[PATCH rtems-tools] rtemstoolkit: add support for executing pipe command
Muhammad Sulthan Mazaya
msulthanmazaya at gmail.com
Tue Jun 20 02:31:54 UTC 2023
Sorry, sent the wrong patch, it should be the v2. Ignore this one.
On Tue, Jun 20, 2023 at 12:30 PM Muhammad Sulthan Mazaya <
msulthanmazaya at gmail.com> wrote:
> The previous implementation of execute command on rtems-tools config does
> not support command line pipe operation. So something like:
> %execute %{command} | %{trim_command}
> Would not work, since the "| %{trim_command}" part is treated as an
> additional command option. This patch is intended to fix that issue.
> rtemstoolkit/execute.py | 28 +++++++++++++++++++++++-----
> 1 file changed, 23 insertions(+), 5 deletions(-)
> diff --git a/rtemstoolkit/execute.py b/rtemstoolkit/execute.py
> index ed81589..9bb7434 100755
> --- a/rtemstoolkit/execute.py
> +++ b/rtemstoolkit/execute.py
> @@ -389,11 +389,29 @@ class execute(object):
> r, e = os.path.splitext(command[0])
> if e not in ['.exe', '.com', '.bat']:
> command[0] = command[0] + '.exe'
> - proc = subprocess.Popen(command, shell = shell,
> - cwd = cwd, env = env,
> - stdin = stdin, stdout = stdout,
> - stderr = stderr,
> - close_fds = False)
> + pipe_commands = []
> + current_command = []
> + for cmd in command:
> + if cmd == '|':
> + pipe_commands.append(current_command)
> + else:
> + current_command.append(cmd)
> + proc = None
> + for i, cmd in enumerate(pipe_commands):
> + if i == 0:
> + proc = subprocess.Popen(
> + cmd, shell=shell, cwd=cwd, env=env, stdin=stdin,
> stdout=subprocess.PIPE)
> + elif i == len(pipe_commands) - 1:
> stdin=proc.stdout, stdout=stdout, stderr=stderr, close_fds=False)
> + else:
> stdin=proc.stdout, stdout=subprocess.PIPE)
> if not capture:
> return (0, proc)
> if self.output is None:
> 2.34.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230620/7f9930d0/attachment-0001.htm>
