[PATCH 2/2] bsps/riscv: add riscv/kendrytek210 BSP variant
Mon Mar 13 16:16:02 UTC 2023
On Mon, Mar 13, 2023 at 9:53 AM Alan Cudmore <alan.cudmore at gmail.com> wrote:
> Thanks for taking a look. Comments below.
> On Mon, Mar 13, 2023 at 11:04 AM Gedare Bloom <gedare at rtems.org> wrote:
>> On Thu, Mar 9, 2023 at 8:48 PM Alan Cudmore <alan.cudmore at gmail.com> wrote:
>> > This patch set adds support for the Kendryte K210 RISC-V BSP variant.
>> > The SoC uses existing PLIC, Timer, and console UART. It only needs
>> > SoC specific initalization and an embedded device tree binary similar
>> > to the polarfire SoC BSP.
>> > Updates #4876
>> >  bsps/riscv/riscv/config/kendrytek210.cfg      |   9 +
>> >  bsps/riscv/riscv/console/console-config.c     |  10 +-
>> >  bsps/riscv/riscv/console/fe310-uart.c         |   2 +-
>> >  bsps/riscv/riscv/dts/kendryte-k210.dts        | 216 ++++++++++++
>> >  bsps/riscv/riscv/include/bsp.h                |   4 +
>> >  bsps/riscv/riscv/include/bsp/k210.h           |  91 +++++
>> >  .../riscv/include/bsp/kendryte-k210-dtb.h     | 315 ++++++++++++++++++
>> >  bsps/riscv/riscv/include/bsp/riscv.h          |   4 +
>> >  bsps/riscv/riscv/start/bspstart.c             |  42 +++
>> >  9 files changed, 687 insertions(+), 6 deletions(-)
>> >  create mode 100644 bsps/riscv/riscv/config/kendrytek210.cfg
>> >  create mode 100644 bsps/riscv/riscv/dts/kendryte-k210.dts
>> >  create mode 100644 bsps/riscv/riscv/include/bsp/k210.h
>> >  create mode 100644 bsps/riscv/riscv/include/bsp/kendryte-k210-dtb.h
>> > diff --git a/bsps/riscv/riscv/config/kendrytek210.cfg b/bsps/riscv/riscv/config/kendrytek210.cfg
>> > new file mode 100644
>> > index 0000000000..b04e78b0e9
>> > --- /dev/null
>> > +++ b/bsps/riscv/riscv/config/kendrytek210.cfg
>> > @@ -0,0 +1,9 @@
>> > +include $(RTEMS_ROOT)/make/custom/default.cfg
>> > +RTEMS_CPU = riscv
>> > +CPU_CFLAGS = -march=rv64imafdc -mabi=lp64d -mcmodel=medany
>> > +LDFLAGS = -Wl,--gc-sections
>> > +CFLAGS_OPTIMIZE_V ?= -O2 -g -ffunction-sections -fdata-sections
>> > diff --git a/bsps/riscv/riscv/console/console-config.c b/bsps/riscv/riscv/console/console-config.c
>> > index 4916191e0b..72743fe9d5 100644
>> > --- a/bsps/riscv/riscv/console/console-config.c
>> > +++ b/bsps/riscv/riscv/console/console-config.c
>> > @@ -55,7 +55,7 @@
>> >  #include <libfdt.h>
>> >  #include <string.h>
>> > -#if RISCV_ENABLE_FRDME310ARTY_SUPPORT != 0
>> > +#if RISCV_ENABLE_SIFIVE_UART_SUPPORT != 0
>> >  #include <bsp/fe310-uart.h>
>> >  static fe310_uart_context fe310_uart_instance;
>> >  #endif
>> > @@ -239,7 +239,7 @@ static void riscv_console_probe(void)
>> >  #endif
>> >      if (fdt_stringlist_contains(compat, compat_len, "sifive,uart0")) {
>> >        fe310_uart_context *ctx;
>> > @@ -255,7 +255,7 @@ static void riscv_console_probe(void)
>> >          riscv_console.getchar = fe310_uart_read;
>> > -      rtems_termios_device_context_initialize(&ctx->base, "FE310UART");
>> > +      rtems_termios_device_context_initialize(&ctx->base, "SIFIVEUART");
>> >  #endif
>> > @@ -290,7 +290,7 @@ rtems_status_code console_initialize(
>> >    size_t i;
>> >  #endif
>> >    char fe310_path[] = "/dev/ttyS0";
>> >  #endif
>> > @@ -326,7 +326,7 @@ rtems_status_code console_initialize(
>> >  #endif
>> >    ctx = &fe310_uart_instance;
>> >    rtems_termios_device_install(
>> >      fe310_path,
>> > diff --git a/bsps/riscv/riscv/console/fe310-uart.c b/bsps/riscv/riscv/console/fe310-uart.c
>> > index 506521add0..ddabcff4c8 100644
>> > --- a/bsps/riscv/riscv/console/fe310-uart.c
>> > +++ b/bsps/riscv/riscv/console/fe310-uart.c
>> > @@ -53,7 +53,7 @@ static void fe310_uart_write (
>> >    fe310_uart_context * ctx = (fe310_uart_context*) base;
>> >    size_t i;
>> > -  ctx->regs->div = riscv_get_core_frequency() / 115200 - 1;
>> > +  ctx->regs->div = (riscv_get_core_frequency() / 115200 - 1) & 0xFFFF;
>> >    ctx->regs->txctrl |= 1;
>> >    ctx->regs->rxctrl |= 1;
>> > diff --git a/bsps/riscv/riscv/dts/kendryte-k210.dts b/bsps/riscv/riscv/dts/kendryte-k210.dts
>> > index 0000000000..379aaf01a3
>> > --- /dev/null
>> > +++ b/bsps/riscv/riscv/dts/kendryte-k210.dts
>> > @@ -0,0 +1,216 @@
>> > +/* SPDX-License-Identifier: BSD-2-Clause */
>> > + * Copyright (C) Alan Cudmore
>> > + * Copyright (C) Padmarao Begari
>> > + * Copyright (C) 2022 Microchip Technology Inc.
