[RTEMS-NET-LEGACY PATCH] waf: List all source built and installed
chrisj at rtems.org
chrisj at rtems.org
Mon Mar 27 05:44:55 UTC 2023
- Remove scanning the file system for files to build and install.
- Install list checked against an RTEMS 5.3 networking build.
Closes #4887
bsp_drivers.py | 244 +++++++++++++++++++-----
netlegacy.py | 148 +++++---------
netsources.py | 328 ++++++++++++++++++++++++++++++++
testsuites/ftp01/wscript | 18 +-
testsuites/loopback/wscript | 9 +-
testsuites/networking01/wscript | 9 +-
testsuites/pppd/wscript | 13 +-
testsuites/syscall01/wscript | 9 +-
testsuites/telnetd01/wscript | 17 +-
testsuites/wscript | 6 +-
wscript | 4 +-
11 files changed, 615 insertions(+), 190 deletions(-)
create mode 100644 netsources.py
diff --git a/bsp_drivers.py b/bsp_drivers.py
index 7d07d3d..e2250aa 100644
--- a/bsp_drivers.py
+++ b/bsp_drivers.py
@@ -26,51 +26,201 @@
# (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
# OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
-from rtems_waf import rtems
-import os
-import waflib.Options
-import waflib.ConfigSet
+include = {
+ 'arm/csb336': [
+ 'bsps/arm/csb336/net',
+ 'arm/csb337': [
+ 'bsps/arm/csb337/net',
+ 'arm/edb7312': [
+ 'bsps/arm/edb7312/net',
+ 'arm/gumstix': [
+ 'bsps/arm/gumstix/net',
+ 'arm/rtl22xx': [
+ 'bsps/arm/rtl22xx/net',
+ 'bfin/bf537Stamp': [
+ 'bsps/bfin/bf537Stamp/net',
+ 'i386/pc386': [
+ 'bsps/i386/pc386/net',
+ 'lm32/lm32_evr': [
+ 'bsps/lm32/include',
+ 'bsps/lm32/shared/net',
+ 'm68k/av5282': [
+ 'bsps/m68k/av5282/net',
+ 'm68k/csb360': [
+ 'bsps/m68k/csb360/net',
+ 'm68k/mcf5235': [
+ 'bsps/m68k/mcf5235/net',
+ 'm68k/mcf5329': [
+ 'bsps/m68k/mcf5329/net',
+ 'm68k/mvme167': [
+ 'bsps/m68k/mvme167/net',
+ 'm68k/uC5282': [
+ 'bsps/m68k/uC5282/net',
+ 'mips/csb350': [
+ 'bsps/mips/csb350/net',
+ 'powerpc/beatnik': [
+ 'bsps/powerpc/beatnik/include',
+ 'bsps/powerpc/beatnik/include/bsp',
+ 'bsps/powerpc/beatnik/net',
+ 'bsps/powerpc/beatnik/net/if_em',
+ 'bsps/powerpc/beatnik/net/if_gfe',
+ 'bsps/powerpc/beatnik/net/porting',
+ 'powerpc/mpc8260ads': [
+ 'bsps/powerpc/mpc8260ads/net',
+ 'powerpc/mvme3100': [
+ 'bsps/powerpc/mvme3100/net',
+ 'powerpc/mvme5500': [
+ 'bsps/powerpc/mvme5500/net',
+ 'powerpc/psim': [
+ 'bsps/powerpc/psim/net',
+ 'powerpc/virtex': [
+ 'bsps/powerpc/virtex/net',
+ 'riscv/griscv': [
+ 'bsps/riscv/griscv/net',
+ 'sparc/erc32': [
+ 'bsps/sparc/erc32/net',
+ 'sparc/leon2': [
+ 'bsps/sparc/leon2/net',
+ 'sparc/leon3': [
+ 'bsps/sparc/leon3/net',
-def bsp_files(bld):
- source_files = {}
- include_dirs = {}
- include_files = []
- special_case_dirs = {'atsamv': os.path.expanduser('bsps/arm/atsam'),
- 'lm32_evr': os.path.expanduser('bsps/lm32'),
- 'lpc24xx_ea': os.path.expanduser('bsps/arm/shared/')}
- special_case_sources = {'leon2':
- [os.path.expanduser('bsps/shared/grlib/net/network_interface_add.c'),
- os.path.expanduser('bsps/shared/grlib/net/greth.c')],
- 'leon3':
