[PATCH 0/1] Fix for Arasan SDHCI driver
rvanderwal at bellsouth.net
Thu Mar 23 00:02:02 UTC 2023
I found an issue with the Arasan SDHCI driver when there is no card
present, it causes RTEMS startup to hang for 10 seconds waiting on mmc
command timeout and displays a controller register dump. It is caused
by the card present signal remaining high while indicating the signal
is not stable.
I've tested this fix using the aarch64/xilinx_zynqmp_lp64_zu3eg bsp on
two different boards: Avnet UtraZed and a custom UltraScale+ board.
Rick VanderWal (1):
rtemsbsd/sdhci: Fix Arasan driver when no card present
rtemsbsd/sys/dev/sdhci/arasan_sdhci.c | 20 ++++++++++++++++++++
1 file changed, 20 insertions(+)
2.34.1
