[PATCH] Add support for ELF notes
Tue Mar 28 07:20:42 UTC 2023
On 28.03.23 09:03, Chris Johns wrote:
> On 28/3/2023 5:48 pm, Sebastian Huber wrote:
>> On 25.03.23 00:39, Chris Johns wrote:
>>> On 24/3/2023 7:32 pm, Sebastian Huber wrote:
>>>> On 23.03.23 20:07, Chris Johns wrote:
>>>>> On 24/3/2023 3:57 am, Sebastian Huber wrote:
>>>>>> On 23.03.23 17:52, Will wrote:
>>>>>>> Great idea to store this information in the executable itself. Does this need
>>>>>>> a RTEMS_TEST_STATE_LINK_ONLY test state or something similar for minimum.exe?
>>>>>> With the notes you can build the test. The test runner would look at the notes
>>>>>> and then decide if it makes sense to run the test or not. It could still
>>>>>> run the
>>>>>> minimum.exe and see if it terminates.
>>>>> I welcome notes support. Thanks for adding it.
>>>>> How will we control and manage the notes we support?
>>>> In the new elfnote.h header file there are defines for the note type
>>>> (domain-specific integer).
>>> Great.
>>>>> Should we document the top level notes domains (?) with some we control and
>>>>> restrict and others users can use? For example `note.rtems.test`,
>>>>> `note.rtems.kernel`, `note.rtems.bsp`, and `note.rtems.user`?
>>>> The section name doesn't matter. You can divide the number space of the note
>>>> type for this.
>>> Does this mean we define the numbers or number ranges or is it left open? I am
>>> not sure I am following this bit.
>> The patch has this:
>> #define ELF_NOTE_RTEMS_TYPE( _index ) ( ( _index ) + 0x10000 )
>> We basically have 32-bits available. We could also use something like this:
>> #define ELF_NOTE_RTEMS_BASE_TYPE( _index ) ( ( _index ) + 0x10000000 )
>> #define ELF_NOTE_RTEMS_TEST_TYPE( _index ) ( ( _index ) + 0x20000000 )
>> #define ELF_NOTE_RTEMS_USER_TYPE( _index ) ( ( _index ) + 0x30000000 )
> Nice.
Maybe we should also encode the data type here, for example:
#define ELF_NOTE_DATA_TYPE_BOOL 0
#define ELF_NOTE_DATA_TYPE_INT8 1
#define ELF_NOTE_DATA_TYPE_UINT8 2
#define ELF_NOTE_DATA_TYPE_INT16 3
#define ELF_NOTE_DATA_TYPE_UINT16 4
#define ELF_NOTE_DATA_TYPE_INT32 5
#define ELF_NOTE_DATA_TYPE_UINT32 6
#define ELF_NOTE_DATA_TYPE_INT64 7
#define ELF_NOTE_DATA_TYPE_UINT64 8
#define ELF_NOTE_DATA_TYPE_FLOAT32 9
#define ELF_NOTE_DATA_TYPE_FLOAT32 10
#define ELF_NOTE_DATA_TYPE_FLOAT64 11
#define ELF_NOTE_DATA_TYPE_FLOAT64 12
#define ELF_NOTE_DATA_TYPE_STRING 13
#define ELF_NOTE_DATA_TYPE_BINARY 14
#define ELF_NOTE_RTEMS_BASE_TYPE( _data_type, _index ) \
   ( ( ( _data_type ) << 28 ) | ( ( _index ) + 0x1000000 ) )
This could be used by the host tool to more easily produce the right
JSON data.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
