Add Formal Verification chapter v3
Mon Mar 13 14:36:13 UTC 2023
On Mon, Mar 13, 2023 at 8:07 AM Gedare Bloom <gedare at rtems.org> wrote:
> I closed it, and instead created a Pull Request from your
> new-eng-chapter branch to the `master` branch on your fork of
> rtems-docs
I have added comments to https://github.com/andrewbutterfield/rtems-docs/pull/1
> On Mon, Mar 13, 2023 at 3:17 AM Andrew.Butterfield at scss.tcd.ie
> <Andrew.Butterfield at scss.tcd.ie> wrote:
> > Hi Gedare,
> >  pull request done
> > Regards,
> >  Andrew
> > On 10/03/2023, 21:23, "Gedare Bloom" <gedare at rtems.org <mailto:gedare at rtems.org>> wrote:
> > On Fri, Mar 10, 2023 at 8:19 AM Andrew.Butterfield at scss.tcd.ie <mailto:Andrew.Butterfield at scss.tcd.ie>
> > <Andrew.Butterfield at scss.tcd.ie <mailto:Andrew.Butterfield at scss.tcd.ie>> wrote:
> > > Hi Gedare,
> > > the quick and easy way is to visit https://github.com/andrewbutterfield/rtems-docs/commit/8165814471402d56c480b1400b121715ad507c58 <https://github.com/andrewbutterfield/rtems-docs/commit/8165814471402d56c480b1400b121715ad507c58>
> > Yes, In this case, can you (or I can) create a Pull Request from your
> > rtems-docs? then I can review your code changes for you there pretty
> > easily.
> > > That's a fork of RTEMS/rtems-docs on Github - and is the top of my `new-eng-chapter` branch.
> > > The commits are those I had developing it and do not match the patch-set I sent.
> > > Will that do?
> > > Regards,
> > > Andrew
> > > On 09/03/2023, 20:22, "Gedare Bloom" <gedare at rtems.org <mailto:gedare at rtems.org> <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>> wrote:
> > > Hi Andrew,
> > > In this case, since the patches are attachments, would you happen to
> > > have a hosted git (github?) repo that I could examine to facilitate a
> > > review. I can only review inline patches efficiently by email.
> > > Gedare
> > > On Thu, Mar 9, 2023 at 6:52 AM Andrew.Butterfield at scss.tcd.ie <mailto:Andrew.Butterfield at scss.tcd.ie> <mailto:Andrew.Butterfield at scss.tcd.ie <mailto:Andrew.Butterfield at scss.tcd.ie>>
> > > <Andrew.Butterfield at scss.tcd.ie <mailto:Andrew.Butterfield at scss.tcd.ie> <mailto:Andrew.Butterfield at scss.tcd.ie <mailto:Andrew.Butterfield at scss.tcd.ie>>> wrote:
> > > > ping
> > > > From: devel <devel-bounces at rtems.org <mailto:devel-bounces at rtems.org> <mailto:devel-bounces at rtems.org <mailto:devel-bounces at rtems.org>>> on behalf of "Andrew.Butterfield at scss.tcd.ie <mailto:Andrew.Butterfield at scss.tcd.ie> <mailto:Andrew.Butterfield at scss.tcd.ie <mailto:Andrew.Butterfield at scss.tcd.ie>>" <Andrew.Butterfield at scss.tcd.ie <mailto:Andrew.Butterfield at scss.tcd.ie> <mailto:Andrew.Butterfield at scss.tcd.ie <mailto:Andrew.Butterfield at scss.tcd.ie>>>
> > > > Date: Friday 10 February 2023 at 16:10
> > > > To: "rtems-devel at rtems.org <mailto:rtems-devel at rtems.org> <mailto:rtems-devel at rtems.org <mailto:rtems-devel at rtems.org>>" <rtems-devel at rtems.org <mailto:rtems-devel at rtems.org> <mailto:rtems-devel at rtems.org <mailto:rtems-devel at rtems.org>>>
> > > > Subject: eng: Add Formal Verification chapter v3
> > > > Dear RTEMS Developers,
> > > > Here is a 3rd version of the proposed Formal Verification chapter
> > > > to be added to the Software Engineering Manual.
> > > > The patch-set is attached here, as I cannot use git-mail.
> > > > Best Regards,
> > > > Andrew
> > > > _______________________________________________
> > > > devel mailing list
> > > > devel at rtems.org <mailto:devel at rtems.org> <mailto:devel at rtems.org <mailto:devel at rtems.org>>
> > > > http://lists.rtems.org/mailman/listinfo/devel <http://lists.rtems.org/mailman/listinfo/devel> <http://lists.rtems.org/mailman/listinfo/devel> <http://lists.rtems.org/mailman/listinfo/devel>>
