[PATCH 1/1] bsp-howto: Fix grammar and improve coherence.
Utkarsh Verma utkarsh at bitbanged.com
Wed Mar 29 00:38:45 UTC 2023
 user/start/app.rst       |  2 +-
 user/start/bsp-build.rst | 17 +++++------------
 2 files changed, 6 insertions(+), 13 deletions(-)
diff --git a/user/start/app.rst b/user/start/app.rst
index ce9a44d..0599305 100644
--- a/user/start/app.rst
+++ b/user/start/app.rst
@@ -209,7 +209,7 @@ Run the executable:
 .. code-block:: none
-    $HOME/quick-start/rtems/@rtems-ver-major@/bin/rtems-run --rtems-bsps=erc32-sis build/sparc-rtems at rtems-ver-major@-erc32/hello.exe
+    rtems-run --rtems-bsps=erc32-sis build/sparc-rtems at rtems-ver-major@-erc32/hello.exe
 The output will be something close to:
diff --git a/user/start/bsp-build.rst b/user/start/bsp-build.rst
index 8401d71..585d009 100644
--- a/user/start/bsp-build.rst
+++ b/user/start/bsp-build.rst
@@ -99,16 +99,9 @@ If you have built a BSP with the RSB, you can move on to
 Manual BSP Build
-We manually build the BSP in four steps.  The first step is to create a build
-directory.  It must be separate from the RTEMS source directory.  We use
-:file:`$HOME/quick-start/build/b-erc32`.
-.. code-block:: none
-    mkdir -p $HOME/quick-start/build/b-erc32
-The second step is to set your path. Prepend the RTEMS tool suite binary
-directory to your ``$PATH`` throughout the remaining steps. Run the command:
+We manually build the BSP in four steps. The first step is to set your path.
+Prepend the RTEMS tool suite binary directory to your ``$PATH`` throughout the
+remaining steps. Run the command:
@@ -133,7 +126,7 @@ has not been correctly set. Check the contents of the path
 file cannot be found return to :ref:`QuickStartTools` and install the tools
 again.
-The first step is to configure the BSP.  There are various BSP build
+The second step is to configure the BSP.  There are various BSP build
 configuration options available.  Some options are BSP-specific.  Each section
 in the INI-style configuration file ``config.ini`` instructs the build system to
 build a particular BSP variant (`sparc/erc32` in our case).  We enable the build
@@ -179,7 +172,7 @@ by ``$BASE``.
     Checking for program 'xz'                : $BASE/anaconda3/bin/xz
     'configure' finished successfully (0.414s)
-Building the BSP is the second step.
+Building the BSP is the third step.
2.40.0
