[PATCH v2 09/32] bsp/leon3: Move and simplify bsp_irq_fixup()
Fri Jun 16 06:01:06 UTC 2023
 bsps/sparc/erc32/include/bsp/irqimpl.h   | 63 ++++++++++++++++++++++++
 bsps/sparc/erc32/include/erc32.h         |  5 --
 bsps/sparc/leon2/include/bsp/irqimpl.h   | 63 ++++++++++++++++++++++++
 bsps/sparc/leon2/include/leon.h          |  5 --
 bsps/sparc/leon3/clock/ckinit.c          |  4 +-
 bsps/sparc/leon3/include/bsp/irq.h       |  1 -
 bsps/sparc/leon3/include/bsp/irqimpl.h   | 31 ++++++++++++
 bsps/sparc/leon3/include/leon.h          | 18 -------
 bsps/sparc/leon3/start/eirq.c            |  8 +--
 bsps/sparc/shared/irq/bsp_isr_handler.c  |  1 +
 spec/build/bsps/sparc/erc32/bsperc32.yml |  1 +
 spec/build/bsps/sparc/leon2/obj.yml      |  1 +
 12 files changed, 164 insertions(+), 37 deletions(-)
 create mode 100644 bsps/sparc/erc32/include/bsp/irqimpl.h
 create mode 100644 bsps/sparc/leon2/include/bsp/irqimpl.h
diff --git a/bsps/sparc/erc32/include/bsp/irqimpl.h b/bsps/sparc/erc32/include/bsp/irqimpl.h
new file mode 100644
index 0000000000..6a8b17f188
--- /dev/null
+++ b/bsps/sparc/erc32/include/bsp/irqimpl.h
@@ -0,0 +1,63 @@
+ * @file
+ * @ingroup RTEMSBSPsSPARCERC32
+ * @brief This header file provides interfaces used by the interrupt support
+ *   implementation.
+ * Copyright (C) 2023 embedded brains GmbH & Co. KG
+ * are met:
+#ifndef LIBBSP_SPARC_ERC32_BSP_IRQIMPL_H
+#define LIBBSP_SPARC_ERC32_BSP_IRQIMPL_H
+#include <stdint.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @addtogroup RTEMSBSPsSPARCERC32
+static inline uint32_t bsp_irq_fixup( uint32_t irq )
+  return irq;
+#ifdef __cplusplus
+#endif
+#endif /* LIBBSP_SPARC_ERC32_BSP_IRQIMPL_H */
diff --git a/bsps/sparc/erc32/include/erc32.h b/bsps/sparc/erc32/include/erc32.h
index f9cdbc960a..3967f4c918 100644
--- a/bsps/sparc/erc32/include/erc32.h
+++ b/bsps/sparc/erc32/include/erc32.h
@@ -326,11 +326,6 @@ typedef struct {
 extern ERC32_Register_Map ERC32_MEC;
-static __inline__ int bsp_irq_fixup(int irq)
-       return irq;
  *  Macros to manipulate the Interrupt Clear, Interrupt Force, Interrupt Mask,
  *  and the Interrupt Pending Registers.
diff --git a/bsps/sparc/leon2/include/bsp/irqimpl.h b/bsps/sparc/leon2/include/bsp/irqimpl.h
index 0000000000..868822f3aa
--- /dev/null
+++ b/bsps/sparc/leon2/include/bsp/irqimpl.h
@@ -0,0 +1,63 @@
+ * @file
+ * @ingroup RTEMSBSPsSPARCLEON2
+ *   implementation.