>> > + * Redistribution and use in source and binary forms, with or without
>> > + * modification, are permitted provided that the following conditions
>> > + * are met:
>> > + * 1. Redistributions of source code must retain the above copyright
>> > + *     notice, this list of conditions and the following disclaimer.
>> > + * 2. Redistributions in binary form must reproduce the above copyright
>> > + *     notice, this list of conditions and the following disclaimer in the
>> > + *     documentation and/or other materials provided with the distribution.
>> > + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
>> > + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
>> > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
>> > + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
>> > + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>> > + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>> > + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
>> > + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
>> > + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
>> > + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
>> > + * POSSIBILITY OF SUCH DAMAGE.
>> > + /* This is a device tree for the Kendryte K210 SoC. It is a simplified tree
>> > +  * to support the current RTEMS BSP, but it is not sufficient enough for
>> > +  * full linux or u-boot support.
>> > +  * The file structure is based on the device tree source for the
>> > +  * Polarfire SoC created by Padmaro Begari. The K210 device trees from
>> > +  * u-boot were originally used to bring up the RTEMS BSP and were
>> > +  * referenced to develop this file.
>> > +/dts-v1/;
>> > +        /* 32 bit address bus - upper 32 bits are ignored */
>> > +       #address-cells = <1>;
>> > +       #size-cells = <1>;
>> > +       model = "Kendtryte K210 generic";
>> > +       compatible = "canaan,kendryte-k210";
>> > +       aliases {
>> > +               serial0 = &uarths0;
>> > +               serial1 = &uart1;
>> > +               /* serial2 = &uart2; */
>> > +               /* serial3 = &uart3; */
>> > +       chosen {
>> > +               stdout-path = "serial0";
>> > +       cpus {
>> > +               #size-cells = <0>;
>> > +               timebase-frequency = <7800000>;
>> > +               cpu0: cpu at 0 {
>> > +                       compatible = "canaan,k210", "riscv";
>> > +                       device_type = "cpu";
>> > +                       reg = <0>;
>> > +                       riscv,isa = "rv64imafdc";
>> > +                       i-cache-block-size = <64>;
>> > +                       i-cache-size = <0x8000>;
>> > +                       d-cache-block-size = <64>;
>> > +                       d-cache-size = <0x8000>;
>> > +                       cpu0_intc: interrupt-controller {
>> > +                               #interrupt-cells = <1>;
>> > +                               compatible = "riscv,cpu-intc";
>> > +                               interrupt-controller;
>> > +               cpu1: cpu at 1 {
>> > +                       reg = <1>;
>> > +                       cpu1_intc: interrupt-controller {
>> > +       clocks {
>> > +                in0: oscillator {
>> > +                       compatible = "fixed-clock";
>> > +                       #clock-cells = <0>;
>> > +                       clock-frequency = <26000000>;
>> > +       sram: memory at 80000000 {
>> > +               device_type = "memory";
>> > +                compatible = "canaan,k210-sram";
>> > +               reg = <0x80000000 0x400000>,
>> > +                     <0x80400000 0x200000>,
>> > +                     <0x80600000 0x200000>;
>> > +                reg-names = "sram0",
>> > +                            "sram1",
>> > +                            "aisram";
>> > +       soc: soc {
>> > +               compatible = "simple-bus";
>> > +               ranges;
>> > +                interrupt-parent = <&plic0>;
>> > +                rom0: nvmem at 1000 {
>> > +                         reg = <0x1000 0x1000>;
>> > +                         read-only;
>> > +               clint0: timer at 2000000 {
>> > +                       compatible = "riscv,clint0","sifive,clint0";
>> > +                       reg = <0x2000000 0xC000>;
>> > +                       interrupts-extended = <&cpu0_intc 3>,<&cpu0_intc 7>,
>> > +                                             <&cpu1_intc 3>,<&cpu1_intc 7>;
>> > +               plic0: interrupt-controller at c000000 {
>> > +                       #address-cells = <0>;
>> > +                       compatible = "riscv,plic0","sifive,plic-1.0.0";
>> > +                       reg = <0xC000000 0x4000000>;
>> > +                       riscv,ndev = <65>;
>> > +                               <&cpu0_intc 11>, <&cpu0_intc 9>,
>> > +                               <&cpu1_intc 11>, <&cpu1_intc 9>;
>> > +               uarths0: serial at 38000000 {
>> > +                       compatible = "canaan,k210-uarths","sifive,uart0";
>> > +                       reg = <0x38000000 0x1000>;
>> > +                       interrupts = <33>;
>> > +                       clocks = <&sysclk 0>;
>> > +                /* apb0 has gpio1 and additional uarts */
>> > +               apb0: bus at 50200000 {