- 'griscv':
- os.path.expanduser('bsps/shared/grlib/net/greth.c')]}
- bsp_list = bld.env.RTEMS_ARCH_BSP_LIST
- for bl in bsp_list:
- bsp = bl.split('-')[-1]
- arch = bl.split('-')[0]
- include_dirs[bsp] = []
- source_files[bsp] = []
- if bsp not in special_case_dirs:
- source_dir = os.walk(os.path.join('bsps', arch, bsp))
- else:
- source_dir = os.walk(special_case_dirs[bsp])
- for root, dirs, files in source_dir:
- for name in files:
- ext = os.path.splitext(name)[1]
- if ext == '.c':
- source_files[bsp].append(os.path.join(root, name))
- if ext == '.h':
- if root not in include_dirs[bsp]:
- include_dirs[bsp].append(root)
- if bsp in special_case_sources:
- source_files[bsp].extend(special_case_sources[bsp])
- include_dirs[bsp].append(os.path.join('bsps', arch, bsp, 'net'))
- include_dirs[bsp].append(os.path.join('bsps', arch, bsp, 'include'))
- return (include_dirs, source_files)
+source = {
+ 'arm/atsamv': [
+ 'bsps/arm/atsam/if_atsam.c',
+ 'arm/csb336': [
+ 'bsps/arm/csb336/net/lan91c11x.c',
+ 'bsps/arm/csb336/net/network.c',
+ 'arm/csb337': [
+ 'bsps/arm/csb337/net/network.c',
+ 'arm/edb7312': [
+ 'bsps/arm/edb7312/net/network.c',
+ 'arm/gumstix': [
+ 'bsps/arm/gumstix/net/rtl8019.c',
+ 'arm/lpc24xx_ea': [
+ 'bsps/arm/shared/lpc-ethernet.c',
+ 'arm/rtl22xx': [
+ 'bsps/arm/rtl22xx/net/network.c',
+ 'bsps/bfin/bf537Stamp/net/ethernet.c',
+ 'bsps/bfin/bf537Stamp/net/networkconfig.c',
+ 'i386/pc386': [
+ 'bsps/i386/pc386/net/3c509.c',
+ 'bsps/i386/pc386/net/elink.c',
+ 'bsps/i386/pc386/net/ne2000.c',
+ 'bsps/i386/pc386/net/wd8003.c',
+ 'bsps/lm32/shared/net/network.c',
+ 'bsps/lm32/shared/net/tsmac.c',
+ 'm68k/av5282': [
+ 'bsps/m68k/av5282/net/network.c',
+ 'm68k/csb360': [
+ 'bsps/m68k/csb360/net/network.c',
+ 'm68k/mcf5235': [
+ 'bsps/m68k/mcf5235/net/network.c',
+ 'm68k/mcf5329': [
+ 'bsps/m68k/mcf5329/net/network.c',
+ 'm68k/mvme167': [
+ 'bsps/m68k/mvme167/net/network.c',
+ 'm68k/uC5282': [
+ 'bsps/m68k/uC5282/net/network.c',
+ 'mips/csb350': [
+ 'bsps/mips/csb350/net/network.c',
+ 'bsps/powerpc/beatnik/net/if_em/if_em.c',
+ 'bsps/powerpc/beatnik/net/if_em/if_em_hw.c',
+ 'bsps/powerpc/beatnik/net/if_em/if_em_rtems.c',
+ 'bsps/powerpc/beatnik/net/if_gfe/if_gfe.c',
+ 'bsps/powerpc/beatnik/net/if_gfe/if_gfe_rtems.c',
+ 'bsps/powerpc/beatnik/net/porting/if_xxx_rtems.c',
+ 'bsps/powerpc/beatnik/net/support/bsp_attach.c',
+ 'bsps/powerpc/beatnik/net/support/early_link_status.c',
+ 'bsps/powerpc/mpc8260ads/net/if_hdlcsubr.c',
+ 'bsps/powerpc/mpc8260ads/net/network.c',
+ 'bsps/powerpc/mvme3100/net/tsec.c',
+ 'bsps/powerpc/mvme5500/net/if_100MHz/GT64260eth.c',
+ 'bsps/powerpc/mvme5500/net/if_1GHz/if_wm.c',
+ 'bsps/powerpc/mvme5500/net/if_1GHz/pci_map.c',
+ 'powerpc/psim': [
+ 'bsps/powerpc/psim/net/if_sim.c',
+ 'bsps/powerpc/virtex/net/xiltemac.c',
+ 'riscv/griscv': [
+ 'bsps/riscv/griscv/net/griscv_greth.c',
+ 'bsps/shared/grlib/net/greth.c',
+ 'bsps/shared/grlib/net/network_interface_add.c',
