[PATCH] cpukit/flash: Correct erase ioctl address
Chris Johns
chrisj at rtems.org
Mon Jun 26 21:55:54 UTC 2023
Pushed and thanks
On 26/6/2023 3:29 pm, aaron.nyholm at unfoldedeffective.com wrote:
> From: Aaron Nyholm <aaron.nyholm at southerninnovation.com>
> Previously, the erase ioctl call would ignore flash regions and erase at
> the absolute address passed in. This adds a check for if the region is
> set and adds the region offset accordingly.
> cpukit/dev/flash/flashdev.c | 43 ++++++++++++++++++++++++++++++-------
> 1 file changed, 35 insertions(+), 8 deletions(-)
> diff --git a/cpukit/dev/flash/flashdev.c b/cpukit/dev/flash/flashdev.c
> index 4b7a0560ff..be85593201 100644
> --- a/cpukit/dev/flash/flashdev.c
> +++ b/cpukit/dev/flash/flashdev.c
> @@ -135,6 +135,13 @@ static int rtems_flashdev_get_addr(
> off_t *addr
> +static int rtems_flashdev_get_abs_addr(
> + rtems_flashdev *flash,
> + rtems_libio_t *iop,
> + size_t count,
> + off_t *addr
> static int rtems_flashdev_update_and_return(
> rtems_libio_t *iop,
> int status,
> @@ -565,6 +572,28 @@ static int rtems_flashdev_get_addr(
> return 0;
> + size_t count,
> + off_t *addr
> + off_t new_offset;
> + /* Check address is in valid region */
> + new_offset = *addr + count;
> + if (rtems_flashdev_check_offset_region(flash, iop, new_offset)) {
> + return -1;
> + /* Get address for operation */
> + if ( rtems_flashdev_is_region_defined( iop ) ) {
> + *addr = ( *addr + rtems_flashdev_get_region_offset( flash, iop ) );
> + return 0;
> rtems_libio_t *iop,
> int status,
> @@ -588,7 +617,7 @@ static int rtems_flashdev_ioctl_erase(
> rtems_flashdev_region *erase_args_1;
> - off_t check_offset;
> + off_t new_offset;
> int status;
> if ( flash->erase == NULL ) {
> @@ -597,16 +626,14 @@ static int rtems_flashdev_ioctl_erase(
> erase_args_1 = (rtems_flashdev_region *) arg;
> /* Check erasing valid region */
> - check_offset = erase_args_1->offset + erase_args_1->size;
> - if ( rtems_flashdev_is_region_defined( iop ) && (
> - rtems_flashdev_check_offset_region(flash, iop, check_offset) ||
> - ( erase_args_1->offset <
> - rtems_flashdev_get_region_offset( flash, iop ) ) ) ) {
> - rtems_set_errno_and_return_minus_one( EINVAL );
> + new_offset = erase_args_1->offset;
> + status = rtems_flashdev_get_abs_addr(flash, iop, erase_args_1->size, &new_offset);
> + if ( status < 0 ) {
> + return status;
> /* Erase flash */
> - status = ( *flash->erase )( flash, erase_args_1->offset, erase_args_1->size );
> + status = ( *flash->erase )( flash, new_offset, erase_args_1->size );
> return status;
