[PATCH] bsps/xqspipsu: Add support for reading ECC
Kinsey Moore kinsey.moore at oarcorp.com
Thu Mar 16 17:39:34 UTC 2023
This adds a helper function to read the ECC status for an ECC unit in
SPI-attached NOR memory.
 bsps/include/dev/spi/xqspipsu-flash-helper.h |  29 +++
 bsps/include/dev/spi/xqspipsu_flash_config.h |   1 +
 bsps/shared/dev/spi/xqspipsu-flash-helper.c  | 223 +++++++++++++++++++
 3 files changed, 253 insertions(+)
diff --git a/bsps/include/dev/spi/xqspipsu-flash-helper.h b/bsps/include/dev/spi/xqspipsu-flash-helper.h
index 075f7f826d..22f85f156c 100644
--- a/bsps/include/dev/spi/xqspipsu-flash-helper.h
+++ b/bsps/include/dev/spi/xqspipsu-flash-helper.h
@@ -79,3 +79,32 @@ int QspiPsu_NOR_Read(
   u32 ByteCount,
   u8 **ReadBfrPtr
+ * This function performs a read of the ECC Status Register for a given address.
+ * @param	QspiPsuPtr is a pointer to the QSPIPSU driver component to use.
+ * @param	Address contains the address of the ECC unit for which the ECCSR
+ *		needs to be read. The ECC unit contains 16 bytes of user data
+ *		and all bytes in an ECC unit will return the same ECCSR.
+ * @param	ReadBfrPtr is a pointer to a single byte to which the ECCSR will
+ * 		be written.
+ * @return	XST_SUCCESS if successful, else XST_FAILURE.
+ * @note	Only the three least significant bits of the returned byte are
+ * 		meaningful. If all bits are 0, ECC is enabled for this unit and
+ * 		no errors have been encountered.
+ * 		Bit 0 is 1: ECC is disabled for the requested unit.
+ * 		Bit 1 is 1: A single bit error has been corrected in user data.
+ * 		Bit 2 is 1: A single bit error has been found in the ECC data
+ * 		            and may indicate user data corruption.
+int QspiPsu_NOR_Read_Ecc(
+  XQspiPsu *QspiPsuPtr,
+  u32 Address,
+  u8 *ReadBfrPtr
diff --git a/bsps/include/dev/spi/xqspipsu_flash_config.h b/bsps/include/dev/spi/xqspipsu_flash_config.h
index 323b223ee3..8ef89f85ff 100644
--- a/bsps/include/dev/spi/xqspipsu_flash_config.h
+++ b/bsps/include/dev/spi/xqspipsu_flash_config.h
@@ -79,6 +79,7 @@ extern "C" {
 #define BANK_REG_RD		0x16
 #define BANK_REG_WR		0x17
+#define READ_ECCSR		0x18
 /* Bank register is called Extended Address Register in Micron */
 #define EXTADD_REG_RD		0xC8
 #define EXTADD_REG_WR		0xC5
diff --git a/bsps/shared/dev/spi/xqspipsu-flash-helper.c b/bsps/shared/dev/spi/xqspipsu-flash-helper.c
index 7fa04efdde..43dc700507 100644
--- a/bsps/shared/dev/spi/xqspipsu-flash-helper.c
+++ b/bsps/shared/dev/spi/xqspipsu-flash-helper.c
@@ -2003,3 +2003,226 @@ static int FlashEnableQuadMode(XQspiPsu *QspiPsuPtr)
   return Status;
+static int MultiDieReadEcc(
+  u32 Address,
+  u32 ByteCount,
+  u8 *WriteBfrPtr,
+  u8 *ReadBfrPtr
+  u32 Address,
+  u8 *ReadBfrPtr
+  u32 RealAddr;
+  u32 DiscardByteCnt;
+  u32 FlashMsgCnt;
+  u8  EccBuffer[16];
+  int ByteCount = sizeof(EccBuffer);
+  int Status;
+  /* Check die boundary conditions if required for any flash */
+  if (Flash_Config_Table[FCTIndex].NumDie > 1) {
+    Status = MultiDieReadEcc(QspiPsuPtr, Address, ByteCount,
+              CmdBfr, EccBuffer);
+    if (Status == XST_SUCCESS) {
+      /* All bytes are the same, so copy one return byte into the output buffer */
+      *ReadBfrPtr = EccBuffer[0];
+    return Status;
+  /* For Dual Stacked, split and read for boundary crossing */
+   * Translate address based on type of connection
+   * If stacked assert the slave select based on address
+  RealAddr = GetRealAddr(QspiPsuPtr, Address);
+  CmdBfr[COMMAND_OFFSET]   = READ_ECCSR;
+  CmdBfr[ADDRESS_1_OFFSET] =
