processor.
-  max_wait = 1234567;
-  i = 0;
-  while (
-    (grlib_load_32(&regs->mpstat) & halt_mask) != halt_mask && i < max_wait
-    ++i;
-#endif
 void bsp_fatal_extension(
   rtems_fatal_source source,
   bool always_set_to_false,
@@ -92,29 +50,12 @@ void bsp_fatal_extension(
   (void) level;
-   * On SMP we must wait for all other CPUs not requesting a fatal halt, they
-   * are responding to another CPU's fatal request. These CPUs goes into
-   * power-down. The CPU requesting fatal halt waits for the others and then
-   * handles the system shutdown via the normal procedure.
   if ((source == RTEMS_FATAL_SOURCE_SMP) &&
       (code == SMP_FATAL_SHUTDOWN_RESPONSE)) {
     leon3_power_down_loop(); /* CPU didn't start shutdown sequence .. */
-  } else {
-    irqamp *regs;
-    _SMP_Request_shutdown();
-    regs = LEON3_IrqCtrl_Regs;
-#if defined(LEON3_IRQAMP_BASE)
-    leon3_wait_for_power_down(regs);
-#else
-    if (regs != NULL) {
-#endif
+  _SMP_Request_shutdown();
 #endif
 #if BSP_PRINT_EXCEPTION_CONTEXT
diff --git a/spec/build/testsuites/validation/bsps/fatal-sparc-leon3-shutdown.yml b/spec/build/testsuites/validation/bsps/fatal-sparc-leon3-shutdown.yml
index c12f447e84..e1a0f32900 100644
--- a/spec/build/testsuites/validation/bsps/fatal-sparc-leon3-shutdown.yml
+++ b/spec/build/testsuites/validation/bsps/fatal-sparc-leon3-shutdown.yml
@@ -11,7 +11,8 @@ enabled-by:
   - bsps/sparc/leon3
 features: c cprogram
 includes: []
-ldflags: []
+ldflags:
+- -Wl,--wrap=_CPU_Fatal_halt
 links: []
 source:
 - testsuites/validation/bsps/tc-fatal-sparc-leon3-shutdown.c
2.35.3