+ 'sparc/erc32': [
+ 'bsps/sparc/erc32/net/erc32sonic.c',
+ 'sparc/leon2': [
+ 'bsps/sparc/leon2/net/leon_open_eth.c',
+ 'bsps/sparc/leon2/net/leon_smc91111.c',
+ 'sparc/leon3': [
+ 'bsps/sparc/leon3/net/leon_greth.c',
+ 'bsps/sparc/leon3/net/leon_open_eth.c',
+ 'bsps/sparc/leon3/net/leon_smc91111.c',
diff --git a/netlegacy.py b/netlegacy.py
index b08ccad..8445a26 100644
--- a/netlegacy.py
+++ b/netlegacy.py
@@ -26,39 +26,13 @@
-import bsp_drivers
import os
+import os.path
-source_files = []
-include_files = {}
-exclude_dirs = [
- 'pppd', 'nfsclient', 'testsuites',
- os.path.join('librpc', 'include'), 'bsps'
-exclude_headers = ['rtems-bsd-user-space.h', 'rtems-bsd-kernel-space.h']
-for root, dirs, files in os.walk("."):
- [dirs.remove(d) for d in list(dirs) if d in exclude_dirs]
- dirs.append(os.path.join('bsps', 'shared', 'net'))
- include_files[root[2:]] = []
- if ext == '.c':
- source_files.append(os.path.join(root, name))
- if ext == '.h' and name not in exclude_headers:
- include_files[root[2:]].append(os.path.join(root, name))
-def find_node(bld, *paths):
- path = os.path.join(*paths)
- return os.path.relpath(str(bld.path.find_node(path)))
+from rtems_waf import rtems
-def install_file_list(*paths):
- file_list = [os.path.join(path, f) for f in os.listdir(path)]
- return file_list
+import bsp_drivers
+import netsources
def options(opt):
@@ -66,91 +40,65 @@ def options(opt):
def bsp_configure(conf, arch_bsp, mandatory=True):
- pass
-def build(bld):
- include_path = []
- ip = ''
- bsp = bld.env.RTEMS_ARCH_BSP.split('-')[-1]
- pppd_source = [
- os.path.join('pppd', s) for s in os.listdir('pppd')
- if os.path.splitext(s)[1] == '.c'
+ ab = rtems.arch(arch_bsp) + '/' + rtems.bsp(arch_bsp)
+ includes = [
+ 'include',
+ 'bsps/include',
+ 'testsuites/include',
- nfs_source = []
- for root, dirs, files in os.walk('nfsclient'):
- if ext == '.c':
- src_root = os.path.split(root)
- nfs_source.append(os.path.join(src_root[0], src_root[1], name))
- bsp_dirs, bsp_sources = bsp_drivers.bsp_files(bld)
- include_path.extend([
- '.', 'include',
- os.path.relpath(bld.env.PREFIX),
- os.path.join('testsuites', 'include'),
- os.path.relpath(os.path.join(bld.env.PREFIX, 'include')),
- os.path.join('bsps', 'include')
- arch_lib_path = rtems.arch_bsp_lib_path(bld.env.RTEMS_VERSION,
- bld.env.RTEMS_ARCH_BSP)
- lib_path = os.path.join(bld.env.PREFIX, arch_lib_path)
- include_path.append(
- os.path.relpath(os.path.join(bld.env.PREFIX, arch_lib_path)))
- os.path.relpath(os.path.join(bld.env.PREFIX, arch_lib_path,
- 'include')))
- include_path.append(find_node(bld, 'bsps', 'include', 'libchip'))
- bld.read_stlib('rtemsbsp', paths=[lib_path])
+ if ab in bsp_drivers.include:
+ includes += bsp_drivers.include[ab]
+ conf.env.IFLAGS = [str(conf.path.find_node(i))
+ for i in includes] + conf.env.IFLAGS
+ conf.env.OPTIMIZATION = ['-O2']
- if bsp in bsp_dirs:
- include_path.extend(bsp_dirs[bsp])