>> > +                       compatible = "simple-pm-bus";
>> > +                       ranges;
>> > +                       clocks = <&sysclk 8>;
>> > +                       uart1: serial at 50210000 {
>> > +                               compatible = "snps,dw-apb-uart";
>> > +                               reg = <0x50210000 0x100>;
>> > +                               interrupts = <11>;
>> > +                               clocks = <&sysclk 30>,
>> > +                                        <&sysclk 8>;
>> > +                               clock-namees = "baudclk", "abp_pclk";
>> > +                               resets = <&sysrst 16>;
>> > +                               reg-io-width = <4>;
>> > +                               reg-shift = <2>;
>> > +                               dcd-override;
>> > +                               dsr-override;
>> > +                               cts-override;
>> > +                               ri-override;
>> > +                apb1: bus at 50400000 {
>> > +                       ranges;
>> > +                       clocks = <&sysclk 9>;
>> > +                       sysctl: syscon at 50440000 {
>> > +                               compatible = "canaan,k210-sysctl","syscon",
>> > +                                            "simple-mfd";
>> > +                               reg = <0x50440000 0x100>;
>> > +                               clock-names = "pclk";
>> > +                               sysclk: clock-controller {
>> > +                                       #clock-cells = <1>;
>> > +                                       compatible = "canaan,k210-rst";
>> > +                                       clock = <&in0>;
>> > +                               sysrst: reset-coontroller {
>> > +                                       #reset-cells = <1>;
>> > +                               reboot: syscon-reboot {
>> > +                                       compatible = "syscon-reboot";
>> > +                                       regmap = <&sysctl>;
>> > +                                       offset = <48>;
>> > +                                       mask = <1>;
>> > +                                       value = <1>;
>> > diff --git a/bsps/riscv/riscv/include/bsp.h b/bsps/riscv/riscv/include/bsp.h
>> > index 911b85f4a3..c33de42aa7 100644
>> > --- a/bsps/riscv/riscv/include/bsp.h
>> > +++ b/bsps/riscv/riscv/include/bsp.h
>> > @@ -60,6 +60,10 @@
>> >  #include <rtems/devnull.h>
>> > +#if RISCV_ENABLE_KENDRYTE_K210_SUPPORT != 0
>> > +   #include <bsp/k210.h>
>> > +#endif
>> >  #ifdef __cplusplus
>> >  extern "C" {
>> >  #endif
>> > diff --git a/bsps/riscv/riscv/include/bsp/k210.h b/bsps/riscv/riscv/include/bsp/k210.h
>> > index 0000000000..558502cd11
>> > --- /dev/null
>> > +++ b/bsps/riscv/riscv/include/bsp/k210.h
>> > @@ -0,0 +1,91 @@
>> > + * @file
>> > + * @ingroup k210_regs
>> > + * @brief k210 RISC-V CPU defines.
>> > + *  Copyright (c) 2022 Alan Cudmore
>> > + *  The license and distribution terms for this file may be
>> > + *  found in the file LICENSE in this distribution or at
>> > + *  http://www.rtems.org/license/LICENSE
> OK  - I'll update this
>> Please use the 2-BSD boilerplate consistent with the SPDX above.
>> > +#ifndef LIBBSP_RISCV_RISCV_K210_H
>> > +#define LIBBSP_RISCV_RISCV_K210_H
>> > +#include <bspopts.h>
>> > +#include <stdint.h>
>> > +#include <bsp/utility.h>
>> > + * @defgroup K210 RISC V Register Definitions
>> > + * @ingroup RTEMSBSPsriscv
>> > + * @brief Register Definitions
>> > +#ifdef __cplusplus
>> > +extern "C" {
>> > +#endif
>> > +/* For PLL / Clocks */
>> > +#define K210_SYSCTL_BASE     0x50440000
>> > +#define PLL_CLK_R(n)         (n & 0x00000F)
>> Usually good practice to put parens around CPP macro arguments, e.g.,
>> ((n) & 0x00000F)
>> > +#define PLL_CLK_F(n)         ((n & 0x0003F0) >> 4)
>> > +#define PLL_CLK_OD(n)        ((n & 0x003C00) >> 10)
>> > +#define CLKSEL0_ACLK_SEL(n)  (n & 0x00000001)
>> > +typedef struct {
>> > +  uint32_t git_id;
>> > +  uint32_t clk_freq;
>> > +  uint32_t pll0;
>> > +  uint32_t pll1;
>> > +  uint32_t pll2;
>> > +  uint32_t resv5;
>> > +  uint32_t pll_lock;
>> > +  uint32_t rom_error;
>> > +  uint32_t clk_sel0;
>> > +  uint32_t clk_sel1;
>> > +  uint32_t clk_en_cent;
>> > +  uint32_t clk_en_peri;
>> > +  uint32_t soft_reset;
>> > +  uint32_t peri_reset;
>> > +  uint32_t clk_th0;
>> > +  uint32_t clk_th1;
>> > +  uint32_t clk_th2;
>> > +  uint32_t clk_th3;
>> > +  uint32_t clk_th4;
>> > +  uint32_t clk_th5;
>> > +  uint32_t clk_th6;
>> > +  uint32_t misc;
>> > +  uint32_t peri;
>> > +  uint32_t spi_sleep;
>> > +  uint32_t reset_status;
>> > +  uint32_t dma_sel0;
>> > +  uint32_t dma_sel1;
>> > +  uint32_t power_sel;
>> > +  uint32_t resv28;
>> > +  uint32_t resv29;
>> > +  uint32_t resv30;
>> > +  uint32_t resv31;
>> > +} k210_sysctl_t;
>> > +#ifdef __cplusplus
>> > +#endif
>> > +#endif /* LIBBSP_RISCV_RISCV_K210_H */
>> > diff --git a/bsps/riscv/riscv/include/bsp/kendryte-k210-dtb.h b/bsps/riscv/riscv/include/bsp/kendryte-k210-dtb.h
>> > index 0000000000..ad13aefdbf
>> > --- /dev/null
>> > +++ b/bsps/riscv/riscv/include/bsp/kendryte-k210-dtb.h
>> > @@ -0,0 +1,315 @@
>> > + *  Declarations for C structure representing binary file system.dtb
>> > + *  WARNING: Automatically generated -- do not edit!
