[PATCH rtems-libbsd 2/3] freebsd/cgem: Read clock frequency from device tree
Padmarao Begari
padmarao.begari at microchip.com
Wed Mar 1 05:57:27 UTC 2023
Read the clock frequency from the device tree and use it to
calculate the mdc clock divider for the MII bus if not found
then use default clock divider.
freebsd/sys/dev/cadence/if_cgem.c | 39 ++++++++++++++++++++++++++++---
1 file changed, 36 insertions(+), 3 deletions(-)
diff --git a/freebsd/sys/dev/cadence/if_cgem.c b/freebsd/sys/dev/cadence/if_cgem.c
index 2888a085..363a9717 100644
--- a/freebsd/sys/dev/cadence/if_cgem.c
+++ b/freebsd/sys/dev/cadence/if_cgem.c
@@ -135,6 +135,7 @@ struct cgem_softc {
uint32_t net_cfg_shadow;
int neednullqs;
int phy_contype;
+ uint32_t pclk_rate;
#endif /* __rtems__ */
int ref_clk_num;
#ifndef __rtems__
@@ -1238,6 +1239,27 @@ cgem_get_phyaddr(phandle_t node, int *phy_addr)
return (0);
+static uint32_t cgem_mdc_clk_div(struct cgem_softc *sc)
+ uint32_t config;
+ uint32_t pclk_hz = sc->pclk_rate;
+ if (pclk_hz <= 20000000)
+ config = CGEM_NET_CFG_MDC_CLK_DIV_8;
+ else if (pclk_hz <= 40000000)
+ config = CGEM_NET_CFG_MDC_CLK_DIV_16;
+ else if (pclk_hz <= 80000000)
+ config = CGEM_NET_CFG_MDC_CLK_DIV_32;
+ else if (pclk_hz <= 120000000)
+ config = CGEM_NET_CFG_MDC_CLK_DIV_48;
+ else if (pclk_hz <= 160000000)
+ config = CGEM_NET_CFG_MDC_CLK_DIV_64;
+ else
+ config = CGEM_NET_CFG_MDC_CLK_DIV_96;
+ return config;
/* Reset hardware. */
static void
cgem_reset(struct cgem_softc *sc)
@@ -1279,12 +1301,16 @@ cgem_reset(struct cgem_softc *sc)
sc->net_cfg_shadow = CGEM_NET_CFG_DBUS_WIDTH_32;
+ if (sc->pclk_rate != 0) {
+ sc->net_cfg_shadow |= cgem_mdc_clk_div(sc);
+ } else {
#ifdef CGEM64
- sc->net_cfg_shadow |= CGEM_NET_CFG_MDC_CLK_DIV_48;
+ sc->net_cfg_shadow |= CGEM_NET_CFG_MDC_CLK_DIV_48;
#else
- sc->net_cfg_shadow |= CGEM_NET_CFG_MDC_CLK_DIV_64;
+ sc->net_cfg_shadow |= CGEM_NET_CFG_MDC_CLK_DIV_64;
#endif
- WR4(sc, CGEM_NET_CFG, sc->net_cfg_shadow);
+ WR4(sc, CGEM_NET_CFG, sc->net_cfg_shadow);
sc->net_ctl_shadow = CGEM_NET_CTRL_MGMT_PORT_EN;
@@ -2038,6 +2064,13 @@ cgem_attach(device_t dev)
/* Get reference clock number and base divider from fdt. */
node = ofw_bus_get_node(dev);
+#ifdef __rtems__
+ if (OF_getencprop(node, "clock-frequency", &cell, sizeof(cell)) > 0)
+ sc->pclk_rate = cell;
+ else
+ sc->pclk_rate = 0;
+#endif /* __rtems__ */
sc->ref_clk_num = 0;
if (OF_getprop(node, "ref-clock-num", &cell, sizeof(cell)) > 0)
sc->ref_clk_num = fdt32_to_cpu(cell);
2.25.1
