[PATCH rtems-lwip] lwip.py: Remove directory scanning
Kinsey Moore
kinsey.moore at oarcorp.com
Fri Mar 24 00:57:15 UTC 2023
This removes directory scanning from rtems-lwip for a more robust build
system.
Closes #4889
defs/bsps/aarch64/xilinx_zynqmp_base.json | 6 +++---
.../aarch64/xilinx_zynqmp_hardware_base.json | 8 ++++++++
defs/bsps/aarch64/xilinx_zynqmp_ilp32_qemu.json | 9 ++-------
.../bsps/aarch64/xilinx_zynqmp_ilp32_zu3eg.json | 9 ++-------
.../aarch64/xilinx_zynqmp_lp64_cfc400x.json | 4 ++--
defs/bsps/aarch64/xilinx_zynqmp_lp64_qemu.json | 9 ++-------
defs/bsps/aarch64/xilinx_zynqmp_lp64_zu3eg.json | 9 ++-------
defs/bsps/aarch64/xilinx_zynqmp_qemu_base.json | 8 ++++++++
defs/bsps/arm/beaglebone_bw_base.json | 17 ++++++++++++++---
defs/bsps/arm/tms570_base.json | 6 ++++--
lwip.py | 3 ---
11 files changed, 47 insertions(+), 41 deletions(-)
create mode 100644 defs/bsps/aarch64/xilinx_zynqmp_hardware_base.json
create mode 100644 defs/bsps/aarch64/xilinx_zynqmp_qemu_base.json
diff --git a/defs/bsps/aarch64/xilinx_zynqmp_base.json b/defs/bsps/aarch64/xilinx_zynqmp_base.json
index 515ad6e..c18b339 100644
--- a/defs/bsps/aarch64/xilinx_zynqmp_base.json
+++ b/defs/bsps/aarch64/xilinx_zynqmp_base.json
@@ -11,10 +11,10 @@
"embeddedsw/lib/bsp/standalone/src/arm/common/gcc",
"embeddedsw/lib/bsp/standalone/src/arm/common"
- "source-paths-to-import": [
- "rtemslwip/zynqmp"
"source-files-to-import": [
+ "rtemslwip/zynqmp/xemacps_g.c",
+ "rtemslwip/zynqmp/xil_shims.c",
+ "rtemslwip/zynqmp/xtopology_g.c",
"embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xadapter.c",
"embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xpqueue.c",
"embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif.c",
diff --git a/defs/bsps/aarch64/xilinx_zynqmp_hardware_base.json b/defs/bsps/aarch64/xilinx_zynqmp_hardware_base.json
new file mode 100644
index 0000000..f60a911
--- /dev/null
+++ b/defs/bsps/aarch64/xilinx_zynqmp_hardware_base.json
@@ -0,0 +1,8 @@
+ "header-paths-to-import": [
+ "rtemslwip/zynqmp_hardware"
+ "source-files-to-import": [
+ "rtemslwip/zynqmp_hardware/netstart.c"
diff --git a/defs/bsps/aarch64/xilinx_zynqmp_ilp32_qemu.json b/defs/bsps/aarch64/xilinx_zynqmp_ilp32_qemu.json
index ed8667d..a096668 100644
--- a/defs/bsps/aarch64/xilinx_zynqmp_ilp32_qemu.json
+++ b/defs/bsps/aarch64/xilinx_zynqmp_ilp32_qemu.json
@@ -1,11 +1,6 @@
"includes": [
- "xilinx_zynqmp_base"
- "header-paths-to-import": [
- "rtemslwip/zynqmp_qemu"
+ "xilinx_zynqmp_base",
+ "xilinx_zynqmp_qemu_base"
diff --git a/defs/bsps/aarch64/xilinx_zynqmp_ilp32_zu3eg.json b/defs/bsps/aarch64/xilinx_zynqmp_ilp32_zu3eg.json
index 4438ed2..01d7021 100644
--- a/defs/bsps/aarch64/xilinx_zynqmp_ilp32_zu3eg.json
+++ b/defs/bsps/aarch64/xilinx_zynqmp_ilp32_zu3eg.json
@@ -1,11 +1,6 @@
