[PATCH] score/arm: make MPU setup more generic
Sebastian Huber
Thu Mar 16 10:19:16 UTC 2023
On 16.03.23 10:37, Karel Gardas wrote:
> On 3/16/23 10:19, Sebastian Huber wrote:
>> On 16.03.23 10:14, Karel Gardas wrote:
>>> This patch makes MPU setup more generic by adding capability to set
>>> also control register. This way BSPs are allowed to enable MPU
>>> also for hard faults by simply not setting PRIVDEFENA attribute
>>> to control register. Compatibility with previous behavior and API
>>> is preserved.
>> Is this really a BSP-specific choice or more a user option which
>> should be controlled by a BSP option (through config.ini)?
> config.ini would be even more generic and probably more elegant too.
> However for upstreaming I took a more conservative approach to have a
> chance.
> Let me ask what do you prefer and what will you support? I'm happy to
> write that as long as it is reasonable simple and makes chance to
> upstream higher.
> My goal is simple:
> I'm working on BSP for Precidata SL-3011 board. The board is using
> STM32H747. Board firmware responsible for hardware management runs on
> CM4 while RTEMS and app code will run on CM7 and will be using firmware
> services by calling some API. For communication between both domains we
> use SRAM4. To be able to print hard fault from RTEMS on CM7 I need either:
> - keep cache disabled for SRAM4 region even for hard fault (hence MPU
> change proposed)
> or
> - disable cache in print exception frame directly which involves quite a
> bit of hacking around and looks to be more source code invasive than MPU
> change.
I would add the ctrl parameter to _ARMV7M_MPU_Setup() and add a
ARMV7M_MPU_CTRL_DEFAULT (default value ARMV7M_MPU_CTRL_ENABLE |
ARMV7M_MPU_CTRL_PRIVDEFENA) BSP option for all Cortex-M BSPs.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