>> > + * are met:
>> > +#ifndef __kendryte_k210_dtb_h
>> > +#define __kendryte_k210_dtb_h
>> > +#include <rtems/score/basedefs.h>
>> > +#include <sys/types.h>
>> > +const unsigned char system_dtb[] RTEMS_ALIGNED(8) = {
>> > +  0xd0, 0x0d, 0xfe, 0xed, 0x00, 0x00, 0x0c, 0xa7, 0x00, 0x00, 0x00, 0x38,
>> > +  0x00, 0x00, 0x0a, 0xb4, 0x00, 0x00, 0x00, 0x28, 0x00, 0x00, 0x00, 0x11,
>> > +  0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xf3,
>> > +  0x00, 0x00, 0x0a, 0x7c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
>> > +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
>> > +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
>> > +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03,
>> > +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, 0x01,
>> > +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x17, 0x00, 0x00, 0x00, 0x1b,
>> > +  0x4b, 0x65, 0x6e, 0x64, 0x74, 0x72, 0x79, 0x74, 0x65, 0x20, 0x4b, 0x32,
>> > +  0x31, 0x30, 0x20, 0x67, 0x65, 0x6e, 0x65, 0x72, 0x69, 0x63, 0x00, 0x00,
>> > +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x15, 0x00, 0x00, 0x00, 0x21,
>> > +  0x63, 0x61, 0x6e, 0x61, 0x61, 0x6e, 0x2c, 0x6b, 0x65, 0x6e, 0x64, 0x72,
>> > +  0x79, 0x74, 0x65, 0x2d, 0x6b, 0x32, 0x31, 0x30, 0x00, 0x00, 0x00, 0x00,
>> > +  0x00, 0x00, 0x00, 0x01, 0x61, 0x6c, 0x69, 0x61, 0x73, 0x65, 0x73, 0x00,
>> > +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x15, 0x00, 0x00, 0x00, 0x2c,
>> > +  0x2f, 0x73, 0x6f, 0x63, 0x2f, 0x73, 0x65, 0x72, 0x69, 0x61, 0x6c, 0x40,
>> > +  0x33, 0x38, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00,
>> > +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x22, 0x00, 0x00, 0x00, 0x34,
>> > +  0x2f, 0x73, 0x6f, 0x63, 0x2f, 0x62, 0x75, 0x73, 0x40, 0x35, 0x30, 0x32,
>> > +  0x30, 0x30, 0x30, 0x30, 0x30, 0x2f, 0x73, 0x65, 0x72, 0x69, 0x61, 0x6c,
>> > +  0x40, 0x35, 0x30, 0x32, 0x31, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00,
>> > +  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x63, 0x68, 0x6f, 0x73,
>> > +  0x65, 0x6e, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08,
>> > +  0x00, 0x00, 0x00, 0x3c, 0x73, 0x65, 0x72, 0x69, 0x61, 0x6c, 0x30, 0x00,
>> > +  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x63, 0x70, 0x75, 0x73,
>> > +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, 0x00,
>> > +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x48,
>> > +  0x00, 0x77, 0x04, 0xc0, 0x00, 0x00, 0x00, 0x01, 0x63, 0x70, 0x75, 0x40,
>> > +  0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x12,
>> > +  0x00, 0x00, 0x00, 0x21, 0x63, 0x61, 0x6e, 0x61, 0x61, 0x6e, 0x2c, 0x6b,
>> > +  0x32, 0x31, 0x30, 0x00, 0x72, 0x69, 0x73, 0x63, 0x76, 0x00, 0x00, 0x00,
>> > +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x5b,
>> > +  0x63, 0x70, 0x75, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
>> > +  0x00, 0x00, 0x00, 0x67, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
>> > +  0x00, 0x00, 0x00, 0x0b, 0x00, 0x00, 0x00, 0x6b, 0x72, 0x76, 0x36, 0x34,
>> > +  0x69, 0x6d, 0x61, 0x66, 0x64, 0x63, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
>> > +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x75, 0x00, 0x00, 0x00, 0x40,
>> > +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x88,
>> > +  0x00, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
>> > +  0x00, 0x00, 0x00, 0x95, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x03,
>> > +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xa8, 0x00, 0x00, 0x80, 0x00,
>> > +  0x00, 0x00, 0x00, 0x01, 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72, 0x75, 0x70,
>> > +  0x74, 0x2d, 0x63, 0x6f, 0x6e, 0x74, 0x72, 0x6f, 0x6c, 0x6c, 0x65, 0x72,
>> > +  0x00, 0x00, 0x00, 0xb5, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03,
>> > +  0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, 0x21, 0x72, 0x69, 0x73, 0x63,
>> > +  0x76, 0x2c, 0x63, 0x70, 0x75, 0x2d, 0x69, 0x6e, 0x74, 0x63, 0x00, 0x00,
>> > +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc6,
>> > +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xdb,
>> > +  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02,
>> > +  0x00, 0x00, 0x00, 0x01, 0x63, 0x70, 0x75, 0x40, 0x31, 0x00, 0x00, 0x00,
>> > +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x12, 0x00, 0x00, 0x00, 0x21,
>> > +  0x63, 0x61, 0x6e, 0x61, 0x61, 0x6e, 0x2c, 0x6b, 0x32, 0x31, 0x30, 0x00,
>> > +  0x72, 0x69, 0x73, 0x63, 0x76, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
>> > +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x5b, 0x63, 0x70, 0x75, 0x00,