- for i in include_path:
- ip = ip + i + ' '
+def build(bld):
+ arch_bsp = bld.env.RTEMS_ARCH_BSP
- if (bsp in bsp_sources):
- bld(target='bsp_objs',
+ if ab in bsp_drivers.source:
+ print(bsp_drivers.source[ab])
+ bld(target='bspobjs',
features='c',
- cflags=['-O2', '-g'],
- includes=ip,
- source=bsp_sources[bsp])
+ cflags=bld.env.OPTIMIZATION + ['-g'],
+ includes=bld.env.IFLAGS,
+ source=bsp_drivers.source[ab])
- bld(target='network_objects',
+ bld(target='netobjs',
features='c',
- includes=ip,
defines=['IN_HISTORICAL_NETS=1'],
- source=source_files)
+ source=netsources.source.network)
- bld(target='networking',
- features='c cstlib',
- use=['bsp_objs', 'network_objects'])
+ bld(target='networking', features='c cstlib', use=['bspobjs', 'netobjs'])
bld.stlib(target='pppd',
features='c',
- includes=ip,
- use='networking',
- source=pppd_source)
+ use=['networking'],
+ source=netsources.source.pppd)
bld.stlib(target='nfs',
features='c',
- includes=ip,
- use=['rtemsbsp', 'networking'],
- source=nfs_source)
+ source=netsources.source.nfsclient)
+ arch_lib_path = rtems.arch_bsp_lib_path(bld.env.RTEMS_VERSION,
+ bld.env.RTEMS_ARCH_BSP)
+ arch_inc_path = rtems.arch_bsp_include_path(bld.env.RTEMS_VERSION,
bld.install_files(os.path.join(bld.env.PREFIX, arch_lib_path),
["libnetworking.a", 'libpppd.a', 'libnfs.a'])
- bld.install_files(
- os.path.join(bld.env.PREFIX, arch_lib_path, 'include', 'libchip'),
- install_file_list('bsps', 'include', 'libchip'))
- for i in include_files:
- if 'include' in os.path.split(i):
- bld.install_files(os.path.join(bld.env.PREFIX, arch_lib_path, i),
- include_files[i])
- else:
- os.path.join(bld.env.PREFIX, arch_lib_path, 'include', i),
- include_files[i])
+ for inc_dir in netsources.header:
+ for header in netsources.header[inc_dir]:
+ hname = os.path.basename(header)
+ bld.install_as(
+ os.path.join(bld.env.PREFIX, arch_inc_path, inc_dir, hname),
+ header)
diff --git a/netsources.py b/netsources.py
new file mode 100644
index 0000000..be9334d
--- /dev/null
+++ b/netsources.py
@@ -0,0 +1,328 @@
+# RTEMS Project (https://www.rtems.org/)
+# Copyright (c) 2023 Chris Johns <chrisj at rtems.org>.
+# All rights reserved.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions
+# are met:
+# 1. Redistributions of source code must retain the above copyright
+# notice, this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright
+# notice, this list of conditions and the following disclaimer in the
+# documentation and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+# "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+# LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
+# A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
+# OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+# SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
+# LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
+# DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
+# THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
+# (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
+# OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+class source:
+ network = [
+ # rtems
+ 'rtems/mkrootfs.c',
+ 'rtems/rtems_bootp.c',
+ 'rtems/rtems_bsdnet_malloc_starvation.c',
+ 'rtems/rtems_dhcp.c',
+ 'rtems/rtems_dhcp_failsafe.c',
+ 'rtems/rtems_glue.c',
+ 'rtems/rtems_malloc_mbuf.c',
+ 'rtems/rtems_mii_ioctl.c',
+ 'rtems/rtems_mii_ioctl_kern.c',
+ 'rtems/rtems_select.c',
+ 'rtems/rtems_showicmpstat.c',
+ 'rtems/rtems_showifstat.c',
+ 'rtems/rtems_showipstat.c',
+ 'rtems/rtems_showmbuf.c',
+ 'rtems/rtems_showroute.c',
+ 'rtems/rtems_showtcpstat.c',
+ 'rtems/rtems_showudpstat.c',
+ 'rtems/rtems_socketpair.c',
+ 'rtems/rtems_syscall.c',
+ 'rtems/rtems_syscall_api.c',
+ 'rtems/sghostname.c',
+ # kernel
+ 'kern/kern_mib.c',
+ 'kern/kern_subr.c',
+ 'kern/kern_sysctl.c',
+ 'kern/uipc_domain.c',
+ 'kern/uipc_mbuf.c',
+ 'kern/uipc_socket.c',
+ 'kern/uipc_socket2.c',
+ # bsps
+ 'bsps/shared/net/cs8900.c',
+ 'bsps/shared/net/dec21140.c',
+ 'bsps/shared/net/elnk.c',
+ 'bsps/shared/net/greth2.c',
+ 'bsps/shared/net/i82586.c',
+ 'bsps/shared/net/if_dc.c',
+ 'bsps/shared/net/if_fxp.c',
+ 'bsps/shared/net/open_eth.c',
+ 'bsps/shared/net/smc91111.c',
+ 'bsps/shared/net/sonic.c',
+ # net
+ 'net/if.c',
+ 'net/if_ethersubr.c',
+ 'net/if_loop.c',
+ 'net/if_ppp.c',
+ 'net/ppp_tty.c',
+ 'net/radix.c',
+ 'net/raw_cb.c',
+ 'net/raw_usrreq.c',
+ 'net/route.c',
+ 'net/rtsock.c',
+ 'net/slcompress.c',
+ # netinet
+ 'netinet/if_ether.c',
+ 'netinet/igmp.c',
+ 'netinet/in.c',
+ 'netinet/in_cksum.c',
+ 'netinet/in_pcb.c',
+ 'netinet/in_proto.c',
+ 'netinet/in_rmx.c',
+ 'netinet/ip_divert.c',
+ 'netinet/ip_fw.c',
+ 'netinet/ip_icmp.c',
+ 'netinet/ip_input.c',
+ 'netinet/ip_mroute.c',
+ 'netinet/ip_output.c',
+ 'netinet/raw_ip.c',
+ 'netinet/tcp_debug.c',
+ 'netinet/tcp_input.c',
+ 'netinet/tcp_output.c',
+ 'netinet/tcp_subr.c',
+ 'netinet/tcp_timer.c',
+ 'netinet/tcp_usrreq.c',
+ 'netinet/udp_usrreq.c',
+ # nfs
+ 'nfs/bootp_subr.c',
+ # rpc
+ 'librpc/src/rpc/auth_none.c',
+ 'librpc/src/rpc/auth_unix.c',
+ 'librpc/src/rpc/authunix_prot.c',
+ 'librpc/src/rpc/bindresvport.c',
+ 'librpc/src/rpc/clnt_generic.c',
+ 'librpc/src/rpc/clnt_perror.c',
+ 'librpc/src/rpc/clnt_raw.c',
+ 'librpc/src/rpc/clnt_simple.c',
+ 'librpc/src/rpc/clnt_tcp.c',
+ 'librpc/src/rpc/clnt_udp.c',
+ 'librpc/src/rpc/get_myaddress.c',
+ 'librpc/src/rpc/getrpcent.c',
+ 'librpc/src/rpc/getrpcport.c',
+ 'librpc/src/rpc/netname.c',
+ 'librpc/src/rpc/netnamer.c',
+ 'librpc/src/rpc/pmap_clnt.c',
+ 'librpc/src/rpc/pmap_getmaps.c',
+ 'librpc/src/rpc/pmap_getport.c',
+ 'librpc/src/rpc/pmap_prot.c',
+ 'librpc/src/rpc/pmap_prot2.c',
+ 'librpc/src/rpc/pmap_rmt.c',
+ 'librpc/src/rpc/rpc_callmsg.c',
+ 'librpc/src/rpc/rpc_commondata.c',
+ 'librpc/src/rpc/rpc_dtablesize.c',
+ 'librpc/src/rpc/rpc_prot.c',
