[lwip 2/2] Move and rename sys_arch_data_sync_barier()
Sebastian Huber
Fri Mar 24 10:21:57 UTC 2023
Hello Pavel,
On 18.03.23 01:04, Pavel Pisa wrote:
> As for
> +static inline void
> +tms570_data_sync_barier(void)
> +#ifdef __arm__
> + _ARM_Data_synchronization_barrier();
> +#endif
> it is OK but may it be not ideal, because more drivers could require
> write buffers and instructions memory access order synchronization.
> We have added that definition to ports/os/rtems/arch/sys_arch.h
> #ifndef __rtems__
> static inline sys_prot_t
> sys_arch_protect(void)
> sys_prot_t pval;
> rtems_interrupt_disable(pval);
> return pval;
> static inline void
> sys_arch_unprotect(sys_prot_t pval)
> rtems_interrupt_enable(pval);
> static inline void
> sys_arch_data_sync_barier(void){
> #else
> as the generic solution when to allow same drivers to be used
> with different architectures. There can be more drivers requiring
> such protection.
ok, I will keep the sys_arch_data_sync_barier(). What I don't understand
is why this stuff is under #ifndef __rtems__ (NOT defined __rtems__).
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