+ * are met:
+#ifndef LIBBSP_SPARC_LEON3_BSP_IRQIMPL_H
+#define LIBBSP_SPARC_LEON3_BSP_IRQIMPL_H
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @addtogroup RTEMSBSPsSPARCLEON2
+  return irq;
+#ifdef __cplusplus
+#endif
+#endif /* LIBBSP_SPARC_LEON3_BSP_IRQIMPL_H */
diff --git a/bsps/sparc/leon2/include/leon.h b/bsps/sparc/leon2/include/leon.h
index 762260ba48..8f2d807eb4 100644
--- a/bsps/sparc/leon2/include/leon.h
+++ b/bsps/sparc/leon2/include/leon.h
@@ -292,11 +292,6 @@ typedef struct {
 extern LEON_Register_Map LEON_REG;
-       return irq;
diff --git a/bsps/sparc/leon3/clock/ckinit.c b/bsps/sparc/leon3/clock/ckinit.c
index b66ac793fc..2ec701fe2a 100644
--- a/bsps/sparc/leon3/clock/ckinit.c
+++ b/bsps/sparc/leon3/clock/ckinit.c
@@ -40,9 +40,9 @@
 #include <bsp.h>
-#include <bsp/irq.h>
-#include <bspopts.h>
 #include <bsp/fatal.h>
+#include <bsp/irq.h>
+#include <leon.h>
 #include <rtems/rtems/intr.h>
 #include <grlib/ambapp.h>
 #include <rtems/score/profiling.h>
diff --git a/bsps/sparc/leon3/include/bsp/irq.h b/bsps/sparc/leon3/include/bsp/irq.h
index a7054030e2..ef0f6245f9 100644
--- a/bsps/sparc/leon3/include/bsp/irq.h
+++ b/bsps/sparc/leon3/include/bsp/irq.h
@@ -37,7 +37,6 @@
 #ifndef LIBBSP_LEON3_IRQ_CONFIG_H
 #define LIBBSP_LEON3_IRQ_CONFIG_H
-#include <leon.h>
 #include <rtems/score/processormask.h>
 #define BSP_INTERRUPT_VECTOR_MAX_STD 15 /* Standard IRQ controller */
diff --git a/bsps/sparc/leon3/include/bsp/irqimpl.h b/bsps/sparc/leon3/include/bsp/irqimpl.h
index 77619c99b9..60b198bd02 100644
--- a/bsps/sparc/leon3/include/bsp/irqimpl.h
+++ b/bsps/sparc/leon3/include/bsp/irqimpl.h
@@ -67,6 +67,14 @@ extern volatile struct irqmp_regs *LEON3_IrqCtrl_Regs;
 extern struct ambapp_dev *LEON3_IrqCtrl_Adev;
+ * @brief This object provides the interrupt number used to multiplex extended
+ *   interrupts or is zero if no extended interrupts are available.
+ * This object should be read-only after initialization.
+extern uint32_t LEON3_IrqCtrl_EIrq;
  * @brief Initializes the interrupt controller for the boot processor.
@@ -74,6 +82,29 @@ extern struct ambapp_dev *LEON3_IrqCtrl_Adev;
 void leon3_ext_irq_init( volatile struct irqmp_regs *regs );
+ * @brief Acknowledges and maps extended interrupts if this feature is
+ * available and the interrupt for extended interrupts is present.
+ * @param irq is the standard interrupt number.
