Add Formal Verification chapter v3
Andrew.Butterfield at scss.tcd.ie
Mon Mar 13 09:17:20 UTC 2023
Hi Gedare,
pull request done
Regards,
Andrew
On 10/03/2023, 21:23, "Gedare Bloom" <gedare at rtems.org <mailto:gedare at rtems.org>> wrote:
On Fri, Mar 10, 2023 at 8:19 AM Andrew.Butterfield at scss.tcd.ie <mailto:Andrew.Butterfield at scss.tcd.ie>
<Andrew.Butterfield at scss.tcd.ie <mailto:Andrew.Butterfield at scss.tcd.ie>> wrote:
> Hi Gedare,
> the quick and easy way is to visit https://github.com/andrewbutterfield/rtems-docs/commit/8165814471402d56c480b1400b121715ad507c58 <https://github.com/andrewbutterfield/rtems-docs/commit/8165814471402d56c480b1400b121715ad507c58>
Yes, In this case, can you (or I can) create a Pull Request from your
new-eng-chapter branch to the `master` branch on your fork of
rtems-docs? then I can review your code changes for you there pretty
easily.
> That's a fork of RTEMS/rtems-docs on Github - and is the top of my `new-eng-chapter` branch.
> The commits are those I had developing it and do not match the patch-set I sent.
> Will that do?
> Regards,
> Andrew
> On 09/03/2023, 20:22, "Gedare Bloom" <gedare at rtems.org <mailto:gedare at rtems.org> <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>> wrote:
> Hi Andrew,
> In this case, since the patches are attachments, would you happen to
> have a hosted git (github?) repo that I could examine to facilitate a
> review. I can only review inline patches efficiently by email.
> Gedare
> On Thu, Mar 9, 2023 at 6:52 AM Andrew.Butterfield at scss.tcd.ie <mailto:Andrew.Butterfield at scss.tcd.ie> <mailto:Andrew.Butterfield at scss.tcd.ie <mailto:Andrew.Butterfield at scss.tcd.ie>>
> <Andrew.Butterfield at scss.tcd.ie <mailto:Andrew.Butterfield at scss.tcd.ie> <mailto:Andrew.Butterfield at scss.tcd.ie <mailto:Andrew.Butterfield at scss.tcd.ie>>> wrote:
> > ping
> > From: devel <devel-bounces at rtems.org <mailto:devel-bounces at rtems.org> <mailto:devel-bounces at rtems.org <mailto:devel-bounces at rtems.org>>> on behalf of "Andrew.Butterfield at scss.tcd.ie <mailto:Andrew.Butterfield at scss.tcd.ie> <mailto:Andrew.Butterfield at scss.tcd.ie <mailto:Andrew.Butterfield at scss.tcd.ie>>" <Andrew.Butterfield at scss.tcd.ie <mailto:Andrew.Butterfield at scss.tcd.ie> <mailto:Andrew.Butterfield at scss.tcd.ie <mailto:Andrew.Butterfield at scss.tcd.ie>>>
> > Date: Friday 10 February 2023 at 16:10
> > To: "rtems-devel at rtems.org <mailto:rtems-devel at rtems.org> <mailto:rtems-devel at rtems.org <mailto:rtems-devel at rtems.org>>" <rtems-devel at rtems.org <mailto:rtems-devel at rtems.org> <mailto:rtems-devel at rtems.org <mailto:rtems-devel at rtems.org>>>
> > Subject: eng: Add Formal Verification chapter v3
> > Dear RTEMS Developers,
> > Here is a 3rd version of the proposed Formal Verification chapter
> > to be added to the Software Engineering Manual.
> > The patch-set is attached here, as I cannot use git-mail.
> > Best Regards,
> > Andrew
> > devel mailing list
> > devel at rtems.org <mailto:devel at rtems.org> <mailto:devel at rtems.org <mailto:devel at rtems.org>>
> > http://lists.rtems.org/mailman/listinfo/devel <http://lists.rtems.org/mailman/listinfo/devel> <http://lists.rtems.org/mailman/listinfo/devel> <http://lists.rtems.org/mailman/listinfo/devel>>