>> > +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x67,
>> > +  0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0b,
>> > +  0x00, 0x00, 0x00, 0x6b, 0x72, 0x76, 0x36, 0x34, 0x69, 0x6d, 0x61, 0x66,
>> > +  0x64, 0x63, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
>> > +  0x00, 0x00, 0x00, 0x75, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x03,
>> > +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x88, 0x00, 0x00, 0x80, 0x00,
>> > +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x95,
>> > +  0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
>> > +  0x00, 0x00, 0x00, 0xa8, 0x00, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x01,
>> > +  0x69, 0x6e, 0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74, 0x2d, 0x63, 0x6f,
>> > +  0x6e, 0x74, 0x72, 0x6f, 0x6c, 0x6c, 0x65, 0x72, 0x00, 0x00, 0x00, 0x00,
>> > +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xb5,
>> > +  0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0f,
>> > +  0x00, 0x00, 0x00, 0x21, 0x72, 0x69, 0x73, 0x63, 0x76, 0x2c, 0x63, 0x70,
>> > +  0x75, 0x2d, 0x69, 0x6e, 0x74, 0x63, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
>> > +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc6, 0x00, 0x00, 0x00, 0x03,
>> > +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xdb, 0x00, 0x00, 0x00, 0x03,
>> > +  0x00, 0x00, 0x00, 0x01, 0x63, 0x6c, 0x6f, 0x63, 0x6b, 0x73, 0x00, 0x00,
>> > +  0x00, 0x00, 0x00, 0x01, 0x6f, 0x73, 0x63, 0x69, 0x6c, 0x6c, 0x61, 0x74,
>> > +  0x6f, 0x72, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0c,
>> > +  0x00, 0x00, 0x00, 0x21, 0x66, 0x69, 0x78, 0x65, 0x64, 0x2d, 0x63, 0x6c,
>> > +  0x6f, 0x63, 0x6b, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
>> > +  0x00, 0x00, 0x00, 0xe3, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
>> > +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xf0, 0x01, 0x8c, 0xba, 0x80,
>> > +  0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02,
>> > +  0x00, 0x00, 0x00, 0x01, 0x6d, 0x65, 0x6d, 0x6f, 0x72, 0x79, 0x40, 0x38,
>> > +  0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x03,
>> > +  0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x5b, 0x6d, 0x65, 0x6d, 0x6f,
>> > +  0x72, 0x79, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x11,
>> > +  0x32, 0x31, 0x30, 0x2d, 0x73, 0x72, 0x61, 0x6d, 0x00, 0x00, 0x00, 0x00,
>> > +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x18, 0x00, 0x00, 0x00, 0x67,
>> > +  0x80, 0x00, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x80, 0x40, 0x00, 0x00,
>> > +  0x00, 0x20, 0x00, 0x00, 0x80, 0x60, 0x00, 0x00, 0x00, 0x20, 0x00, 0x00,
>> > +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x13, 0x00, 0x00, 0x01, 0x00,
>> > +  0x73, 0x72, 0x61, 0x6d, 0x30, 0x00, 0x73, 0x72, 0x61, 0x6d, 0x31, 0x00,
>> > +  0x61, 0x69, 0x73, 0x72, 0x61, 0x6d, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02,
>> > +  0x00, 0x00, 0x00, 0x01, 0x73, 0x6f, 0x63, 0x00, 0x00, 0x00, 0x00, 0x03,
>> > +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
>> > +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x0f,
>> > +  0x00, 0x00, 0x00, 0x21, 0x73, 0x69, 0x6d, 0x70, 0x6c, 0x65, 0x2d, 0x62,
>> > +  0x75, 0x73, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00,
>> > +  0x00, 0x00, 0x01, 0x0a, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
>> > +  0x00, 0x00, 0x01, 0x11, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x01,
>> > +  0x6e, 0x76, 0x6d, 0x65, 0x6d, 0x40, 0x31, 0x30, 0x30, 0x30, 0x00, 0x00,
>> > +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x67,
>> > +  0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x03,
>> > +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x22, 0x00, 0x00, 0x00, 0x02,
>> > +  0x00, 0x00, 0x00, 0x01, 0x74, 0x69, 0x6d, 0x65, 0x72, 0x40, 0x32, 0x30,
>> > +  0x30, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
>> > +  0x00, 0x00, 0x00, 0x1b, 0x00, 0x00, 0x00, 0x21, 0x72, 0x69, 0x73, 0x63,
>> > +  0x76, 0x2c, 0x63, 0x6c, 0x69, 0x6e, 0x74, 0x30, 0x00, 0x73, 0x69, 0x66,
>> > +  0x69, 0x76, 0x65, 0x2c, 0x63, 0x6c, 0x69, 0x6e, 0x74, 0x30, 0x00, 0x00,
>> > +  0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x03,
>> > +  0x00, 0x00, 0x00, 0x20, 0x00, 0x00, 0x01, 0x2c, 0x00, 0x00, 0x00, 0x02,
>> > +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x07,
>> > +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x03,
>> > +  0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
>> > +  0x6e, 0x74, 0x72, 0x6f, 0x6c, 0x6c, 0x65, 0x72, 0x40, 0x63, 0x30, 0x30,
