[lwip 2/2] Move and rename sys_arch_data_sync_barier()
Sebastian Huber
Fri Mar 24 10:43:02 UTC 2023
Hello Pavel,
it seems we have two different MDIO services:
cpsw/src/include/mdio.h:extern unsigned int MDIOPhyRegRead(unsigned int
baseAddr, unsigned int phyAddr,
uLan/ports/driver/tms570_emac/ti_drv_mdio.h:MDIOPhyRegRead(volatile
tms570_mdio_t *baseAddr, uint32_t phyAddr,
I get these warnings currently:
../../uLan/ports/driver/tms570_emac/phy_dp83848h.c: In function 'PHY_reset':
../../uLan/ports/driver/tms570_emac/phy_dp83848h.c:61:19: warning:
passing argument 1 of 'MDIOPhyRegWrite' makes integer from pointer
without a cast [-Wint-conversion]
61 | MDIOPhyRegWrite(mdioBaseAddr, phyAddr, PHY_BMCR, PHY_RESET_m);
| volatile tms570_mdio_t *
In file included from ../../uLan/ports/driver/tms570_emac/phy_dp83848h.c:38:
../../cpsw/src/include/mdio.h:68:42: note: expected 'unsigned int' but
argument is of type 'volatile tms570_mdio_t *'
68 | extern void MDIOPhyRegWrite(unsigned int baseAddr, unsigned int
phyAddr,
../../uLan/ports/driver/tms570_emac/phy_dp83848h.c:62:25: warning:
passing argument 1 of 'MDIOPhyRegRead' makes integer from pointer
62 | while (MDIOPhyRegRead(mdioBaseAddr, phyAddr, PHY_BMCR,
®Content) & PHY_RESET_m);
../../cpsw/src/include/mdio.h:66:49: note: expected 'unsigned int' but
66 | extern unsigned int MDIOPhyRegRead(unsigned int baseAddr,
'PHY_partner_ability_get':
../../uLan/ports/driver/tms570_emac/phy_dp83848h.c:68:26: warning:
68 | return (MDIOPhyRegRead(mdioBaseAddr, phyAddr, PHY_ANLPAR,
regContent));
'PHY_start_auto_negotiate':
../../uLan/ports/driver/tms570_emac/phy_dp83848h.c:77:22: warning:
77 | if (MDIOPhyRegRead(mdioBaseAddr, phyAddr, PHY_BMCR,
®Content) != TRUE) {
../../uLan/ports/driver/tms570_emac/phy_dp83848h.c:81:19: warning:
81 | MDIOPhyRegWrite(mdioBaseAddr, phyAddr, PHY_BMCR, regContent);
/* originally ...HY_BMCR, PHY_RESET_m | PHY_AUTONEG_EN_m); */
phyAddr,
../../uLan/ports/driver/tms570_emac/phy_dp83848h.c:84:22: warning:
84 | if (MDIOPhyRegRead(mdioBaseAddr, phyAddr, PHY_ANAR,
../../uLan/ports/driver/tms570_emac/phy_dp83848h.c:88:19: warning:
88 | MDIOPhyRegWrite(mdioBaseAddr, phyAddr, PHY_ANAR, regContent);
phyAddr,
../../uLan/ports/driver/tms570_emac/phy_dp83848h.c:91:18: warning:
91 | MDIOPhyRegRead(mdioBaseAddr, phyAddr, PHY_BMCR, ®Content);
../../uLan/ports/driver/tms570_emac/phy_dp83848h.c:93:19: warning:
93 | MDIOPhyRegWrite(mdioBaseAddr, phyAddr, PHY_BMCR, regContent);
phyAddr,
'PHY_is_done_auto_negotiate':
../../uLan/ports/driver/tms570_emac/phy_dp83848h.c:103:22: warning:
103 | if (MDIOPhyRegRead(mdioBaseAddr, phyAddr, PHY_BMSR,
'PHY_link_status_get':
../../uLan/ports/driver/tms570_emac/phy_dp83848h.c:130:20: warning:
130 | MDIOPhyRegRead(mdioBaseAddr, phyAddr, PHY_BMSR, &linkStatus);
'PHY_RMII_mode_get':
../../uLan/ports/driver/tms570_emac/phy_dp83848h.c:149:18: warning:
149 | MDIOPhyRegRead(mdioBaseAddr, phyAddr, PHY_RBR, ®Content);
'PHY_MII_mode_set':
../../uLan/ports/driver/tms570_emac/phy_dp83848h.c:159:18: warning:
159 | MDIOPhyRegRead(mdioBaseAddr, phyAddr, PHY_RBR, ®Content);
../../uLan/ports/driver/tms570_emac/phy_dp83848h.c:163:19: warning:
163 | MDIOPhyRegWrite(mdioBaseAddr, phyAddr, PHY_RBR, regContent);
phyAddr,
'PHY_Power_Down':
../../uLan/ports/driver/tms570_emac/phy_dp83848h.c:171:18: warning:
171 | MDIOPhyRegRead(mdioBaseAddr, phyAddr, PHY_BMCR, ®Content);
../../uLan/ports/driver/tms570_emac/phy_dp83848h.c:172:19: warning:
172 | MDIOPhyRegWrite(mdioBaseAddr, phyAddr, PHY_BMCR, regContent |
PHY_POWERDOWN_m);
phyAddr,
'PHY_Power_Up':
../../uLan/ports/driver/tms570_emac/phy_dp83848h.c:180:18: warning:
180 | MDIOPhyRegRead(mdioBaseAddr, phyAddr, PHY_BMCR, ®Content);