"includes": [
- "rtemslwip/zynqmp_hardware"
+ "xilinx_zynqmp_hardware_base"
diff --git a/defs/bsps/aarch64/xilinx_zynqmp_lp64_cfc400x.json b/defs/bsps/aarch64/xilinx_zynqmp_lp64_cfc400x.json
index 5fe676c..c4d86e7 100644
--- a/defs/bsps/aarch64/xilinx_zynqmp_lp64_cfc400x.json
+++ b/defs/bsps/aarch64/xilinx_zynqmp_lp64_cfc400x.json
@@ -5,7 +5,7 @@
"rtemslwip/zynqmp_cfc400x"
- "rtemslwip/zynqmp_cfc400x"
+ "rtemslwip/zynqmp_cfc400x/netstart.c"
diff --git a/defs/bsps/aarch64/xilinx_zynqmp_lp64_qemu.json b/defs/bsps/aarch64/xilinx_zynqmp_lp64_qemu.json
--- a/defs/bsps/aarch64/xilinx_zynqmp_lp64_qemu.json
+++ b/defs/bsps/aarch64/xilinx_zynqmp_lp64_qemu.json
@@ -1,11 +1,6 @@
"includes": [
diff --git a/defs/bsps/aarch64/xilinx_zynqmp_lp64_zu3eg.json b/defs/bsps/aarch64/xilinx_zynqmp_lp64_zu3eg.json
--- a/defs/bsps/aarch64/xilinx_zynqmp_lp64_zu3eg.json
+++ b/defs/bsps/aarch64/xilinx_zynqmp_lp64_zu3eg.json
@@ -1,11 +1,6 @@
"includes": [
diff --git a/defs/bsps/aarch64/xilinx_zynqmp_qemu_base.json b/defs/bsps/aarch64/xilinx_zynqmp_qemu_base.json
index 0000000..7bf24b8
--- /dev/null
+++ b/defs/bsps/aarch64/xilinx_zynqmp_qemu_base.json
@@ -0,0 +1,8 @@
+ "rtemslwip/zynqmp_qemu"
+ "rtemslwip/zynqmp_qemu/netstart.c"
diff --git a/defs/bsps/arm/beaglebone_bw_base.json b/defs/bsps/arm/beaglebone_bw_base.json
index 9d25a67..ca474fd 100644
--- a/defs/bsps/arm/beaglebone_bw_base.json
+++ b/defs/bsps/arm/beaglebone_bw_base.json
@@ -3,8 +3,19 @@
"rtemslwip/beaglebone",
"cpsw/src/include"
- "rtemslwip/beaglebone",
- "cpsw/src"
+ "rtemslwip/beaglebone/netstart.c",
+ "cpsw/src/locator.c",
+ "cpsw/src/perf.c",
+ "cpsw/src/delay.c",
+ "cpsw/src/netif/cpsw_bb.c",
+ "cpsw/src/netif/cache.c",
+ "cpsw/src/netif/cpsw.c",
+ "cpsw/src/netif/cpswif.c",
+ "cpsw/src/netif/delay.c",
+ "cpsw/src/netif/phy.c",
+ "cpsw/src/netif/mdio.c",
+ "cpsw/src/netif/mmu.c",
+ "cpsw/src/lwiplib.c"
diff --git a/defs/bsps/arm/tms570_base.json b/defs/bsps/arm/tms570_base.json
index 33cd969..5f1f73e 100644
--- a/defs/bsps/arm/tms570_base.json
+++ b/defs/bsps/arm/tms570_base.json
@@ -3,7 +3,9 @@
"uLan/ports/driver/tms570_emac",
"uLan/ports/os"
- "uLan/ports/driver/tms570_emac"
+ "uLan/ports/driver/tms570_emac/eth_lwip.c",
+ "uLan/ports/driver/tms570_emac/phy_dp83848h.c",
+ "uLan/ports/driver/tms570_emac/tms570_netif.c"
diff --git a/lwip.py b/lwip.py
index bcd898f..bd743a1 100644
--- a/lwip.py
+++ b/lwip.py
@@ -68,9 +68,6 @@ def build(bld):
includes.extend(tmpincl)
if 'source-files-to-import' in files:
sources.extend(files['source-files-to-import'])
- if 'source-paths-to-import' in files:
- for f in files['source-paths-to-import']:
- sources.extend(walk_sources(f))
if 'header-paths-to-import' in files:
includes.extend(files['header-paths-to-import'])
return (sources, includes)
2.30.2
