[PATCH] binutils: Disable stack exec and RWX section warnings
Joel Sherrill
joel at rtems.org
Tue Mar 21 15:16:43 UTC 2023
I'm ok with this if Kinsey confirms it
On Tue, Mar 21, 2023, 4:11 AM <chrisj at rtems.org> wrote:
> From: Chris Johns <chrisj at rtems.org>
> Binutils 2.39 and later enable by default warnings for executables
> with executable stack and RWX sections. Disable them.
> Closes #4881
> source-builder/config/binutils-2-1.cfg | 15 ++++++++++++++-
> 1 file changed, 14 insertions(+), 1 deletion(-)
> diff --git a/source-builder/config/binutils-2-1.cfg
> b/source-builder/config/binutils-2-1.cfg
> index 6de33ae..df121af 100644
> --- a/source-builder/config/binutils-2-1.cfg
> +++ b/source-builder/config/binutils-2-1.cfg
> @@ -32,6 +32,18 @@ URL: http://sources.redhat.com/binutils
> %define with_gold 0
> %endif
> +# Disable the new default options to check for stack exec and RWX sections
> +# instroduced in 2.39.
> +%define binutils_extra_config %nil
> +%ifn %{defined without_stackexec}
> + %define binutils_extra_config %{binutils_extra_config}
> --disable-warn-execstack
> +%endif
> +%ifn %{defined without_rwx_sections}
> --disable-warn-rwx-segments
> +%endif
> # Source
> @@ -75,7 +87,8 @@ URL: http://sources.redhat.com/binutils
> --prefix=%{_prefix} --bindir=%{_bindir} \
> --exec-prefix=%{_exec_prefix} \
> --includedir=%{_includedir} --libdir=%{_libdir} \
> - --mandir=%{_mandir} --infodir=%{_infodir}
> + --mandir=%{_mandir} --infodir=%{_infodir} \
> + %{binutils_extra_config}
> %{__make} %{?_smp_mflags} all
> 2.37.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230321/4e0f2c7e/attachment.htm>