>> > +  0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
>> > +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xb5, 0x00, 0x00, 0x00, 0x01,
>> > +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00,
>> > +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x1e,
>> > +  0x00, 0x00, 0x00, 0x21, 0x72, 0x69, 0x73, 0x63, 0x76, 0x2c, 0x70, 0x6c,
>> > +  0x69, 0x63, 0x30, 0x00, 0x73, 0x69, 0x66, 0x69, 0x76, 0x65, 0x2c, 0x70,
>> > +  0x6c, 0x69, 0x63, 0x2d, 0x31, 0x2e, 0x30, 0x2e, 0x30, 0x00, 0x00, 0x00,
>> > +  0x0c, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
>> > +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x01, 0x40, 0x00, 0x00, 0x00, 0x41,
>> > +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x20, 0x00, 0x00, 0x01, 0x2c,
>> > +  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x0b, 0x00, 0x00, 0x00, 0x02,
>> > +  0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0b,
>> > +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x03,
>> > +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xdb, 0x00, 0x00, 0x00, 0x01,
>> > +  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x73, 0x65, 0x72, 0x69,
>> > +  0x61, 0x6c, 0x40, 0x33, 0x38, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x00,
>> > +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x20, 0x00, 0x00, 0x00, 0x21,
>> > +  0x63, 0x61, 0x6e, 0x61, 0x61, 0x6e, 0x2c, 0x6b, 0x32, 0x31, 0x30, 0x2d,
>> > +  0x75, 0x61, 0x72, 0x74, 0x68, 0x73, 0x00, 0x73, 0x69, 0x66, 0x69, 0x76,
>> > +  0x65, 0x2c, 0x75, 0x61, 0x72, 0x74, 0x30, 0x00, 0x00, 0x00, 0x00, 0x03,
>> > +  0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x67, 0x38, 0x00, 0x00, 0x00,
>> > +  0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
>> > +  0x00, 0x00, 0x01, 0x4b, 0x00, 0x00, 0x00, 0x21, 0x00, 0x00, 0x00, 0x03,
>> > +  0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x01, 0x56, 0x00, 0x00, 0x00, 0x04,
>> > +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
>> > +  0x62, 0x75, 0x73, 0x40, 0x35, 0x30, 0x32, 0x30, 0x30, 0x30, 0x30, 0x30,
>> > +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x00, 0x21,
>> > +  0x73, 0x69, 0x6d, 0x70, 0x6c, 0x65, 0x2d, 0x70, 0x6d, 0x2d, 0x62, 0x75,
>> > +  0x73, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00,
>> > +  0x00, 0x00, 0x01, 0x0a, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08,
>> > +  0x00, 0x00, 0x01, 0x56, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x08,
>> > +  0x00, 0x00, 0x00, 0x01, 0x73, 0x65, 0x72, 0x69, 0x61, 0x6c, 0x40, 0x35,
>> > +  0x30, 0x32, 0x31, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x03,
>> > +  0x00, 0x00, 0x00, 0x11, 0x00, 0x00, 0x00, 0x21, 0x73, 0x6e, 0x70, 0x73,
>> > +  0x2c, 0x64, 0x77, 0x2d, 0x61, 0x70, 0x62, 0x2d, 0x75, 0x61, 0x72, 0x74,
>> > +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08,
>> > +  0x00, 0x00, 0x00, 0x67, 0x50, 0x21, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00,
>> > +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x01, 0x4b,
>> > +  0x00, 0x00, 0x00, 0x0b, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x10,
>> > +  0x00, 0x00, 0x01, 0x56, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x1e,
>> > +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x03,
>> > +  0x00, 0x00, 0x00, 0x11, 0x00, 0x00, 0x01, 0x5d, 0x62, 0x61, 0x75, 0x64,
>> > +  0x63, 0x6c, 0x6b, 0x00, 0x61, 0x62, 0x70, 0x5f, 0x70, 0x63, 0x6c, 0x6b,
>> > +  0x00, 0x00, 0x01, 0x6a, 0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x00, 0x10,
>> > +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x01, 0x71,
>> > +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
>> > +  0x00, 0x00, 0x01, 0x7e, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x03,
>> > +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x88, 0x00, 0x00, 0x00, 0x03,
>> > +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x95, 0x00, 0x00, 0x00, 0x03,
>> > +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xa2, 0x00, 0x00, 0x00, 0x03,
>> > +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xaf, 0x00, 0x00, 0x00, 0x02,
>> > +  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x62, 0x75, 0x73, 0x40,
>> > +  0x35, 0x30, 0x34, 0x30, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00,
>> > +  0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
>> > +  0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03,
>> > +  0x00, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x00, 0x21, 0x73, 0x69, 0x6d, 0x70,
>> > +  0x6c, 0x65, 0x2d, 0x70, 0x6d, 0x2d, 0x62, 0x75, 0x73, 0x00, 0x00, 0x00,