+  uint32_t eirq;
+  if ( irq != LEON3_IrqCtrl_EIrq ) {
+    return irq;
+  eirq = LEON3_IrqCtrl_Regs->intid[ _LEON3_Get_current_processor() ] & 0x1f;
+  if ( eirq < 16 ) {
+    return irq;
+  return eirq;
 #ifdef __cplusplus
diff --git a/bsps/sparc/leon3/include/leon.h b/bsps/sparc/leon3/include/leon.h
index 0382e1b7e3..8a64285b3f 100644
--- a/bsps/sparc/leon3/include/leon.h
+++ b/bsps/sparc/leon3/include/leon.h
@@ -154,24 +154,6 @@ extern struct ambapp_dev *LEON3_Timer_Adev;
 /* LEON3 CPU Index of boot CPU */
 extern uint32_t LEON3_Cpu_Index;
-/* The external IRQ number, -1 if not external interrupts */
-extern int LEON3_IrqCtrl_EIrq;
-  int eirq, cpu;
-  if (LEON3_IrqCtrl_EIrq != 0 && irq == LEON3_IrqCtrl_EIrq) {
-    /* Get interrupt number from IRQ controller */
-    cpu = _LEON3_Get_current_processor();
-    eirq = LEON3_IrqCtrl_Regs->intid[cpu] & 0x1f;
-    if (eirq & 0x10)
-      irq = eirq;
-  return irq;
 /* Macros used for manipulating bits in LEON3 GP Timer Control Register */
 #define LEON3_IRQMPSTATUS_CPUNR     28
diff --git a/bsps/sparc/leon3/start/eirq.c b/bsps/sparc/leon3/start/eirq.c
index 0371cfe98f..d9c5402dd0 100644
--- a/bsps/sparc/leon3/start/eirq.c
+++ b/bsps/sparc/leon3/start/eirq.c
@@ -36,7 +36,7 @@
 #include <bsp/irq-generic.h>
 /* GRLIB extended IRQ controller IRQ number */
-int LEON3_IrqCtrl_EIrq = -1;
+uint32_t LEON3_IrqCtrl_EIrq;
 rtems_interrupt_lock LEON3_IrqCtrl_Lock =
   RTEMS_INTERRUPT_LOCK_INITIALIZER("LEON3 IrqCtrl");
@@ -47,11 +47,7 @@ void leon3_ext_irq_init(volatile struct irqmp_regs *regs)
   regs->mask[LEON3_Cpu_Index] = 0;
   regs->force[LEON3_Cpu_Index] = 0;
   regs->iclear = 0xffffffff;
-  if ( (regs->mpstat >> 16) & 0xf ) {
-    /* Extended IRQ controller available */
-    LEON3_IrqCtrl_EIrq = (regs->mpstat >> 16) & 0xf;
+  LEON3_IrqCtrl_EIrq = (regs->mpstat >> 16) & 0xf;
 bool bsp_interrupt_is_valid_vector(rtems_vector_number vector)
diff --git a/bsps/sparc/shared/irq/bsp_isr_handler.c b/bsps/sparc/shared/irq/bsp_isr_handler.c
index cf2800cd85..54e82b15a4 100644
--- a/bsps/sparc/shared/irq/bsp_isr_handler.c
+++ b/bsps/sparc/shared/irq/bsp_isr_handler.c
@@ -29,6 +29,7 @@
 #include <bsp.h>
+#include <bsp/irqimpl.h>
  * This function is called directly from _SPARC_Interrupt_trap() for
diff --git a/spec/build/bsps/sparc/erc32/bsperc32.yml b/spec/build/bsps/sparc/erc32/bsperc32.yml
index d082feb5f7..4ca351cd61 100644
--- a/spec/build/bsps/sparc/erc32/bsperc32.yml
+++ b/spec/build/bsps/sparc/erc32/bsperc32.yml
@@ -17,6 +17,7 @@ install:
 - destination: ${BSP_INCLUDEDIR}/bsp
   source:
   - bsps/sparc/erc32/include/bsp/irq.h
+  - bsps/sparc/erc32/include/bsp/irqimpl.h
 - destination: ${BSP_LIBDIR}
   source:
   - bsps/sparc/erc32/start/linkcmds
diff --git a/spec/build/bsps/sparc/leon2/obj.yml b/spec/build/bsps/sparc/leon2/obj.yml
index 50ee715af2..87e5cd90c9 100644
--- a/spec/build/bsps/sparc/leon2/obj.yml
+++ b/spec/build/bsps/sparc/leon2/obj.yml
@@ -16,6 +16,7 @@ install:
   source:
   - bsps/sparc/leon2/include/bsp/at697_pci.h
   - bsps/sparc/leon2/include/bsp/irq.h
+  - bsps/sparc/leon2/include/bsp/irqimpl.h
   source:
   - bsps/sparc/leon2/start/linkcmds.at697f
2.35.3