+ 'librpc/src/rpc/rpcdname.c',
+ 'librpc/src/rpc/rtems_portmapper.c',
+ 'librpc/src/rpc/rtems_rpc.c',
+ 'librpc/src/rpc/rtime.c',
+ 'librpc/src/rpc/svc.c',
+ 'librpc/src/rpc/svc_auth.c',
+ 'librpc/src/rpc/svc_auth_unix.c',
+ 'librpc/src/rpc/svc_raw.c',
+ 'librpc/src/rpc/svc_run.c',
+ 'librpc/src/rpc/svc_simple.c',
+ 'librpc/src/rpc/svc_tcp.c',
+ 'librpc/src/rpc/svc_udp.c',
+ 'librpc/src/xdr/xdr.c',
+ 'librpc/src/xdr/xdr_array.c',
+ 'librpc/src/xdr/xdr_float.c',
+ 'librpc/src/xdr/xdr_mem.c',
+ 'librpc/src/xdr/xdr_rec.c',
+ 'librpc/src/xdr/xdr_reference.c',
+ 'librpc/src/xdr/xdr_sizeof.c',
+ 'librpc/src/xdr/xdr_stdio.c',
+ # misc
+ 'libmisc/dummy-networking.c',
+ 'libmisc/err.c',
+ 'libmisc/main_ifconfig.c',
+ 'libmisc/main_netstats.c',
+ 'libmisc/main_ping.c',
+ 'libmisc/main_route.c',
+ 'libmisc/mon-network.c',
+ # lib
+ 'lib/getprotoby.c',
+ 'lib/rtems_bsdnet_ntp.c',
+ 'lib/syslog.c',
+ # libc
+ 'libc/base64.c',
+ 'libc/gethostbydns.c',
+ 'libc/gethostbyht.c',
+ 'libc/gethostbynis.c',
+ 'libc/gethostnamadr.c',
+ 'libc/getifaddrs.c',
+ 'libc/getnameinfo.c',
+ 'libc/getnetbydns.c',
+ 'libc/getnetbyht.c',
+ 'libc/getnetbynis.c',
+ 'libc/getnetnamadr.c',
+ 'libc/getproto.c',
+ 'libc/getprotoent.c',
+ 'libc/getprotoname.c',
+ 'libc/getservbyname.c',
+ 'libc/getservbyport.c',
+ 'libc/getservent.c',
+ 'libc/herror.c',
+ 'libc/if_indextoname.c',
+ 'libc/if_nameindex.c',
+ 'libc/inet_addr.c',
+ 'libc/inet_lnaof.c',
+ 'libc/inet_makeaddr.c',
+ 'libc/inet_netof.c',
+ 'libc/inet_network.c',
+ 'libc/inet_ntoa.c',
+ 'libc/inet_ntop.c',
+ 'libc/inet_pton.c',
+ 'libc/linkaddr.c',
+ 'libc/map_v4v6.c',
+ 'libc/ns_name.c',
+ 'libc/ns_netint.c',
+ 'libc/ns_parse.c',
+ 'libc/ns_print.c',
+ 'libc/ns_ttl.c',
+ 'libc/nsap_addr.c',
+ 'libc/rcmd.c',
+ 'libc/recv.c',
+ 'libc/res_comp.c',
+ 'libc/res_data.c',
+ 'libc/res_debug.c',
+ 'libc/res_init.c',
+ 'libc/res_mkquery.c',
+ 'libc/res_mkupdate.c',
+ 'libc/res_query.c',
+ 'libc/res_send.c',
+ 'libc/res_stubs.c',
+ 'libc/res_update.c',
+ 'libc/send.c',
+ # libtest
+ 'libtest/testbeginend.c',
+ 'libtest/testbusy.c',
+ 'libtest/testextension.c',
+ 'libtest/testparallel.c',
+ 'libtest/testrun.c',
+ 'libtest/testwrappers.c',
+ nfsclient = [
+ 'pppd/auth.c',
+ 'pppd/ccp.c',
+ 'pppd/chap.c',
+ 'pppd/chap_ms.c',
+ 'pppd/chat.c',
+ 'pppd/demand.c',
+ 'pppd/fsm.c',
+ 'pppd/ipcp.c',
+ 'pppd/lcp.c',
+ 'pppd/magic.c',
+ 'pppd/options.c',
+ 'pppd/rtemsmain.c',
+ 'pppd/rtemspppd.c',
+ 'pppd/sys-rtems.c',
+ 'pppd/upap.c',
+ 'pppd/utils.c',
+ pppd = [
+ 'pppd/auth.c',
+ 'pppd/ccp.c',
+ 'pppd/chap.c',
+ 'pppd/chap_ms.c',
+ 'pppd/chat.c',
+ 'pppd/demand.c',
+ 'pppd/fsm.c',
+ 'pppd/ipcp.c',
+ 'pppd/lcp.c',
+ 'pppd/magic.c',
+ 'pppd/options.c',
+ 'pppd/upap.c',
+ 'pppd/utils.c',
+header = {
+ '.': ['ifaddrs.h', 'librtemsNfs.h', 'loop.h', 'resolv.h'],
+ 'arpa': ['arpa/nameser.h', 'arpa/nameser_compat.h'],
+ 'dev/mii': ['dev/mii/mii.h'],
+ 'libchip': [
+ 'bsps/include/libchip/cs8900.h',
