[PATCH] bsps/xqspipsu: Handle SMP systems properly
Chris Johns
chrisj at rtems.org
Wed Jun 21 23:55:40 UTC 2023
OK
On 22/6/2023 2:09 am, Kinsey Moore wrote:
> The NOR driver was not written with SMP systems and caching in mind.
> This makes the IsBusy flag volatile for updates across cores and
> introduces cache flushing and invalidation where necessary for data
> manipulated by the DMA engine in the QSPI peripheral.
> bsps/include/dev/spi/xqspipsu.h | 3 +++
> bsps/shared/dev/spi/xqspipsu-flash-helper.c | 3 +++
> bsps/shared/dev/spi/xqspipsu.c | 23 +++++++++++++++++++++
> 3 files changed, 29 insertions(+)
> diff --git a/bsps/include/dev/spi/xqspipsu.h b/bsps/include/dev/spi/xqspipsu.h
> index 7d9b662464..92d38eb0c8 100644
> --- a/bsps/include/dev/spi/xqspipsu.h
> +++ b/bsps/include/dev/spi/xqspipsu.h
> @@ -259,6 +259,9 @@ typedef struct {
> s32 TxBytes; /**< Number of bytes to transfer (state) */
> s32 RxBytes; /**< Number of bytes left to transfer(state) */
> s32 GenFifoEntries; /**< Number of Gen FIFO entries remaining */
> +#ifdef __rtems__
> + volatile
> +#endif
> u32 IsBusy; /**< A transfer is in progress (state) */
> u32 ReadMode; /**< DMA or IO mode */
> u32 GenFifoCS; /**< Gen FIFO chip selection */
> diff --git a/bsps/shared/dev/spi/xqspipsu-flash-helper.c b/bsps/shared/dev/spi/xqspipsu-flash-helper.c
> index 4e018bf2fa..c9d8273b87 100644
> --- a/bsps/shared/dev/spi/xqspipsu-flash-helper.c
> +++ b/bsps/shared/dev/spi/xqspipsu-flash-helper.c
> @@ -314,6 +314,7 @@ static int FlashReadID(XQspiPsu *QspiPsuPtr)
> while (TransferInProgress);
> + rtems_cache_invalidate_multiple_data_lines(ReadBfrPtr, 3);
> /* In case of dual, read both and ensure they are same make/size */
> @@ -860,6 +861,7 @@ int QspiPsu_NOR_Read(
> + rtems_cache_invalidate_multiple_data_lines(ReadBuffer, ByteCount);
> return 0;
> @@ -1047,6 +1049,7 @@ static int MultiDieRead(
> Address += data_len;
> remain_len -= data_len;
> + rtems_cache_invalidate_multiple_data_lines(ReadBfrPtr, ByteCount);
> return 0;
> diff --git a/bsps/shared/dev/spi/xqspipsu.c b/bsps/shared/dev/spi/xqspipsu.c
> index 1286efd359..c77407bdf4 100644
> --- a/bsps/shared/dev/spi/xqspipsu.c
> +++ b/bsps/shared/dev/spi/xqspipsu.c
> @@ -84,6 +84,9 @@
> #include "xqspipsu.h"
> #include "xqspipsu_control.h"
> #include "sleep.h"
> +#ifdef __rtems__
> +#include <rtems/rtems/cache.h>
> +#endif
> /************************** Constant Definitions *****************************/
> #define MAX_DELAY_CNT 10000000U /**< Max delay count */
> @@ -442,7 +445,16 @@ s32 XQspiPsu_PolledTransfer(XQspiPsu *InstancePtr, XQspiPsu_Msg *Msg,
> for (Index = 0; Index < (s32)NumMsg; Index++) {
> Xil_AssertNonvoid(Msg[Index].ByteCount > 0U);
> +#ifdef __rtems__
> + if (Msg[Index].TxBfrPtr != NULL) {
> + rtems_cache_flush_multiple_data_lines(Msg[Index].TxBfrPtr, Msg[Index].ByteCount);
> +#endif
> +#ifdef __rtems__
> + rtems_cache_flush_multiple_data_lines(Msg, NumMsg * sizeof(*Msg));
> +#endif
> * Check whether there is another transfer in progress.
> * Not thread-safe
> @@ -582,7 +594,18 @@ s32 XQspiPsu_InterruptTransfer(XQspiPsu *InstancePtr, XQspiPsu_Msg *Msg,
> Xil_AssertNonvoid(InstancePtr->IsReady == XIL_COMPONENT_IS_READY);
> +#ifdef __rtems__
> +#endif
> +#ifdef __rtems__
> +#endif
> * Not thread-safe
