[PATCH] Add support for ELF notes
Chris Johns
chrisj at rtems.org
Thu Mar 23 19:07:03 UTC 2023
On 24/3/2023 3:57 am, Sebastian Huber wrote:
> On 23.03.23 17:52, Will wrote:
>> Great idea to store this information in the executable itself. Does this need
>> a RTEMS_TEST_STATE_LINK_ONLY test state or something similar for minimum.exe?
> With the notes you can build the test. The test runner would look at the notes
> and then decide if it makes sense to run the test or not. It could still run the
> minimum.exe and see if it terminates.
I welcome notes support. Thanks for adding it.
How will we control and manage the notes we support?
Should we document the top level notes domains (?) with some we control and
restrict and others users can use? For example `note.rtems.test`,
`note.rtems.kernel`, `note.rtems.bsp`, and `note.rtems.user`?
Do you have any host side tools in mind to access notes apart from the standards
like readefl? Maybe the rtems-exe-info tool could do this?
