[PATCH rtems-docs] c-user: Update references to rtems_task_wake_after
Sebastian Huber
Tue Jun 27 21:05:23 UTC 2023
On 27.06.23 22:18, Kinsey Moore wrote:
> diff --git a/c-user/task/directives.rst b/c-user/task/directives.rst
> index c082b51..3334679 100644
> --- a/c-user/task/directives.rst
> +++ b/c-user/task/directives.rst
> @@ -1475,15 +1475,15 @@ The following constraints apply to this directive:
> \clearpage
> .. index:: rtems_task_wake_after()
> -.. index:: delay a task for an interval
> -.. index:: wake up after an interval
> +.. index:: delay a task for a number of ticks
> +.. index:: wake up after a number of ticks
> .. _InterfaceRtemsTaskWakeAfter:
> -Wakes up after an interval in :term:`clock ticks <clock tick>` or yields the
> +Wakes up after a number of :term:`clock ticks <clock tick>` or yields the
> processor.
> .. rubric:: CALLING SEQUENCE:
> @@ -1502,10 +1502,12 @@ processor.
> This directive blocks the calling task for the specified ``ticks`` of clock
> ticks if the value is not equal to :c:macro:`RTEMS_YIELD_PROCESSOR`. When the
> -requested interval has elapsed, the task is made ready. The clock tick
> +requested number of ticks has elapsed, the task is made ready. The clock tick
> directives automatically updates the delay period. The calling task may give
> up the processor and remain in the ready state by specifying a value of
> -:c:macro:`RTEMS_YIELD_PROCESSOR` in ``ticks``.
> +:c:macro:`RTEMS_YIELD_PROCESSOR` in ``ticks``. Applications requiring use of a
> +time base instead of system ticks should make use of ``nanosleep()`` or
> +``clock_nanosleep()``.
What is a time base?
nanosleep() has the same issues as rtems_task_wake_after(). If you want
to wait for fixed intervals, then you have to use clock_nanosleep() with
TIMER_ABSTIME and CLOCK_MONOTONIC.
The wording with the interval is not really wrong. Only the clock
resolution is a bit coarse (clock ticks). I guess the real problem is
that if you want to implement a periodic task with
while (1) {
f();
rtems_task_wake_after(period);
then this doesn't work if the time between calls to
rtems_task_wake_after() varies within the range of clock ticks. This can
be fixed by using clock_nanosleep() with TIMER_ABSTIME and CLOCK_MONOTONIC.
> .. rubric:: RETURN VALUES:
Could you please update
https://git.rtems.org/rtems-central/tree/spec/rtems/task/if/wake-after.yml
since this will keep also the Doxygen up to date.
For clock_nanosleep() references, use ${/c/if/clock-nanosleep:/name}.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
