[PATCH 2/3] bsps/microblaze: Add support for multiple UARTs
Chris Johns
chrisj at rtems.org
Thu Mar 30 04:04:03 UTC 2023
On 30/3/2023 12:26 pm, Sam Price wrote:
> Same IP as the regular KCU105.
> The current uart ip is dependent on the fpga.
> I don't believe this modifies the kcu105 bsp, but allows other bsps to
> support up to 4 uarts.
I am not sure if this patch is OK. If the UART driver is needed for a console
does that limits how it's configuration can be handled? If so that means the
patch is OK. Adding options for a user's custom IP is questionable.