>> > +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x0a,
>> > +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x01, 0x56,
>> > +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x01,
>> > +  0x73, 0x79, 0x73, 0x63, 0x6f, 0x6e, 0x40, 0x35, 0x30, 0x34, 0x34, 0x30,
>> > +  0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x25,
>> > +  0x32, 0x31, 0x30, 0x2d, 0x73, 0x79, 0x73, 0x63, 0x74, 0x6c, 0x00, 0x73,
>> > +  0x79, 0x73, 0x63, 0x6f, 0x6e, 0x00, 0x73, 0x69, 0x6d, 0x70, 0x6c, 0x65,
>> > +  0x2d, 0x6d, 0x66, 0x64, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
>> > +  0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x67, 0x50, 0x44, 0x00, 0x00,
>> > +  0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08,
>> > +  0x00, 0x00, 0x01, 0x56, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x09,
>> > +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x01, 0xbb,
>> > +  0x70, 0x63, 0x6c, 0x6b, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
>> > +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xdb, 0x00, 0x00, 0x00, 0x07,
>> > +  0x00, 0x00, 0x00, 0x01, 0x63, 0x6c, 0x6f, 0x63, 0x6b, 0x2d, 0x63, 0x6f,
>> > +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xe3,
>> > +  0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x10,
>> > +  0x32, 0x31, 0x30, 0x2d, 0x72, 0x73, 0x74, 0x00, 0x00, 0x00, 0x00, 0x03,
>> > +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x01, 0xc7, 0x00, 0x00, 0x00, 0x06,
>> > +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
>> > +  0x72, 0x65, 0x73, 0x65, 0x74, 0x2d, 0x63, 0x6f, 0x6f, 0x6e, 0x74, 0x72,
>> > +  0x6f, 0x6c, 0x6c, 0x65, 0x72, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
>> > +  0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x21, 0x63, 0x61, 0x6e, 0x61,
>> > +  0x61, 0x6e, 0x2c, 0x6b, 0x32, 0x31, 0x30, 0x2d, 0x72, 0x73, 0x74, 0x00,
>> > +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x01, 0xcd,
>> > +  0x00, 0x00, 0x00, 0xdb, 0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x00, 0x02,
>> > +  0x00, 0x00, 0x00, 0x01, 0x73, 0x79, 0x73, 0x63, 0x6f, 0x6e, 0x2d, 0x72,
>> > +  0x65, 0x62, 0x6f, 0x6f, 0x74, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
>> > +  0x00, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x00, 0x21, 0x73, 0x79, 0x73, 0x63,
>> > +  0x6f, 0x6e, 0x2d, 0x72, 0x65, 0x62, 0x6f, 0x6f, 0x74, 0x00, 0x00, 0x00,
>> > +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x01, 0xda,
>> > +  0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
>> > +  0x00, 0x00, 0x01, 0xe1, 0x00, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x03,
>> > +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x01, 0xe8, 0x00, 0x00, 0x00, 0x01,
>> > +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x01, 0xed,
>> > +  0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02,
>> > +  0x00, 0x00, 0x00, 0x09, 0x23, 0x61, 0x64, 0x64, 0x72, 0x65, 0x73, 0x73,
>> > +  0x2d, 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x23, 0x73, 0x69, 0x7a, 0x65,
>> > +  0x2d, 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x6d, 0x6f, 0x64, 0x65, 0x6c,
>> > +  0x00, 0x63, 0x6f, 0x6d, 0x70, 0x61, 0x74, 0x69, 0x62, 0x6c, 0x65, 0x00,
>> > +  0x73, 0x65, 0x72, 0x69, 0x61, 0x6c, 0x30, 0x00, 0x73, 0x65, 0x72, 0x69,
>> > +  0x61, 0x6c, 0x31, 0x00, 0x73, 0x74, 0x64, 0x6f, 0x75, 0x74, 0x2d, 0x70,
>> > +  0x61, 0x74, 0x68, 0x00, 0x74, 0x69, 0x6d, 0x65, 0x62, 0x61, 0x73, 0x65,
>> > +  0x2d, 0x66, 0x72, 0x65, 0x71, 0x75, 0x65, 0x6e, 0x63, 0x79, 0x00, 0x64,
>> > +  0x65, 0x76, 0x69, 0x63, 0x65, 0x5f, 0x74, 0x79, 0x70, 0x65, 0x00, 0x72,
>> > +  0x65, 0x67, 0x00, 0x72, 0x69, 0x73, 0x63, 0x76, 0x2c, 0x69, 0x73, 0x61,
>> > +  0x00, 0x69, 0x2d, 0x63, 0x61, 0x63, 0x68, 0x65, 0x2d, 0x62, 0x6c, 0x6f,
>> > +  0x63, 0x6b, 0x2d, 0x73, 0x69, 0x7a, 0x65, 0x00, 0x69, 0x2d, 0x63, 0x61,
>> > +  0x63, 0x68, 0x65, 0x2d, 0x73, 0x69, 0x7a, 0x65, 0x00, 0x64, 0x2d, 0x63,
>> > +  0x61, 0x63, 0x68, 0x65, 0x2d, 0x62, 0x6c, 0x6f, 0x63, 0x6b, 0x2d, 0x73,
>> > +  0x69, 0x7a, 0x65, 0x00, 0x64, 0x2d, 0x63, 0x61, 0x63, 0x68, 0x65, 0x2d,
>> > +  0x73, 0x69, 0x7a, 0x65, 0x00, 0x23, 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72,
>> > +  0x75, 0x70, 0x74, 0x2d, 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x69, 0x6e,
>> > +  0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74, 0x2d, 0x63, 0x6f, 0x6e, 0x74,
>> > +  0x72, 0x6f, 0x6c, 0x6c, 0x65, 0x72, 0x00, 0x70, 0x68, 0x61, 0x6e, 0x64,
>> > +  0x6c, 0x65, 0x00, 0x23, 0x63, 0x6c, 0x6f, 0x63, 0x6b, 0x2d, 0x63, 0x65,