+ 'bsps/include/libchip/greth.h',
+ 'bsps/include/libchip/i82586var.h',
+ 'bsps/include/libchip/if_dcreg.h',
+ 'bsps/include/libchip/if_fxpvar.h',
+ 'bsps/include/libchip/open_eth.h',
+ 'bsps/include/libchip/smc91111.h',
+ 'bsps/include/libchip/smc91111exp.h',
+ 'bsps/include/libchip/sonic.h',
+ 'machine': [
+ 'machine/_align.h', 'machine/_kernel_if.h', 'machine/_kernel_lock.h',
+ 'machine/_kernel_socket.h', 'machine/cpu.h', 'machine/cpufunc.h',
+ 'machine/in_cksum.h', 'machine/limits.h', 'machine/vmparam.h'
+ 'net': [
+ 'net/bpf.h', 'net/ethernet.h', 'net/if_arp.h', 'net/if_dl.h',
+ 'net/if_llc.h', 'net/if_media.h', 'net/if_ppp.h', 'net/if_pppvar.h',
+ 'net/if_types.h', 'net/if_var.h', 'net/netisr.h', 'net/ppp_comp.h',
+ 'net/ppp_defs.h', 'net/radix.h', 'net/raw_cb.h', 'net/route.h',
+ 'net/slcompress.h'
+ 'netinet': [
+ 'netinet/icmp_var.h', 'netinet/if_ether.h', 'netinet/igmp.h',
+ 'netinet/igmp_var.h', 'netinet/in_pcb.h', 'netinet/in_systm.h',
+ 'netinet/in_var.h', 'netinet/ip.h', 'netinet/ip_fw.h',
+ 'netinet/ip_icmp.h', 'netinet/ip_mroute.h', 'netinet/ip_var.h',
+ 'netinet/tcp_debug.h', 'netinet/tcp_fsm.h', 'netinet/tcp_seq.h',
+ 'netinet/tcp_timer.h', 'netinet/tcp_var.h', 'netinet/tcpip.h',
+ 'netinet/udp.h', 'netinet/udp_var.h'
+ 'nfs': ['nfs/nfsproto.h', 'nfs/rpcv2.h', 'nfs/xdr_subs.h'],
+ 'nfsclient': [
+ 'nfsclient/nfsargs.h',
+ 'nfsclient/nfsdiskless.h',
+ 'rpc': [
+ 'rpc/auth.h', 'rpc/auth_unix.h', 'rpc/clnt.h', 'rpc/clnt_soc.h',
+ 'rpc/clnt_stat.h', 'rpc/pmap_clnt.h', 'rpc/pmap_prot.h',
+ 'rpc/pmap_rmt.h', 'rpc/rpc.h', 'rpc/rpc_com.h', 'rpc/rpc_msg.h',
+ 'rpc/rpcent.h', 'rpc/svc.h', 'rpc/svc_auth.h', 'rpc/svc_soc.h',
+ 'rpc/types.h', 'rpc/xdr.h'
+ 'rtems': [
+ 'include/rtems/rtemspppd.h', 'rtems/bootp.h', 'rtems/dhcp.h',
+ 'rtems/mkrootfs.h', 'rtems/rtems_bsdnet.h',
+ 'rtems/rtems_bsdnet_internal.h', 'rtems/rtems_dhcp_failsafe.h',
+ 'rtems/rtems_mii_ioctl.h', 'rtems/rtems_netdb.h',
+ 'rtems/rtems_netinet_in.h', 'rtems/rtems_syscall.h'
+ 'rtems/bsdnet': ['rtems/bsdnet/_types.h', 'rtems/bsdnet/servers.h'],
+ 'sys': [
+ 'sys/callout.h', 'sys/conf.h', 'sys/domain.h', 'sys/kernel.h',
+ 'sys/libkern.h', 'sys/linker_set.h', 'sys/malloc.h', 'sys/mbuf.h',
+ 'sys/mount.h', 'sys/proc.h', 'sys/protosw.h', 'sys/reboot.h',
+ 'sys/resourcevar.h', 'sys/selinfo.h', 'sys/signalvar.h',
+ 'sys/socketvar.h', 'sys/sysctl.h', 'sys/systm.h', 'sys/ucred.h'
+ 'vm': ['vm/vm.h', 'vm/vm_extern.h', 'vm/vm_kern.h', 'vm/vm_param.h'],
diff --git a/testsuites/ftp01/wscript b/testsuites/ftp01/wscript
index 200138e..550b0b5 100644
--- a/testsuites/ftp01/wscript
+++ b/testsuites/ftp01/wscript
@@ -27,7 +27,6 @@
-import os
def init(ctx):
@@ -39,15 +38,12 @@ def configure(conf):
def build(bld):
- bld.read_stlib('ftpfs', paths=[lib_path])
- bld.read_stlib('ftpd', paths=[lib_path])
+ source = ['init.c']
bld.program(target='ftp01.exe',
features='c cprogram',
- includes='. .. ../include ../../',
