Help regarding Building x86_64 BSP
Joel Sherrill
joel at rtems.org
Wed Mar 8 00:42:17 UTC 2023
Did you build the x86_64 tools and qemu using the RTEMS Source Builder?
On Tue, Mar 7, 2023, 11:39 AM Karel Gardas <karel at functional.vision> wrote:
> On 3/7/23 19:24, Karel Gardas wrote:
> > On 3/7/23 15:05, Siddharth Khattar wrote:
> >> Hello all,
> >> So I was aiming to make a project to improve the amd64 BSP for RTEMS
> >> (modify it according to ACPI standards along with other stuff) but
> >> first I would need to build it. Unfortunately there was no way to
> >> build it natively within RTEMS source. So, I needed to install QEMU
> >> and had to build the UEFI firmware,OVMF by Tianocore in order to build
> >> it.
> > Indeed, they still list Ubutnu 16.04 LTS as a build OS. Hmm, I would go
> > with VM for this. You need to build it just once...
> Investigating more, it looks like qemu build those too, so there is no
> need to deal with TianoCore alone anymore. My 7.2.0 install contains:
> $ find qemu-7.2.0/share/qemu/ -name 'edk2*'
> qemu-7.2.0/share/qemu/edk2-arm-code.fd
> qemu-7.2.0/share/qemu/edk2-x86_64-code.fd
> qemu-7.2.0/share/qemu/edk2-arm-vars.fd
> qemu-7.2.0/share/qemu/edk2-i386-secure-code.fd
> qemu-7.2.0/share/qemu/edk2-x86_64-secure-code.fd
> qemu-7.2.0/share/qemu/edk2-aarch64-code.fd
> qemu-7.2.0/share/qemu/edk2-i386-code.fd
> qemu-7.2.0/share/qemu/edk2-i386-vars.fd
> qemu-7.2.0/share/qemu/edk2-licenses.txt
> Ditto for Qemu build by RSB. Will send you tarball of scripts I'm using
> for building and running rtems.exe on those...
> Karel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230307/5ac96071/attachment.htm>
