[PATCH v2 00/32] Integrate pre-qualified LEON3 BSP
Thu Jun 29 00:29:02 UTC 2023
On 29/6/2023 3:41 am, Sebastian Huber wrote:
> On 16.06.23 08:00, Sebastian Huber wrote:
>> The register block specification were recently integrated in the RTEMS
>> Software Engineering manual.  Now it is time to integrate the
>> pre-qualified LEON3 BSP which uses the generated GRLIB header files.
>> The existing tests in the RTEMS test suite are basically BSP
>> independent. This patch set introduces BSP-specific validation tests.
>> These tests are disabled for other BSPs through the build system, for
>> example:
>> spec/build/testsuites/validation/bsp-sparc-leon3-gr712rc.yml
>> cxxflags: []
>> enabled-by: sparc/gr712rc
>> features: c cprogram
>> The patch set introduces new header files for GRLIB in
>> "bsps/include/grlib".  These header files were generated from
>> specification items in:
>> https://github.com/RTEMS/rtems-central/tree/master/spec/dev/grlib/if
>> The specification was created using the GRIP reference manual
>> (https://www.gaisler.com/products/grlib/grip.pdf) and is quite complete.
>> The generated header files were reviewed by the ISVV activity which
>> resulted in two tickets:
>> https://devel.rtems.org/ticket/4828
>> https://devel.rtems.org/ticket/4842
>> In the long term, the existing GRLIB header files should be replaced by
>> the generated header files. Using specification items for the register
>> blocks has the potential benefit that, in addition to the C header
>> files, files for C++/Rust/Python could be generated.
>> The main change for the sparc/gr712rc and sparc/gr740 BSPs is the
>> removal of the dynamic device enumeration in favor of a static
>> initialization.  This greatly simplifies the specification and
>> validation of the BSP-specific parts. It also reduces the code and data
>> size for applications which do not need the dynamic device enumeration.
>> v2:
>> * Move BSP-specific tests to "testsuites/validation/bsps".
>> * Rearrange patches so that they build individually.
> Any comments to this patch set? For the leon3-specific parts I wait for a review
> from Gaisler.
Nothing new from me.
I still do not see how the reg struct is verified however you are fine with
that. I do not use this code.