+      (u8)((RealAddr & 0xFF000000) >> 24);
+  CmdBfr[ADDRESS_2_OFFSET] =
+      (u8)((RealAddr & 0xFF0000) >> 16);
+  CmdBfr[ADDRESS_3_OFFSET] =
+      (u8)((RealAddr & 0xFF00) >> 8);
+  CmdBfr[ADDRESS_4_OFFSET] =
+      (u8)(RealAddr & 0xF0);
+  DiscardByteCnt = 5;
+  FlashMsgCnt = 0;
+  FlashMsg[FlashMsgCnt].TxBfrPtr = CmdBfr;
+  FlashMsg[FlashMsgCnt].RxBfrPtr = NULL;
+  FlashMsg[FlashMsgCnt].ByteCount = DiscardByteCnt;
+  FlashMsg[FlashMsgCnt].BusWidth = XQSPIPSU_SELECT_MODE_SPI;
+  FlashMsg[FlashMsgCnt].Flags = XQSPIPSU_MSG_FLAG_TX;
+  FlashMsgCnt++;
+  FlashMsg[FlashMsgCnt].TxBfrPtr = NULL;
+  FlashMsg[FlashMsgCnt].ByteCount = DUMMY_CLOCKS;
+  FlashMsg[FlashMsgCnt].Flags = 0;
+  FlashMsgCnt++;
+  FlashMsg[FlashMsgCnt].RxBfrPtr = EccBuffer;
+  FlashMsg[FlashMsgCnt].ByteCount = ByteCount;
+  FlashMsg[FlashMsgCnt].Flags = XQSPIPSU_MSG_FLAG_RX;
+  if (QspiPsuPtr->Config.ConnectionMode ==
+      XQSPIPSU_CONNECTION_MODE_PARALLEL) {
+    FlashMsg[FlashMsgCnt].Flags |= XQSPIPSU_MSG_FLAG_STRIPE;
+  TransferInProgress = TRUE;
+  Status = XQspiPsu_InterruptTransfer(QspiPsuPtr, FlashMsg,
+              FlashMsgCnt + 1);
+    while (TransferInProgress);
+  return Status;
+ * This function performs an ECC read operation for multi die flash devices.
+ * Default setting is in DMA mode.
+ * @param	Address contains the address of the first sector which needs to
+ *		be erased.
+ * @param	ByteCount contains the total size to be erased.
+ * @param	WriteBfrPtr is pointer to the write buffer which contains data to be
+ *		transmitted
+ * @param	ReadBfrPtr is pointer to the read buffer to which valid received data
+ *		should be written
+ * @note	None.
+  u32 Address,
+  u32 ByteCount,
+  u8 *WriteBfrPtr,
+  u8 *ReadBuffer
+  u32 RealAddr;
+  u32 FlashMsgCnt;
+  int Status;
+  u32 cur_bank = 0;
+  u32 nxt_bank = 0;
+  u32 bank_size;
+  u32 remain_len = ByteCount;
+  u32 data_len;
+  u32 transfer_len;
+   * Some flash devices like N25Q512 have multiple dies
+   * in it. Read operation in these devices is bounded
+   * by its die segment. In a continuous read, across
+   * multiple dies, when the last byte of the selected
+   * die segment is read, the next byte read is the
+   * first byte of the same die segment. This is Die
+   * cross over issue. So to handle this issue, split
+   * a read transaction, that spans across multiple
+   * banks, into one read per bank. Bank size is 16MB
+   * for single and dual stacked mode and 32MB for dual
+   * parallel mode.
+    bank_size = SIXTEENMB << 1;
+  else
+    bank_size = SIXTEENMB;
+  while (remain_len) {
+    cur_bank = Address / bank_size;
+    nxt_bank = (Address + remain_len) / bank_size;
+    if (cur_bank != nxt_bank) {
+      transfer_len = (bank_size * (cur_bank  + 1)) - Address;
+      if (remain_len < transfer_len)
+        data_len = remain_len;
+      else
+        data_len = transfer_len;
+    } else {
+    WriteBfrPtr[COMMAND_OFFSET]   = READ_ECCSR;
+    WriteBfrPtr[ADDRESS_1_OFFSET] =
+    WriteBfrPtr[ADDRESS_2_OFFSET] =
+    WriteBfrPtr[ADDRESS_3_OFFSET] =
+    WriteBfrPtr[ADDRESS_4_OFFSET] =
+    FlashMsgCnt = 0;
+    FlashMsg[FlashMsgCnt].TxBfrPtr = WriteBfrPtr;
+    FlashMsgCnt++;
+    FlashMsgCnt++;
+    FlashMsg[FlashMsgCnt].RxBfrPtr = ReadBuffer;
+    FlashMsg[FlashMsgCnt].ByteCount = data_len;
+        XQSPIPSU_MSG_FLAG_STRIPE;
+                FlashMsgCnt + 1);
+    if (Status != XST_SUCCESS)
+      return XST_FAILURE;
+    ReadBuffer += data_len;
+    Address += data_len;
+    remain_len -= data_len;
+  return 0;
2.30.2
