[PATCH rtems-net-legacy] leon3: Replace ambapp_plb with ambapp_plb()
Fri Mar 31 00:35:14 UTC 2023
OK to push.
Thanks
On 31/3/2023 11:20 am, Vijay Kumar Banerjee wrote:
> RTEMS commit 2c07f24af210c4738fbe6f75a53c58fbd80fb658 removed the ambapp_plb
> global variable
>  bsps/sparc/leon3/net/leon_greth.c    |  3 ++-
>  bsps/sparc/leon3/net/leon_open_eth.c |  5 +++--
>  bsps/sparc/leon3/net/leon_smc91111.c | 11 ++++++-----
>  3 files changed, 11 insertions(+), 8 deletions(-)
> diff --git a/bsps/sparc/leon3/net/leon_greth.c b/bsps/sparc/leon3/net/leon_greth.c
> index 5b0c99d..934728f 100644
> --- a/bsps/sparc/leon3/net/leon_greth.c
> +++ b/bsps/sparc/leon3/net/leon_greth.c
> @@ -13,6 +13,7 @@
>  #include <bsp.h>
>  #include <libchip/greth.h>
> +#include <grlib/ambapp.h>
>  /*#if (GRETH_DEBUG & GRETH_DEBUG_PRINT_REGISTERS)*/
>  #include <stdio.h>
>  /*#endif*/
> @@ -36,7 +37,7 @@ int rtems_leon_greth_driver_attach(
>    struct ambapp_apb_info *apb;
>    /* Scan for MAC AHB slave interface */
> -  adev = (void *)ambapp_for_each(&ambapp_plb, (OPTIONS_ALL|OPTIONS_APB_SLVS),
> +  adev = (void *)ambapp_for_each(ambapp_plb(), (OPTIONS_ALL|OPTIONS_APB_SLVS),
>                                   VENDOR_GAISLER, GAISLER_ETHMAC,
>                                   ambapp_find_by_idx, NULL);
>    if (adev) {
> diff --git a/bsps/sparc/leon3/net/leon_open_eth.c b/bsps/sparc/leon3/net/leon_open_eth.c
> index 2b386f8..315f6b7 100644
> --- a/bsps/sparc/leon3/net/leon_open_eth.c
> +++ b/bsps/sparc/leon3/net/leon_open_eth.c
> @@ -17,6 +17,7 @@
>  #include <bsp.h>
>  #include <libchip/open_eth.h>
> +#include <leon.h>
>  #if (OPEN_ETH_DEBUG & OPEN_ETH_DEBUG_PRINT_REGISTERS)
>  #include <stdio.h>
>  #endif
> @@ -40,11 +41,11 @@ int rtems_leon_open_eth_driver_attach(
>    struct ambapp_ahb_info *ahb;
> -  adev = (void *)ambapp_for_each(&ambapp_plb, (OPTIONS_ALL|OPTIONS_AHB_SLVS),
> +  adev = (void *)ambapp_for_each(ambapp_plb(), (OPTIONS_ALL|OPTIONS_AHB_SLVS),
>                                   VENDOR_OPENCORES, OPENCORES_ETHMAC,
>    if (!adev) {
>                                     VENDOR_GAISLER, GAISLER_ETHAHB,
> diff --git a/bsps/sparc/leon3/net/leon_smc91111.c b/bsps/sparc/leon3/net/leon_smc91111.c
> index 70b2dcc..6577f28 100644
> --- a/bsps/sparc/leon3/net/leon_smc91111.c
> +++ b/bsps/sparc/leon3/net/leon_smc91111.c
> @@ -19,6 +19,7 @@
>  #include <libchip/smc91111exp.h>
>  #include <rtems/bspIo.h>
> +#include <grlib/grlib.h>
>  #define SMC91111_BASE_ADDR (void*)0x20000300
>  #define SMC91111_BASE_IRQ  4
> @@ -45,7 +46,7 @@ rtems_smc91111_driver_attach_leon3 (struct rtems_bsdnet_ifconfig *config,
>    struct ambapp_apb_info apbpio;
>    struct ambapp_apb_info apbmctrl;
> -  if (ambapp_find_apbslv(&ambapp_plb, VENDOR_GAISLER, GAISLER_GPIO, &apbpio)
> +  if (ambapp_find_apbslv(ambapp_plb(), VENDOR_GAISLER, GAISLER_GPIO, &apbpio)
>        != 1) {
>      printk("SMC9111_leon3: didn't find PIO\n");
>      return 0;
> @@ -54,12 +55,12 @@ rtems_smc91111_driver_attach_leon3 (struct rtems_bsdnet_ifconfig *config,
>    /* In order to access the SMC controller the memory controller must have
>     * I/O bus enabled. Find first memory controller.
> -  if (ambapp_find_apbslv(&ambapp_plb, VENDOR_ESA, ESA_MCTRL, &apbmctrl) != 1) {
> -    if (ambapp_find_apbslv(&ambapp_plb, VENDOR_GAISLER, GAISLER_FTMCTRL,
> +  if (ambapp_find_apbslv(ambapp_plb(), VENDOR_ESA, ESA_MCTRL, &apbmctrl) != 1) {
> +    if (ambapp_find_apbslv(ambapp_plb(), VENDOR_GAISLER, GAISLER_FTMCTRL,
>                             &apbmctrl) != 1) {
> -      if (ambapp_find_apbslv(&ambapp_plb, VENDOR_GAISLER, GAISLER_FTSRCTRL,
> +      if (ambapp_find_apbslv(ambapp_plb(), VENDOR_GAISLER, GAISLER_FTSRCTRL,
>                               &apbmctrl) != 1) {
> -        if (ambapp_find_apbslv(&ambapp_plb, VENDOR_GAISLER, GAISLER_FTSRCTRL8,
> +        if (ambapp_find_apbslv(ambapp_plb(), VENDOR_GAISLER, GAISLER_FTSRCTRL8,
>                                 &apbmctrl) != 1) {
>            printk("SMC9111_leon3: didn't find any memory controller\n");
>            return 0;