>> > +  0x6c, 0x6c, 0x73, 0x00, 0x63, 0x6c, 0x6f, 0x63, 0x6b, 0x2d, 0x66, 0x72,
>> > +  0x65, 0x71, 0x75, 0x65, 0x6e, 0x63, 0x79, 0x00, 0x72, 0x65, 0x67, 0x2d,
>> > +  0x6e, 0x61, 0x6d, 0x65, 0x73, 0x00, 0x72, 0x61, 0x6e, 0x67, 0x65, 0x73,
>> > +  0x00, 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74, 0x2d, 0x70,
>> > +  0x61, 0x72, 0x65, 0x6e, 0x74, 0x00, 0x72, 0x65, 0x61, 0x64, 0x2d, 0x6f,
>> > +  0x6e, 0x6c, 0x79, 0x00, 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72, 0x75, 0x70,
>> > +  0x74, 0x73, 0x2d, 0x65, 0x78, 0x74, 0x65, 0x6e, 0x64, 0x65, 0x64, 0x00,
>> > +  0x72, 0x69, 0x73, 0x63, 0x76, 0x2c, 0x6e, 0x64, 0x65, 0x76, 0x00, 0x69,
>> > +  0x6e, 0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74, 0x73, 0x00, 0x63, 0x6c,
>> > +  0x6f, 0x63, 0x6b, 0x73, 0x00, 0x63, 0x6c, 0x6f, 0x63, 0x6b, 0x2d, 0x6e,
>> > +  0x61, 0x6d, 0x65, 0x65, 0x73, 0x00, 0x72, 0x65, 0x73, 0x65, 0x74, 0x73,
>> > +  0x00, 0x72, 0x65, 0x67, 0x2d, 0x69, 0x6f, 0x2d, 0x77, 0x69, 0x64, 0x74,
>> > +  0x68, 0x00, 0x72, 0x65, 0x67, 0x2d, 0x73, 0x68, 0x69, 0x66, 0x74, 0x00,
>> > +  0x64, 0x63, 0x64, 0x2d, 0x6f, 0x76, 0x65, 0x72, 0x72, 0x69, 0x64, 0x65,
>> > +  0x00, 0x64, 0x73, 0x72, 0x2d, 0x6f, 0x76, 0x65, 0x72, 0x72, 0x69, 0x64,
>> > +  0x65, 0x00, 0x63, 0x74, 0x73, 0x2d, 0x6f, 0x76, 0x65, 0x72, 0x72, 0x69,
>> > +  0x64, 0x65, 0x00, 0x72, 0x69, 0x2d, 0x6f, 0x76, 0x65, 0x72, 0x72, 0x69,
>> > +  0x64, 0x65, 0x00, 0x63, 0x6c, 0x6f, 0x63, 0x6b, 0x2d, 0x6e, 0x61, 0x6d,
>> > +  0x65, 0x73, 0x00, 0x63, 0x6c, 0x6f, 0x63, 0x6b, 0x00, 0x23, 0x72, 0x65,
>> > +  0x73, 0x65, 0x74, 0x2d, 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x72, 0x65,
>> > +  0x67, 0x6d, 0x61, 0x70, 0x00, 0x6f, 0x66, 0x66, 0x73, 0x65, 0x74, 0x00,
>> > +  0x6d, 0x61, 0x73, 0x6b, 0x00, 0x76, 0x61, 0x6c, 0x75, 0x65, 0x00,
>> > +const size_t system_dtb_size = sizeof(system_dtb);
>> > +#endif /* __kendryte_k210_dtb_h */
>> > diff --git a/bsps/riscv/riscv/include/bsp/riscv.h b/bsps/riscv/riscv/include/bsp/riscv.h
>> > index bbaaa246c1..d294f1ae58 100644
>> > --- a/bsps/riscv/riscv/include/bsp/riscv.h
>> > +++ b/bsps/riscv/riscv/include/bsp/riscv.h
>> > @@ -56,6 +56,10 @@ uint32_t riscv_get_hart_index_by_phandle(uint32_t phandle);
>> >  void htif_poweroff(void);
>> >  #endif
>> > +uint32_t k210_get_frequency(void);
>> > +#endif
>> >  #ifdef __cplusplus
>> >  #endif
>> > diff --git a/bsps/riscv/riscv/start/bspstart.c b/bsps/riscv/riscv/start/bspstart.c
>> > index 30d479ce88..a0b6e683f6 100644
>> > --- a/bsps/riscv/riscv/start/bspstart.c
>> > +++ b/bsps/riscv/riscv/start/bspstart.c
>> > @@ -201,6 +201,14 @@ static uint32_t get_core_frequency(void)
>> >      return fdt32_to_cpu(*val);
>> >  #endif
>> > +  uint32_t cpu_clock;
>> > +  cpu_clock = k210_get_frequency();
>> > +  return cpu_clock;
>> > +#endif
>> >    return 0;
> When you choose the kendrtyek210 BSP variant, the RISCV_ENABLE_KENDRYTE_K210_SUPPORT is set to true enabling the code that is needed for frequency calculation in this file. I tried to follow the same pattern for the MPFS and FRDME310ARTY variants here.
> The K210, FRME310ARTY, and MPFS options could probably use refactoring, but I was reluctant to change existing code for the MPFS and 310ARTY since I do not have a way of testing them.
I would at  a minimum make it #else return 0
to avoid having unreachable code in your build.
>> This code is unreachable if RISCV_ENABLE_KENDRYTE_K210_SUPPORT != 0.
>> > @@ -215,6 +223,40 @@ uint32_t bsp_fdt_map_intr(const uint32_t *intr, size_t icells)
>> >    return RISCV_INTERRUPT_VECTOR_EXTERNAL(intr[0]);
>> > +  k210_sysctl_t *sysctl = (k210_sysctl_t *)K210_SYSCTL_BASE;
>> > +  uint32_t cpu_clock = 0;
>> > +  uint32_t pll0, nr, nf, od;
>> > +  uint32_t node;
>> > +  const char *fdt;
>> > +  const fdt32_t *val;
>> > +  int len;
>> > +  fdt = bsp_fdt_get();
>> > +  node = fdt_node_offset_by_compatible(fdt, -1,"fixed-clock");
>> > +  val = fdt_getprop(fdt, node, "clock-frequency", &len);
>> > +  if (val != NULL && len == 4) {
>> > +    clk_freq = fdt32_to_cpu(*val);
>> > +    if (CLKSEL0_ACLK_SEL(sysctl->clk_sel0) == 1) {
>> > +       /* PLL0 selected */
>> > +       pll0 = sysctl->pll0;
>> > +       nr = PLL_CLK_R(pll0) + 1;
>> > +       nf = PLL_CLK_F(pll0) + 1;
>> > +       od = PLL_CLK_OD(pll0) + 1;
>> > +       cpu_clock = (clk_freq / nr * nf / od)/2;
>> > +    } else {
>> > +       /* OSC selected */
>> > +       cpu_clock = clk_freq;
>> > +  return cpu_clock;
>> > +#endif
>> >  void bsp_start(void)
>> >    riscv_find_harts();
>> > 2.25.1
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
