[PATCH rtems 02/12] bsp/imxrt: Update support library from mcux-sdk
Christian Mauderer christian.mauderer at embedded-brains.de
Thu May 4 15:00:43 UTC 2023
This imports new files from the mcux-sdk support library. NXP now offers
the library as a git repository instead of a zip package. The git
repository supports multiple CPUs from the i.MXRT family:
  https://github.com/nxp-mcuxpresso/mcux-sdk.git
The imported files are from revision
  2b9354539e6e4f722749e87b0bdc22966dc080d9
This revision is the same as MCUXpresso 2.13.0 with small bug fixes.
NOTE: Due to the size, this is only the summary of the patch. You can find the
full version here:
https://gitlab.com/c-mauderer/rtems/-/commit/2a871672767a95598e5af42373bfebd3eb9440d3
 .../mcux-sdk/devices/MIMXRT1011/MIMXRT1011.h  |  36631 +++++
 .../devices/MIMXRT1011/MIMXRT1011_features.h  |    572 +
 .../devices/MIMXRT1011/drivers/fsl_clock.c    |   1224 +
 .../devices/MIMXRT1011/drivers/fsl_clock.h    |   1574 +
 .../MIMXRT1011/drivers/fsl_flexram_allocate.c |     86 +
 .../MIMXRT1011/drivers/fsl_flexram_allocate.h |     87 +
 .../devices/MIMXRT1011/drivers/fsl_iomuxc.h   |    591 +
 .../devices/MIMXRT1011/drivers/fsl_nic301.h   |    294 +
 .../devices/MIMXRT1011/fsl_device_registers.h |     35 +
 .../MIMXRT1011/gcc/startup_MIMXRT1011.S       |    861 +
 .../devices/MIMXRT1011/system_MIMXRT1011.c    |    221 +
 .../devices/MIMXRT1011/system_MIMXRT1011.h    |    120 +
 .../MIMXRT1011/xip/fsl_flexspi_nor_boot.c     |     49 +
 .../MIMXRT1011/xip/fsl_flexspi_nor_boot.h     |    124 +
 .../mcux-sdk/devices/MIMXRT1015/MIMXRT1015.h  |  39826 ++++++
 .../devices/MIMXRT1015/MIMXRT1015_features.h  |    581 +
 .../devices/MIMXRT1015/drivers/fsl_clock.c    |   1201 +
 .../devices/MIMXRT1015/drivers/fsl_clock.h    |   1648 +
 .../MIMXRT1015/drivers/fsl_flexram_allocate.c |     86 +
 .../MIMXRT1015/drivers/fsl_flexram_allocate.h |     87 +
 .../devices/MIMXRT1015/drivers/fsl_iomuxc.h   |    570 +
 .../devices/MIMXRT1015/drivers/fsl_nic301.h   |    294 +
 .../devices/MIMXRT1015/drivers/fsl_romapi.c   |    170 +
 .../devices/MIMXRT1015/drivers/fsl_romapi.h   |    554 +
 .../devices/MIMXRT1015/fsl_device_registers.h |     35 +
 .../MIMXRT1015/gcc/startup_MIMXRT1015.S       |    924 +
 .../devices/MIMXRT1015/system_MIMXRT1015.c    |    225 +
 .../devices/MIMXRT1015/system_MIMXRT1015.h    |    122 +
 .../MIMXRT1015/xip/fsl_flexspi_nor_boot.c     |     49 +
 .../MIMXRT1015/xip/fsl_flexspi_nor_boot.h     |    124 +
 .../mcux-sdk/devices/MIMXRT1024/MIMXRT1024.h  |  47174 +++++++
 .../devices/MIMXRT1024/MIMXRT1024_features.h  |    746 +
