[PATCH v2 20/32] bsp/leon3: Add LEON3_L2CACHE_BASE
Sebastian Huber
Fri Jun 16 06:01:17 UTC 2023
bsps/sparc/leon3/start/cache.c | 36 ++++++++++++++-----
spec/build/bsps/sparc/leon3/grp.yml | 2 ++
.../build/bsps/sparc/leon3/optl2cachebase.yml | 19 ++++++++++
3 files changed, 49 insertions(+), 8 deletions(-)
create mode 100644 spec/build/bsps/sparc/leon3/optl2cachebase.yml
diff --git a/bsps/sparc/leon3/start/cache.c b/bsps/sparc/leon3/start/cache.c
index ed6fb5733d..5049b7f81c 100644
--- a/bsps/sparc/leon3/start/cache.c
+++ b/bsps/sparc/leon3/start/cache.c
@@ -11,7 +11,13 @@
#include <bsp/leon3.h>
+#if !defined(LEON3_L2CACHE_BASE)
#include <grlib/ambapp.h>
+#endif
+#if !defined(LEON3_L2CACHE_BASE) || LEON3_L2CACHE_BASE != 0
+#define LEON3_MAYBE_HAS_L2CACHE
+#endif
#define CPU_CACHE_SUPPORT_PROVIDES_RANGE_FUNCTIONS
@@ -23,6 +29,7 @@
#define CPU_DATA_CACHE_ALIGNMENT 64
static inline l2cache *get_l2c_regs(void)
struct ambapp_dev *adev;
@@ -42,7 +49,17 @@ static inline l2cache *get_l2c_regs(void)
return (l2cache *) DEV_TO_AHB(adev)->start[1];
+#endif
+static inline size_t get_l1_size(uint32_t l1_cfg)
+ uint32_t ways = ((l1_cfg >> 24) & 0x7) + 1;
+ uint32_t wsize = UINT32_C(1) << (((l1_cfg >> 20) & 0xf) + 10);
+ return ways * wsize;
+#if defined(LEON3_MAYBE_HAS_L2CACHE)
static inline size_t get_l2_size(void)
l2cache *regs;
@@ -50,11 +67,15 @@ static inline size_t get_l2_size(void)
unsigned ways;
unsigned set_size;
+#if defined(LEON3_L2CACHE_BASE)
+ regs = (l2cache *) LEON3_L2CACHE_BASE;
+#else
regs = get_l2c_regs();
if (regs == NULL) {
return 0;
+#endif
status = grlib_load_32(®s->l2cs);
ways = L2CACHE_L2CS_WAY_GET(status) + 1;
@@ -63,18 +84,11 @@ static inline size_t get_l2_size(void)
return ways * set_size;
-static inline size_t get_l1_size(uint32_t l1_cfg)
- uint32_t ways = ((l1_cfg >> 24) & 0x7) + 1;
- uint32_t wsize = UINT32_C(1) << (((l1_cfg >> 20) & 0xf) + 10);
- return ways * wsize;
static inline size_t get_max_size(size_t a, size_t b)
return a < b ? b : a;
+#endif
static inline size_t get_cache_size(uint32_t level, uint32_t l1_cfg)
@@ -82,14 +96,20 @@ static inline size_t get_cache_size(uint32_t level, uint32_t l1_cfg)
switch (level) {
case 0:
size = get_max_size(get_l1_size(l1_cfg), get_l2_size());
+#else
+ size = get_l1_size(l1_cfg);
+#endif
break;
case 1:
break;
case 2:
size = get_l2_size();
break;
+#endif
default:
size = 0;
break;
diff --git a/spec/build/bsps/sparc/leon3/grp.yml b/spec/build/bsps/sparc/leon3/grp.yml
index d044a6ca60..6d7a1b75c3 100644
--- a/spec/build/bsps/sparc/leon3/grp.yml
+++ b/spec/build/bsps/sparc/leon3/grp.yml
@@ -44,6 +44,8 @@ links:
uid: optirqampts
- role: build-dependency
uid: optconirq
+- role: build-dependency
+ uid: optl2cachebase
uid: optleon3smp
diff --git a/spec/build/bsps/sparc/leon3/optl2cachebase.yml b/spec/build/bsps/sparc/leon3/optl2cachebase.yml
new file mode 100644
index 0000000000..759198f827
--- /dev/null
+++ b/spec/build/bsps/sparc/leon3/optl2cachebase.yml
@@ -0,0 +1,19 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+copyrights:
+- Copyright (C) 2021 embedded brains GmbH & Co. KG
+actions:
+- get-integer: null
+- format-and-define: null
+build-type: option
+default:
+- enabled-by: sparc/gr712rc
+ value: 0x00000000
+- enabled-by: sparc/gr740
+ value: 0xf0000000
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: LEON3_L2CACHE_BASE
+description: |
+ This option defines the base address of the L2CACHE register block.
+type: build
2.35.3
