[PATCH 1/1] change hello world
Sun Mar 19 16:36:57 UTC 2023
Received, thank you.
On Sun, Mar 19, 2023 at 7:30 AM Noriyuki Kurosu <norifxsc at gmail.com> wrote:
> A screenshot of the test run is attached.
> 2023年3月19日(日) 21:24 <norifxsc at gmail.com>:
>> From: Noriyuki Kurosu <norifxsc at gmail.com>
>> fix
>>  testsuites/samples/hello/init.c | 2 +-
>>  1 file changed, 1 insertion(+), 1 deletion(-)
>> diff --git a/testsuites/samples/hello/init.c b/testsuites/samples/hello/init.c
>> index 83f6342ab3..53e8a52506 100644
>> --- a/testsuites/samples/hello/init.c
>> +++ b/testsuites/samples/hello/init.c
>> @@ -41,7 +41,7 @@ static rtems_task Init(
>>    rtems_print_printer_fprintf_putc(&rtems_test_printer);
>>    TEST_BEGIN();
>> -  printf( "Hello World\n" );
>> +  printf( "Hello from The Dark Side!\n" );
>>    TEST_END();
>>    rtems_test_exit( 0 );
>> 2.34.1
> devel mailing list
> devel at rtems.org
