[rtems-tools commit] rtemstoolkit: add support for executing pipe command
Joel Sherrill
joel at rtems.org
Wed Jun 21 13:42:00 UTC 2023
Now that this is pushed, the hash for rtems-tools in the RSB needs to be
bumped to pick these changes up.
--joel
On Tue, Jun 20, 2023 at 6:04 PM Chris Johns <chrisj at rtems.org> wrote:
> Module: rtems-tools
> Branch: master
> Commit: 38162e17d998770cd4696bcd4f01c98b5d8c53a0
> Changeset:
> http://git.rtems.org/rtems-tools/commit/?id=38162e17d998770cd4696bcd4f01c98b5d8c53a0
> Author: Muhammad Sulthan Mazaya <msulthanmazaya at gmail.com>
> Date: Tue Jun 20 12:32:06 2023 +1000
> added unit tests and shorten long lines.
> rtemstoolkit/execute.py | 43 ++++++++++++++++++++++++++++++++++++++-----
> 1 file changed, 38 insertions(+), 5 deletions(-)
> diff --git a/rtemstoolkit/execute.py b/rtemstoolkit/execute.py
> index ed81589..9ec1cd7 100755
> --- a/rtemstoolkit/execute.py
> +++ b/rtemstoolkit/execute.py
> @@ -389,11 +389,38 @@ class execute(object):
> r, e = os.path.splitext(command[0])
> if e not in ['.exe', '.com', '.bat']:
> command[0] = command[0] + '.exe'
> - proc = subprocess.Popen(command, shell = shell,
> - cwd = cwd, env = env,
> - stdin = stdin, stdout = stdout,
> - stderr = stderr,
> - close_fds = False)
> + pipe_commands = []
> + current_command = []
> + for cmd in command:
> + if cmd == '|':
> + pipe_commands.append(current_command)
> + else:
> + current_command.append(cmd)
> + proc = None
> + for i, cmd in enumerate(pipe_commands):
> + if i == 0:
> + proc = subprocess.Popen(
> + cmd, shell=shell,
> + cwd=cwd, env=env,
> + stdin=stdin, stdout=subprocess.PIPE)
> + elif i == len(pipe_commands) - 1:
> + cmd, shell=shell,
> + cwd=cwd, env=env,
> + stdin=proc.stdout,
> + stdout=stdout, stderr=stderr,
> + close_fds=False)
> + else:
> + cmd, shell=shell,
> + cwd=cwd, env=env,
> + stdout=subprocess.PIPE)
> if not capture:
> return (0, proc)
> if self.output is None:
> @@ -583,6 +610,10 @@ if __name__ == "__main__":
> proc.stdin.close()
> e.capture(proc)
> del proc
> + ec, proc = e.open(commands['open'])
> + if ec == 0:
> + e.capture(proc)
> + del proc
> def capture_output(text):
> print(text, end = '')
> @@ -601,6 +632,7 @@ if __name__ == "__main__":
> commands['windows']['csubsts'] = [('netstat %0', ['-a']),
> ('netstat %0 %1', ['-a', '-n'])]
> commands['windows']['pipe'] = ('ftp', None, 'help\nquit')
> + commands['windows']['open'] = ["echo", "hello rtems", "|",
> "findstr", "rtems"]
> commands['unix']['shell'] = ['pwd', 'ls -las', './xyz', sh_shell_test]
> commands['unix']['spawn'] = ['ls', 'execute.pyc', ['ls', '-i']]
> commands['unix']['cmd'] = [('date'), ('date', '-R'), ('date', ['-u',
> '+%d %D']),
> @@ -608,6 +640,7 @@ if __name__ == "__main__":
> commands['unix']['csubsts'] = [('date %0 "+%d %D %S"', ['-u']),
> ('date %0 %1', ['-u', '+%d %D %S'])]
> commands['unix']['pipe'] = ('grep', 'hello', 'hello world')
> + commands['unix']['open'] = ["echo", "hello world", "|", "cut", "-d ",
> "-f2"]
> print(arg_list('cmd a1 a2 "a3 is a string" a4'))
> print(arg_list('cmd b1 b2 "b3 is a string a4'))
> vc mailing list
> vc at rtems.org
> http://lists.rtems.org/mailman/listinfo/vc
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230621/9d657b6a/attachment.htm>
