[PATCH 2/2] libmisc/shell: Add flashdev command
aaron.nyholm at unfoldedeffective.com
Thu Mar 16 02:56:27 UTC 2023
From: Aaron Nyholm <aaron.nyholm at southerninnovation.com>
Closes #4869
cpukit/include/rtems/shellconfig.h | 7 +
cpukit/libmisc/shell/main_flashdev.c | 352 +++++++++++++++++++++++++++
spec/build/cpukit/objshell.yml | 1 +
3 files changed, 360 insertions(+)
create mode 100644 cpukit/libmisc/shell/main_flashdev.c
diff --git a/cpukit/include/rtems/shellconfig.h b/cpukit/include/rtems/shellconfig.h
index a013840ee7..489f281400 100644
--- a/cpukit/include/rtems/shellconfig.h
+++ b/cpukit/include/rtems/shellconfig.h
@@ -98,6 +98,7 @@ extern rtems_shell_cmd_t rtems_shell_MD5_Command;
extern rtems_shell_cmd_t rtems_shell_RTC_Command;
extern rtems_shell_cmd_t rtems_shell_SPI_Command;
+extern rtems_shell_cmd_t rtems_shell_FLASHDEV_Command;
extern rtems_shell_cmd_t rtems_shell_I2CDETECT_Command;
extern rtems_shell_cmd_t rtems_shell_I2CGET_Command;
extern rtems_shell_cmd_t rtems_shell_I2CSET_Command;
@@ -556,6 +557,12 @@ extern rtems_shell_alias_t * const rtems_shell_Initial_aliases[];
&rtems_shell_SPI_Command,
#endif
+ #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) \
+ && !defined(CONFIGURE_SHELL_NO_COMMAND_FLASHDEV)) \
+ || defined(CONFIGURE_SHELL_COMMAND_FLASHDEV)
+ &rtems_shell_FLASHDEV_Command,
+ #endif
&& !defined(CONFIGURE_SHELL_NO_COMMAND_I2CDETECT)) \
|| defined(CONFIGURE_SHELL_COMMAND_I2CDETECT)
diff --git a/cpukit/libmisc/shell/main_flashdev.c b/cpukit/libmisc/shell/main_flashdev.c
new file mode 100644
index 0000000000..3c6ca1476c
--- /dev/null
+++ b/cpukit/libmisc/shell/main_flashdev.c
@@ -0,0 +1,352 @@
+ * Copyright (C) 2023, 2023 Aaron Nyholm
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#include <fcntl.h>
+#include <stdio.h>
+#include <stdlib.h>
+#include <errno.h>
+#include <rtems/shell.h>
+#include <dev/flash/flashdev.h>
+int flashdev_shell_read(char *dev_path, uint32_t address, uint32_t bytes);
+int flashdev_shell_write(char *dev_path, uint32_t address, char *file_path);
+int flashdev_shell_readid(char *dev_path);
+int flashdev_shell_type(char *dev_path);
+int flashdev_shell_erase(char *dev_path, uint32_t address, uint32_t bytes);
+static const char rtems_flashdev_shell_usage [] =
+ "simple flash read / write / erase\n"
+ "\n"
+ "flashdev <FLASH_DEV_PATH> [-r <address> <bytes>]\n"
+ " [-w <address> <file>] [-e <address> <bytes>]\n"
+ " -r <address> <bytes> Read at address for bytes\n"
+ " -w <address> <file> Write file to address\n"
+ " -e <address> <bytes> Erase at address for bytes\n"
+ " -t Print the flash type\n"
+ " -i Print the READID\n"
+ " -h Print this help\n";
+static int rtems_flashdev_shell_main(int argc, char *argv[]) {
+ char *dev_path = NULL;
+ int i;
+ uint32_t address;
+ uint32_t bytes;
+ char *file_path;
+ for (i = 1; i < argc; ++i) {
+ if (argv[i][0] == '-') {
+ switch (argv[i][1]) {
+ case ('r'):
+ // Read
+ if (argc < 5) {
+ printf("Missing argument\n");
+ return -1;
+ if (dev_path == NULL) {
+ printf("Please input FLASH_DEV_PATH before instruction\n");
+ return 1;
+ errno = 0;
+ address = (uint32_t) strtoul(argv[i+1], NULL, 0);
+ if (errno != 0) {
+ printf("Could not read address\n");
+ errno = 0;
+ bytes = (uint32_t) strtoul(argv[i+2], NULL, 0);
+ if (errno != 0) {
+ return flashdev_shell_read(dev_path, address, bytes);
+ break;
+ case ('w'):
+ // Write
+ if (argc < 5) {
+ return -1;
+ return 1;
+ errno = 0;
+ if (errno != 0) {
+ errno = 0;
+ file_path = argv[i+2];
+ return flashdev_shell_write(dev_path, address, file_path);
+ break;
+ case ('i'):
+ return flashdev_shell_readid(dev_path);
+ break;
+ case ('e'):
+ // Erase
+ if (argc < 5) {
+ return -1;
+ return 1;
+ errno = 0;
+ if (errno != 0) {
+ errno = 0;
+ if (errno != 0) {
+ return flashdev_shell_erase(dev_path, address, bytes);
+ break;
+ case ('t'):