../../uLan/ports/driver/tms570_emac/phy_dp83848h.c:181:19: warning:
181 | MDIOPhyRegWrite(mdioBaseAddr, phyAddr, PHY_BMCR, regContent &
~PHY_POWERDOWN_m);
phyAddr,
../../uLan/ports/driver/tms570_emac/tms570_netif.c: In function
'tms570_eth_init_find_PHY':
../../uLan/ports/driver/tms570_emac/tms570_netif.c:304:3: warning:
implicit declaration of function 'MDIOPhyRegRead'
[-Wimplicit-function-declaration]
304 | MDIOPhyRegRead(nf_state->mdio_base, nf_state->phy_addr,
PHY_BMSR, ®Content);
../../uLan/ports/driver/tms570_emac/tms570_netif.c:305:15: warning:
implicit declaration of function 'MDIOPhyAliveStatusGet'
305 | physAlive = MDIOPhyAliveStatusGet(nf_state->mdio_base);
'tms570_eth_init_hw':
../../uLan/ports/driver/tms570_emac/tms570_netif.c:379:3: warning:
implicit declaration of function 'MDIOInit'
379 | MDIOInit(nf_state->mdio_base, 0x0, 0x0);
'tms570_eth_memp_avaible':
../../uLan/ports/driver/tms570_emac/tms570_netif.c:1133:3: warning:
implicit declaration of function 'netifapi_netif_common'
1133 | netifapi_netif_common(eth_lwip_get_netif(0),
tms570_eth_rx_pbuf_refill_single, NULL);
On 18.03.23 01:04, Pavel Pisa wrote:
> Hello Kinsey and Sebastian,
> On Thursday 09 of March 2023 14:46:28 Kinsey Moore wrote:
>> Normally with rtems-lwip I would complain that this doesn't follow the
>> convention of using #ifdef __rtems__ to modify files from upstream sources
>> (each root directory except rtemslwip has an upstream source), but the uLan
>> authors have given permission to fully integrate this code into the
>> rtemslwip directory where possible (the TI code will go into its own
>> directory). This patch looks good.
> driver has no upstream, it has been designed for RTEMS and then
> used even on FreeRTOS and it except for headers from Ti mainly
> used for MDIO, it has been designed from scratch at CTU.
> We have originally started and tried to fix Ti HalCoGen
> code to work with Ti provided FreeRTOS and it newer worked
> reliably. Then we have thrown away all that stuff and started
> from scratch with some inspiration from similar BSD drivers.
> I have call with Premek and we both agree on relicense to RTEMS
> BSD variant. I can prepare commit when I have some while (I am
> loaded by lectures, students support now). Next step is to move
> code to
> rtemslwip/tms570
> As for
> +static inline void
> +tms570_data_sync_barier(void)
> +#ifdef __arm__
> + _ARM_Data_synchronization_barrier();
> +#endif
> it is OK but may it be not ideal, because more drivers could require
> write buffers and instructions memory access order synchronization.
> We have added that definition to ports/os/rtems/arch/sys_arch.h
> #ifndef __rtems__
> static inline sys_prot_t
> sys_arch_protect(void)
> sys_prot_t pval;
> rtems_interrupt_disable(pval);
> return pval;
> static inline void
> sys_arch_unprotect(sys_prot_t pval)
> rtems_interrupt_enable(pval);
> static inline void
> sys_arch_data_sync_barier(void){
> #else
> as the generic solution when to allow same drivers to be used
> with different architectures. There can be more drivers requiring
> such protection.
> In the fact tms570_emac is similar or equivalent to some other
> ETHERNET NICs, I do not remember which one at the moment, I would
> need to search. But I think that I have seen same/similar registers
> organization on other targets.
> If I prepare changes of license, should I sent patches
> only to the mailing list or should I try to create branch
> and try to push it to rtems-lwip or fork some GitHub
> matching repo?
> It seems that my SSH key for ppisa at dispatch.rtems.org has
> expired?
> Best wishes,
> Pavel
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
