[PATCH rtems-source-builder] qemu-5-1: Update to the latest CGEM patch
Chris Johns
chrisj at rtems.org
Mon Jun 26 21:47:48 UTC 2023
On 27/6/2023 5:02 am, Kinsey Moore wrote:
> The original version of this patch had a conflict between the two
> interrupts where the program-viewable interrupt state could be
> deasserted when it should have been asserted. The new version of this
> patch resolves that conflict.
> source-builder/config/qemu-5-1.cfg | 4 ++--
> 1 file changed, 2 insertions(+), 2 deletions(-)
> diff --git a/source-builder/config/qemu-5-1.cfg b/source-builder/config/qemu-5-1.cfg
> index 4b2951d..409ed89 100644
> --- a/source-builder/config/qemu-5-1.cfg
> +++ b/source-builder/config/qemu-5-1.cfg
> @@ -8,6 +8,6 @@
> %include %{_configdir}/qemu-common-2.cfg
> -%patch add qemu --rsb-file=cgem_zynqmp_versal.patch -p1 https://devel.rtems.org/raw-attachment/ticket/4919/cgem_zynqmp_versal.patch
> +%patch add qemu --rsb-file=cgem_zynqmp_versal.patch -p1 https://devel.rtems.org/raw-attachment/ticket/4919/0001-hw-arm-xlnx-Connect-secondary-CGEM-IRQs.patch
> %hash sha512 cgem_zynqmp_versal.patch \
> - 2a4a894acefd00a76f48b6d6339696c8c53ece8e044687cb86c268840eac226d251fe89af933db4c20f5f07a3faff92c7c28c4c82b0617e4b200fd0895ac6158
> + 5c80060f6f506b8b9a10a8a3dd3621d4725425beebf598d95e5d7db77564fbcba5786d8eeccd7182a99e03ace842af860ab70c468271a95e249e245aa4b81945
Please use a base64 SHA512 hash. The source-builder/sha512-base64 command will
generate the hash for you.
A base64 hash version is ok to push.
Thanks
