[PATCH rtems-libbsd] Revert "waf: Move the tools/BSP include path to be last"
Tue May 2 03:19:28 UTC 2023
OK and thanks for cleaning this up.
On 2/5/2023 11:58 am, Kinsey Moore wrote:
> This reverts commit 6ee31ae968323c71c478b2f52ec5a5cbff8c8f5d.
> A fix has been committed to RTEMS pkgcfg and Makefile generation to
> handle this issue and having this in place with the fix in RTEMS causes
> a failure to build.
>  waf_libbsd.py | 29 ++++++++---------------------
>  1 file changed, 8 insertions(+), 21 deletions(-)
> diff --git a/waf_libbsd.py b/waf_libbsd.py
> index acf93a2f..81818956 100644
> --- a/waf_libbsd.py
> +++ b/waf_libbsd.py
> @@ -2,7 +2,7 @@
>  """LibBSD build configuration to waf integration module.
> -# Copyright (c) 2015, 2021 Chris Johns <chrisj at rtems.org>. All rights reserved.
> +# Copyright (c) 2015, 2020 Chris Johns <chrisj at rtems.org>. All rights reserved.
>  # Copyright (c) 2009, 2015 embedded brains GmbH.  All rights reserved.
> @@ -62,13 +62,6 @@ def _add_flags_if_not_present(current_flags, addional_flags):
>          if flag not in current_flags:
>              current_flags.append(flag)
> -def _remove_bsp_include_path(bsp_include_path, current_flags):
> -    # this does not handle quted strings; maybe needed
> -    for bsp_path in bsp_include_path:
> -        if bsp_path in current_flags:
> -            current_flags = [flag for flag in current_flags if flag != bsp_path]
> -    return current_flags
>  # The waf builder for libbsd.
> @@ -194,12 +187,6 @@ class Builder(builder.ModuleManager):
>                                  conf.env['HAVE_%s' % l.upper()] = True
>                      else:
>                          bld.fatal('invalid config test: %s' % (configTest))
> -            conf.env.CFLAGS = _remove_bsp_include_path(conf.env.IFLAGS,
> -                                                       conf.env.CFLAGS)
> -            conf.env.CXXFLAGS = _remove_bsp_include_path(conf.env.IFLAGS,
> -        conf.env.CXXFLAGS)
> -            conf.env.LINKFLAGS = _remove_bsp_include_path(conf.env.IFLAGS,
> -                                                          conf.env.LINKFLAGS)
>          section_flags = ["-fdata-sections", "-ffunction-sections"]
>          _add_flags_if_not_present(conf.env.CFLAGS, section_flags)
>          _add_flags_if_not_present(conf.env.CXXFLAGS, section_flags)
> @@ -250,7 +237,7 @@ class Builder(builder.ModuleManager):
>          inc_paths = sorted(include_paths)
>          inc_paths.remove('build')
>          inc_paths.remove('cpu')
> -        includes = { 'bsp': [p[2:] for p in bld.env.IFLAGS] }
> +        includes = {}
>          for inc in inc_paths:
>              includes[inc] = include_paths[inc]
>          # cpu include paths must be the first searched
> @@ -445,7 +432,7 @@ class Builder(builder.ModuleManager):
>              bld.objects(target='kvmsymbols',
>                          features='c',
>                          cflags=cflags,
> -                        includes=kvmsymbols_includes + includes['kernel'] + includes['bsp'],
> +                        includes=kvmsymbols_includes + includes['kernel'],
>                          source=kvmsymbols['files']['all']['default'][0])
>              libbsd_use += ["kvmsymbols"]
> @@ -500,7 +487,7 @@ class Builder(builder.ModuleManager):
>                      bld.objects(target='lex_%s' % (lex['sym']),
>                                  features='c',
>                                  cflags=cflags,
> -                                includes=lexIncludes + includes['user'] + includes['bsp'],
> +                                includes=lexIncludes + includes['user'],
>                                  defines=defines + lexDefines,
>                                  source=lex['file'][:-2] + '.c')
>                  libbsd_use += ['lex_%s' % (lex['sym'])]
> @@ -540,7 +527,7 @@ class Builder(builder.ModuleManager):
>                      bld.objects(target='yacc_%s' % (yaccSym),
>                                  features='c',
>                                  cflags=cflags,
> -                                includes=yaccIncludes + includes['user'] + includes['bsp'],
> +                                includes=yaccIncludes + includes['user'],
>                                  defines=defines + yaccDefines,
>                                  source=yaccFile[:-2] + '.c')
>                  libbsd_use += ['yacc_%s' % (yaccSym)]
> @@ -574,7 +561,7 @@ class Builder(builder.ModuleManager):
>                              cflags=cflags + bld_cflags,
>                              cxxflags=cxxflags,
>                              includes=sorted(build.get('includes', [])) +
> -                            includes[space] + includes['bsp'],
> +                            includes[space],
>                              defines=defines,
>                              source=bld_sources)
>                  libbsd_use += [target]
> @@ -594,7 +581,7 @@ class Builder(builder.ModuleManager):
>                    features='c cxx',
>                    cflags=cflags,
>                    cxxflags=cxxflags,
> -                  includes=includes['kernel'] + includes['bsp'],
> +                  includes=includes['kernel'],
>                    defines=defines,
>                    source=bld_sources,
>                    use=libbsd_use)
> @@ -671,7 +658,7 @@ class Builder(builder.ModuleManager):
>                  bld.program(target='%s.exe' % (testName),
>                              features='cprogram',
>                              cflags=cflags,
> -                            includes=includes['user'] + includes['bsp'],
> +                            includes=includes['user'],
>                              source=test_sources,
>                              use=['bsd'],
>                              lib=libs,
