[PATCH] build: Print item UID in case of errors
Kinsey Moore
kinsey.moore at oarcorp.com
Mon Mar 6 16:04:57 UTC 2023
Looks good. A welcome improvement for anyone working on the build system.
Kinsey
On Mon, Mar 6, 2023 at 9:40 AM Sebastian Huber <
> This helps to identify issues in build items.
> wscript | 14 ++++++++++++--
> 1 file changed, 12 insertions(+), 2 deletions(-)
> diff --git a/wscript b/wscript
> index a34cac51e2..567f42db2f 100755
> --- a/wscript
> +++ b/wscript
> @@ -214,14 +214,24 @@ class Item(object):
> self.prepare_configure(conf, cic)
> for p in self.links():
> p.configure(conf, cic)
> - self.do_configure(conf, cic)
> + try:
> + self.do_configure(conf, cic)
> + except Exception as e:
> + raise type(e)(
> + "Configuration error related to item spec:{}:
> {}".format(
> + self.uid, str(e)))
> def build(self, bld, bic):
> if _is_enabled(bld.env.ENABLE, self.get_enabled_by()):
> bic = self.prepare_build(bld, bic)
> p.build(bld, bic)
> - self.do_build(bld, bic)
> + try:
> + self.do_build(bld, bic)
> + raise type(e)(
> + "Build error related to item spec:{}: {}".format(
> def do_defaults(self, enabled):
> return
> 2.35.3
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230306/013a1ba0/attachment-0001.htm>
