[PATCH 3/3] bsp-howto/console: Fix typos
Matthew Joyce matthew.joyce at embedded-brains.de
Thu Mar 30 12:51:14 UTC 2023
From: Matt Joyce <matthew.joyce at embedded-brains.de>
 bsp-howto/console.rst | 14 +++++++-------
 1 file changed, 7 insertions(+), 7 deletions(-)
diff --git a/bsp-howto/console.rst b/bsp-howto/console.rst
index 71e156d..9056e0f 100644
--- a/bsp-howto/console.rst
+++ b/bsp-howto/console.rst
@@ -236,8 +236,8 @@ character has been received or the transmitter is ready for another character.
 In the simplest case, the :c:func:`my_driver_interrupt_handler` will have to
 check the status of the serial device and determine what caused the interrupt.
-The following describes the operation of an
-:c:func:`my_driver_interrupt_handler` which has to do this:
+The following describes the operation of
+:c:func:`my_driver_interrupt_handler`:
 .. code-block:: c
@@ -279,15 +279,15 @@ The following describes the operation of an
 The :c:func:`my_driver_interrupt_write()` handler is responsible for telling
-the device that the ``n`` characters at ``buf`` are to be transmitted.  It the
-value ``n`` is zero to indicate that no more characters are to send.  The
+the device that the ``n`` characters at ``buf`` are to be transmitted.  If the
+value ``n`` is zero, it indicates that there are no more characters to send.  The
 driver can disable the transmit interrupts now.  This routine is invoked either
 from task context with disabled interrupts to start a new transmission process
 with exactly one character in case of an idle output state or from the
 interrupt handler to refill the transmitter.  If the routine is invoked to
-start the transmit process the output state will become busy and Termios starts
+start the transmit process, the output state will become busy and Termios starts
 to fill the output buffer.  If the transmit interrupt arises before Termios was
-able to fill the transmit buffer you will end up with one interrupt per
+able to fill the transmit buffer, you will end up with one interrupt per
 character.
 .. code-block:: c
@@ -371,7 +371,7 @@ called by Termios.  The device registered as :file:`/dev/console` (or
-       * Return true to indicate a successful set attributes, and false
+       * Return true to indicate a successful first open, and false
        * otherwise.
       return true;
2.35.3