+ return flashdev_shell_type(dev_path);
+ break;
+ case ('h'):
+ default:
+ // Help
+ printf(rtems_flashdev_shell_usage);
+ break;
+ } else if (dev_path == NULL) {
+ dev_path = argv[i];
+ } else {
+ printf("Invalid argument: %s\n", argv[i]);
+ return 1;
+ if (argc == 1) {
+ return 0;
+int flashdev_shell_read(char *dev_path, uint32_t address, uint32_t bytes) {
+ int fd = open(dev_path, O_RDONLY);
+ if (fd == -1) {
+ printf("Couldn't open %s\n", dev_path);
+ return -1;
+ int status = lseek(fd, address, SEEK_SET);
+ if (status == -1) {
+ printf("Reading failed\n");
+ close(fd);
+ return -1;
+ void *buffer = calloc((bytes + bytes%4), 1);
+ if (buffer == NULL) {
+ printf("Failed to allocate read buffer\n");
+ return -1;
+ status = read(fd, buffer, bytes);
+ free(buffer);
+ close(fd);
+ return -1;
+ uint32_t *IntBuf = (uint32_t*)buffer;
+ printf("Reading %s at 0x%08x for %d bytes\n", dev_path, address, bytes);
+ for (int i = 0; i < (bytes/4); i++) {
+ printf("%08x ", IntBuf[i]);
+ if ((i+1)%4 == 0) {
+ printf("\n");
+ printf("\n");
+ free(buffer);
+ close(fd);
+ return 0;
+int flashdev_shell_write(char *dev_path, uint32_t address, char *file_path) {
+ int flash = open(dev_path, O_WRONLY);
+ if (flash == -1) {
+ return -1;
+ int status = lseek(flash, address, SEEK_SET);
+ close(flash);
+ return -1;
+ int file = open(file_path, O_RDONLY);
+ if (file == -1) {
+ printf("Couldn't open %s\n", file_path);
+ close(flash);
+ return -1;
+ off_t length = lseek(file, 0, SEEK_END);
+ if (length == -1) {
+ close(flash);
+ close(file);
+ printf("Couldn't find length of file\n");
+ return -1;
+ if (lseek(file, 0, SEEK_SET) == -1) {
+ close(flash);
+ close(file);
+ return -1;
+ void *buffer = calloc(1, 0x1000);
+ uint32_t offset = 0;
+ while (offset != length) {
+ int read_len = length - offset;
+ if (read_len > 0x1000) {
+ read_len = 0x1000;
+ status = read(file, buffer, read_len);
+ free(buffer);
+ close(flash);
+ close(file);
+ printf("Can't read %s\n", file_path);
+ return -1;
+ status = write(flash, buffer, read_len);
+ free(buffer);
+ close(flash);
+ close(file);
+ printf("Can't write %s\n", dev_path);
+ return -1;
+ offset = offset + read_len;
+ return 0;
+int flashdev_shell_readid(char *dev_path) {
+ if (fd == -1) {
+ return -1;
+ uint32_t readid;
+ int status = ioctl(fd, FLASHDEV_IOCTL_READID, &readid);
+ printf("ReadId failed\n");
+ close(fd);
+ return -1;
+ printf("ReadId: %06x\n", readid);
+ close(fd);
+ return 0;
+int flashdev_shell_type(char *dev_path) {
+ if (fd == -1) {
+ return -1;
+ uint32_t type;
+ int status = ioctl(fd, FLASHDEV_IOCTL_TYPE, &type);
+ printf("Type failed\n");
+ close(fd);
+ return -1;
+ printf("The flash is ");
+ switch(type) {
+ case FLASHDEV_TYPE_NOR:
+ printf("NOR flash\n");
+ break;
+ case FLASHDEV_TYPE_NAND:
+ printf("NAND flash\n");
+ break;
+ default:
+ printf("Unknown type\n");
+ close(fd);
+ return 0;
+int flashdev_shell_erase(char *dev_path, uint32_t address, uint32_t bytes) {
+ if (fd == -1) {
+ return -1;
+ erase_args args;
+ args.offset = address;
+ args.count = bytes;
+ int status = ioctl(fd, FLASHDEV_IOCTL_ERASE, &args);
+ printf("Erase failed\n");
+ close(fd);
+ return -1;
+ close(fd);
+ return 0;
+rtems_shell_cmd_t rtems_shell_FLASHDEV_Command = {
+ .name = "flashdev",
+ .usage = rtems_flashdev_shell_usage,
+ .topic = "misc",
+ .command = rtems_flashdev_shell_main,
diff --git a/spec/build/cpukit/objshell.yml b/spec/build/cpukit/objshell.yml
index 5fd259bee3..b71abb18f9 100644
--- a/spec/build/cpukit/objshell.yml
+++ b/spec/build/cpukit/objshell.yml
@@ -52,6 +52,7 @@ source:
- cpukit/libmisc/shell/main_echo.c
- cpukit/libmisc/shell/main_edit.c
- cpukit/libmisc/shell/main_exit.c
+- cpukit/libmisc/shell/main_flashdev.c
- cpukit/libmisc/shell/main_getenv.c
- cpukit/libmisc/shell/main_halt.c
- cpukit/libmisc/shell/main_help.c
2.25.1