 .../devices/MIMXRT1024/drivers/fsl_clock.c    |   1249 +
 .../devices/MIMXRT1024/drivers/fsl_clock.h    |   1806 +
 .../MIMXRT1024/drivers/fsl_flexram_allocate.c |     86 +
 .../MIMXRT1024/drivers/fsl_flexram_allocate.h |     87 +
 .../devices/MIMXRT1024/drivers/fsl_iomuxc.h   |    954 +
 .../devices/MIMXRT1024/drivers/fsl_nic301.h   |    294 +
 .../devices/MIMXRT1024/drivers/fsl_romapi.c   |    170 +
 .../devices/MIMXRT1024/drivers/fsl_romapi.h   |    554 +
 .../devices/MIMXRT1024/fsl_device_registers.h |     36 +
 .../MIMXRT1024/gcc/startup_MIMXRT1024.S       |   1058 +
 .../devices/MIMXRT1024/system_MIMXRT1024.c    |    251 +
 .../devices/MIMXRT1024/system_MIMXRT1024.h    |    114 +
 .../MIMXRT1024/xip/fsl_flexspi_nor_boot.c     |     49 +
 .../MIMXRT1024/xip/fsl_flexspi_nor_boot.h     |    124 +
 .../mcux-sdk/devices/MIMXRT1042/MIMXRT1042.h  |  53934 ++++++++
 .../devices/MIMXRT1042/MIMXRT1042_features.h  |    783 +
 .../devices/MIMXRT1042/drivers/fsl_clock.c    |   1434 +
 .../devices/MIMXRT1042/drivers/fsl_clock.h    |   1985 +
 .../MIMXRT1042/drivers/fsl_flexram_allocate.c |     86 +
 .../MIMXRT1042/drivers/fsl_flexram_allocate.h |     87 +
 .../devices/MIMXRT1042/drivers/fsl_iomuxc.h   |   1156 +
 .../devices/MIMXRT1042/drivers/fsl_nic301.h   |    313 +
 .../devices/MIMXRT1042/drivers/fsl_romapi.c   |    196 +
 .../devices/MIMXRT1042/drivers/fsl_romapi.h   |    639 +
 .../devices/MIMXRT1042/fsl_device_registers.h |     35 +
 .../MIMXRT1042/gcc/startup_MIMXRT1042.S       |   1100 +
 .../devices/MIMXRT1042/system_MIMXRT1042.c    |    229 +
 .../devices/MIMXRT1042/system_MIMXRT1042.h    |    118 +
 .../MIMXRT1042/xip/fsl_flexspi_nor_boot.c     |     49 +
 .../MIMXRT1042/xip/fsl_flexspi_nor_boot.h     |    124 +
 .../mcux-sdk/devices/MIMXRT1051/MIMXRT1051.h  |  49292 +++++++
 .../devices/MIMXRT1051/MIMXRT1051_features.h  |    759 +
 .../devices/MIMXRT1051/drivers/fsl_clock.c    |   1531 +
 .../devices/MIMXRT1051/drivers/fsl_clock.h    |   2039 +
 .../MIMXRT1051/drivers/fsl_flexram_allocate.c |     86 +
 .../MIMXRT1051/drivers/fsl_flexram_allocate.h |     87 +
 .../devices/MIMXRT1051/drivers/fsl_iomuxc.h   |   1241 +
 .../devices/MIMXRT1051/drivers/fsl_nic301.h   |    308 +
 .../devices/MIMXRT1051/drivers/fsl_romapi.c   |    162 +
 .../devices/MIMXRT1051/drivers/fsl_romapi.h   |    565 +
 .../devices/MIMXRT1051/fsl_device_registers.h |     36 +
 .../MIMXRT1051/gcc/startup_MIMXRT1051.S       |   1077 +
 .../devices/MIMXRT1051/system_MIMXRT1051.c    |    242 +
 .../devices/MIMXRT1051/system_MIMXRT1051.h    |    131 +
 .../mcux-sdk/devices/MIMXRT1052/MIMXRT1052.h  |  53558 ++++++++
