[PATCH 1/3] bsps/riscv: Make SMP start more robust
Sebastian Huber
Thu Mar 16 08:59:41 UTC 2023
In SMP configurations, check that we run on a configured processor. If not,
then there is not much what can be done since we do not have a stack available
for this processor. Just loop forever in this case. Do this in assemlby to
ensure that no stack memory is used.
bsps/riscv/riscv/start/bspsmp.c | 5 +----
bsps/riscv/shared/start/start.S | 16 ++++++++++++++--
2 files changed, 15 insertions(+), 6 deletions(-)
diff --git a/bsps/riscv/riscv/start/bspsmp.c b/bsps/riscv/riscv/start/bspsmp.c
index 91f4f7b96a..ce5792f5b8 100644
--- a/bsps/riscv/riscv/start/bspsmp.c
+++ b/bsps/riscv/riscv/start/bspsmp.c
@@ -36,10 +36,7 @@ void bsp_start_on_secondary_processor(Per_CPU_Control *cpu_self)
cpu_index_self = _Per_CPU_Get_index(cpu_self);
- if (
- cpu_index_self < rtems_configuration_get_maximum_processors()
- && _SMP_Should_start_processor(cpu_index_self)
+ if (_SMP_Should_start_processor(cpu_index_self)) {
set_csr(mie, MIP_MSIP | MIP_MEIP);
_SMP_Start_multitasking_on_secondary_processor(cpu_self);
} else {
diff --git a/bsps/riscv/shared/start/start.S b/bsps/riscv/shared/start/start.S
index 34e1839ca1..42e4348cd0 100644
--- a/bsps/riscv/shared/start/start.S
+++ b/bsps/riscv/shared/start/start.S
@@ -66,8 +66,17 @@ SYM(_start):
LADDR sp, _ISR_Stack_area_begin
LADDR t2, _ISR_Stack_size
csrr s0, mhartid
- li t3, RISCV_BOOT_HARTID
- sub s0, s0, t3
+ li t3, RISCV_BOOT_HARTID
+ sub s0, s0, t3
+ * Check that this is a configured processor. If not, then there is
+ * not much what can be done since we do not have a stack available for
+ * this processor. Just loop forever in this case.
+ LREG t3, _SMP_Processor_configured_maximum
+ bgeu s0, t3, .Lwfi
LADDR t0, _Per_CPU_Information
slli t1, s0, PER_CPU_CONTROL_SIZE_LOG2
add s1, t0, t1
@@ -100,6 +109,9 @@ SYM(_start):
tail boot_card
#ifdef RTEMS_SMP
+.Lwfi:
+ wfi
+ j .Lwfi
.Lstart_on_secondary_processor:
2.35.3
