[PATCH rtems-docs] c-user/chains: Correct iteration example code
Thu Mar 9 01:40:14 UTC 2023
On 9/3/2023 7:22 am, Kinsey Moore wrote:
> On Wed, Mar 8, 2023 at 3:47 PM Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
>     On 9/3/2023 5:40 am, Kinsey Moore wrote:
>     > Casting the node returned by rtems_chain_head is incorrect. That node is
>     > owned by the control structure and use of it post-cast could cause
>     > memory corruption.
>     >  c-user/chains.rst | 4 ++++
>     >  1 file changed, 4 insertions(+)
>     > diff --git a/c-user/chains.rst b/c-user/chains.rst
>     > index f518ef4..e791d10 100644
>     > --- a/c-user/chains.rst
>     > +++ b/c-user/chains.rst
>     > @@ -193,6 +193,10 @@ placed on another chain:
>     >          rtems_chain_initialize_empty (out);
>     >          node = rtems_chain_head (chain);
>     > +        /* The node returned by rtems_chain_head() is owned by the chain */
>     > +        node = node->next;
>      node = rtems_chain_next (node);  ?
> node->next is used slightly further down in the example, but I can change it to
> rtems_chain_next for both if you prefer.
Thanks. I think making all references use the API in the example is a good thing.