- use=['ftpfs', 'ftpd', 'networking'],
- source='init.c')
+ lib=['ftpfs', 'ftpd', 'networking'],
+ libpath=['.'],
+ source=source,
+ install_path=False)
diff --git a/testsuites/loopback/wscript b/testsuites/loopback/wscript
index 8ba0443..bc7bd9a 100644
--- a/testsuites/loopback/wscript
+++ b/testsuites/loopback/wscript
@@ -27,7 +27,6 @@
-import os
def init(ctx):
@@ -39,9 +38,11 @@ def configure(conf):
def build(bld):
bld.program(target='loopback.exe',
use=['networking'],
- source='init.c')
+ source=source,
diff --git a/testsuites/networking01/wscript b/testsuites/networking01/wscript
index f91a5f8..d9917ff 100644
--- a/testsuites/networking01/wscript
+++ b/testsuites/networking01/wscript
@@ -27,7 +27,6 @@
-import os
def init(ctx):
def build(bld):
bld.program(target='networking01.exe',
use=['networking'],
- source='init.c')
+ source=source,
diff --git a/testsuites/pppd/wscript b/testsuites/pppd/wscript
index cd57444..a99cf5e 100644
--- a/testsuites/pppd/wscript
+++ b/testsuites/pppd/wscript
@@ -27,7 +27,6 @@
-import os
def init(ctx):
@@ -39,10 +38,12 @@ def configure(conf):
def build(bld):
+ source = ['init.c', 'pppdapp.c']
bld(target='pppd.exe',
- includes='. .. ../../include ../include ../../',
- use=['pppd', 'networking'],
- libpath=['.', '../../build'],
- source=['init.c', 'pppdapp.c'])
+ lib=['pppd', 'networking'],
+ libpath=['.'],
+ source=source,
diff --git a/testsuites/syscall01/wscript b/testsuites/syscall01/wscript
index 5ad2e19..c8fd30b 100644
--- a/testsuites/syscall01/wscript
+++ b/testsuites/syscall01/wscript
@@ -27,7 +27,6 @@
-import os
def init(ctx):
def build(bld):
bld.program(target='syscall01.exe',
use=['networking'],
- source='init.c')
+ source=source,
diff --git a/testsuites/telnetd01/wscript b/testsuites/telnetd01/wscript
index f24f2ad..fe8a447 100644
--- a/testsuites/telnetd01/wscript
+++ b/testsuites/telnetd01/wscript
@@ -27,7 +27,6 @@
-import os
def init(ctx):
@@ -39,14 +38,12 @@ def configure(conf):
def build(bld):
- bld.read_stlib('telnetd', paths=[lib_path])
bld.program(target='telnetd01.exe',
- includes='. .. ../include ../../ ../../include',
- use=['telnetd', 'networking'],
- source='init.c')
+ lib=['telnetd', 'networking'],
+ libpath=['.'],
+ source=source,
diff --git a/testsuites/wscript b/testsuites/wscript
index 5145e92..040c5c6 100644
--- a/testsuites/wscript
+++ b/testsuites/wscript
@@ -28,9 +28,9 @@
-subdirs = ['ftp01', 'loopback',
- 'networking01', 'pppd',
- 'syscall01', 'telnetd01']
+subdirs = [
+ 'ftp01', 'loopback', 'networking01', 'pppd', 'syscall01', 'telnetd01'
def recurse(ctx):
diff --git a/wscript b/wscript
index 5492b51..b146db6 100644
--- a/wscript
+++ b/wscript
@@ -31,6 +31,7 @@ from rtems_waf import rtems
import netlegacy
import sys
top = '.'
rtems_version = "6"
@@ -71,6 +72,7 @@ def recurse(ctx):
def build(bld):
- netlegacy.build(bld)
rtems.build(bld)
+ netlegacy.build(bld)
+ bld.add_group()
recurse(bld)
2.37.1
