[PATCH rtems-tools] tester/rtems: add renode implementation
Muhammad Sulthan Mazaya
msulthanmazaya at gmail.com
Mon Jun 26 04:17:42 UTC 2023
Patch for the implementation of renode on rtems-test. Currently, renode
installation has not been implemented in rsb. Thus, for testing, you can
install renode by referring to the documentation link below.
Downloads for debian, fedora, arch, macOS, and windows:
https://renode.io/#downloads
Alternatively, you can access Renode's GitHub releases:
https://github.com/renode/renode/releases/tag/v1.13.3
You can also build it from source:
https://renode.readthedocs.io/en/latest/advanced/building_from_sources.html#building-from-source
This patch consists of changes to test kendrytek210 using renode. To
test it, you can build the kendrytek210 test suite as instructed in the
rtems-docs (Alan's patch here: https://lists.rtems.org/pipermail/devel/2023-April/074838.html).
Then, use the following command to run the test suite.
rtems-test --rtems-bsp=kendrytek210-renode [test-suite-path]
.../testing/bsps/kendrytek210-renode.ini | 38 +++++++++++
tester/rtems/testing/renode.cfg | 64 +++++++++++++++++++
.../testing/renode_scripts/kendrytek210.resc | 53 +++++++++++++++
3 files changed, 155 insertions(+)
create mode 100644 tester/rtems/testing/bsps/kendrytek210-renode.ini
create mode 100644 tester/rtems/testing/renode.cfg
create mode 100644 tester/rtems/testing/renode_scripts/kendrytek210.resc
diff --git a/tester/rtems/testing/bsps/kendrytek210-renode.ini b/tester/rtems/testing/bsps/kendrytek210-renode.ini
new file mode 100644
index 0000000..95850c5
--- /dev/null
+++ b/tester/rtems/testing/bsps/kendrytek210-renode.ini
@@ -0,0 +1,38 @@
+# RTEMS Tools Project (http://www.rtems.org/)
+# Copyright 2010-2014 Chris Johns (chrisj at rtems.org)
+# All rights reserved.
+# This file is part of the RTEMS Tools package in 'rtems-tools'.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions are met:
+# 1. Redistributions of source code must retain the above copyright notice,
+# this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright notice,
+# this list of conditions and the following disclaimer in the documentation
+# and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
+# The Kendrytek210 Renode BSP
+[kendrytek210-renode]
+bsp = kendrytek210-renode
+arch = riscv
+tester = %{_rtscripts}/renode.cfg
+bsp_resc_script = %{_rtscripts}/renode_scripts/kendrytek210.resc
diff --git a/tester/rtems/testing/renode.cfg b/tester/rtems/testing/renode.cfg
index 0000000..49e84a5
--- /dev/null
+++ b/tester/rtems/testing/renode.cfg
@@ -0,0 +1,64 @@
+# Renode
+# Use a renode command to run the executable in the renode simulator.
+%include %{_configdir}/base.cfg
+%include %{_configdir}/checks.cfg
+# Console.
+%define console_telnet
+%include %{_configdir}/console.cfg
+# RTEMS version
+%include %{_rtdir}/rtems/version.cfg
+# Renode executable
+%define renode_cmd renode --hide-monitor
+%define binary_opts -e $bin?=@%{test_executable}
+%define start_opts -e "s @%{bsp_resc_script}"
+%define trim_command sed 's/.*\[output\] //'
+# Executable
+%execute %{renode_cmd} %{binary_opts} %{start_opts} | %{trim_command}
diff --git a/tester/rtems/testing/renode_scripts/kendrytek210.resc b/tester/rtems/testing/renode_scripts/kendrytek210.resc
index 0000000..fe13aa8
--- /dev/null
+++ b/tester/rtems/testing/renode_scripts/kendrytek210.resc
@@ -0,0 +1,53 @@
+using sysbus
+using monitor
+mach create "K210"
+machine LoadPlatformDescription @platforms/cpus/kendryte_k210.repl
+path add @/
+showAnalyzer "uartAnalyzer" uart Antmicro.Renode.Analyzers.LoggingUartAnalyzer
+uartAnalyzer TimestampFormat None
+set report_repeating_line """
+from Antmicro.Renode.Logging import ConsoleBackend
+ConsoleBackend.Instance.ReportRepeatingLines = True
+set add_hook """
+def match(line):
+ ok_to_kill_lines = [
+ '*** TEST STATE: USER_INPUT',
+ '*** TEST STATE: BENCHMARK',
+ '*** END OF TEST ',
+ '*** FATAL ***'
+ return any(l in line for l in ok_to_kill_lines)
+def hook(line):
+ monitor.Parse("q")
+Antmicro.Renode.Hooks.UartHooksExtensions.AddLineHook(monitor.Machine["sysbus.uart"], match, hook)
+python $add_hook
+python $report_repeating_line
+sysbus Tag <0x50440000 0x10000> "SYSCTL"
+sysbus Tag <0x50440018 0x4> "pll_lock" 0xFFFFFFFF
+sysbus Tag <0x5044000C 0x4> "pll1"
+sysbus Tag <0x50440008 0x4> "pll0"
+sysbus Tag <0x50440020 0x4> "clk_sel0"
+sysbus Tag <0x50440028 0x4> "clk_en_cent"
+sysbus Tag <0x5044002c 0x4> "clk_en_peri"
+# enable uart tx
+uart WriteDoubleWord 0x8 0x1
+macro reset
+ sysbus LoadELF $bin
+runMacro $reset
2.34.1