 .../devices/MIMXRT1052/MIMXRT1052_features.h  |    785 +
 .../devices/MIMXRT1052/drivers/fsl_clock.c    |   1535 +
 .../devices/MIMXRT1052/drivers/fsl_clock.h    |   2038 +
 .../MIMXRT1052/drivers/fsl_flexram_allocate.c |     86 +
 .../MIMXRT1052/drivers/fsl_flexram_allocate.h |     87 +
 .../devices/MIMXRT1052/drivers/fsl_iomuxc.h   |   1241 +
 .../devices/MIMXRT1052/drivers/fsl_nic301.h   |    308 +
 .../devices/MIMXRT1052/drivers/fsl_romapi.c   |    162 +
 .../devices/MIMXRT1052/drivers/fsl_romapi.h   |    565 +
 .../devices/MIMXRT1052/fsl_device_registers.h |     36 +
 .../MIMXRT1052/gcc/startup_MIMXRT1052.S       |   1077 +
 .../devices/MIMXRT1052/system_MIMXRT1052.c    |    242 +
 .../devices/MIMXRT1052/system_MIMXRT1052.h    |    131 +
 .../MIMXRT1052/xip/fsl_flexspi_nor_boot.c     |     49 +
 .../MIMXRT1052/xip/fsl_flexspi_nor_boot.h     |    124 +
 .../mcux-sdk/devices/MIMXRT1061/MIMXRT1061.h  |  51926 +++++++
 .../devices/MIMXRT1061/MIMXRT1061_features.h  |    769 +
 .../devices/MIMXRT1061/drivers/fsl_clock.c    |   1552 +
 .../devices/MIMXRT1061/drivers/fsl_clock.h    |   2070 +
 .../MIMXRT1061/drivers/fsl_flexram_allocate.c |     86 +
 .../MIMXRT1061/drivers/fsl_flexram_allocate.h |     87 +
 .../devices/MIMXRT1061/drivers/fsl_iomuxc.h   |   1437 +
 .../devices/MIMXRT1061/drivers/fsl_nic301.h   |    313 +
 .../devices/MIMXRT1061/drivers/fsl_romapi.c   |    196 +
 .../devices/MIMXRT1061/drivers/fsl_romapi.h   |    639 +
 .../devices/MIMXRT1061/fsl_device_registers.h |     37 +
 .../MIMXRT1061/gcc/startup_MIMXRT1061.S       |   1127 +
 .../devices/MIMXRT1061/system_MIMXRT1061.c    |    245 +
 .../devices/MIMXRT1061/system_MIMXRT1061.h    |    134 +
 .../mcux-sdk/devices/MIMXRT1062/MIMXRT1062.h  |  56120 ++++++++
 .../devices/MIMXRT1062/MIMXRT1062_features.h  |    795 +
 .../devices/MIMXRT1062/drivers/fsl_clock.c    |   1552 +
 .../devices/MIMXRT1062/drivers/fsl_clock.h    |   2069 +
 .../MIMXRT1062/drivers/fsl_flexram_allocate.c |     86 +
 .../MIMXRT1062/drivers/fsl_flexram_allocate.h |     87 +
 .../devices/MIMXRT1062/drivers/fsl_iomuxc.h   |   1437 +
 .../devices/MIMXRT1062/drivers/fsl_nic301.h   |    313 +
 .../devices/MIMXRT1062/drivers/fsl_romapi.c   |    196 +
 .../devices/MIMXRT1062/drivers/fsl_romapi.h   |    639 +
 .../devices/MIMXRT1062/fsl_device_registers.h |     38 +
 .../MIMXRT1062/gcc/startup_MIMXRT1062.S       |   1127 +
 .../devices/MIMXRT1062/system_MIMXRT1062.c    |    246 +
 .../devices/MIMXRT1062/system_MIMXRT1062.h    |    135 +
 .../MIMXRT1062/xip/fsl_flexspi_nor_boot.c     |     49 +
 .../MIMXRT1062/xip/fsl_flexspi_nor_boot.h     |    124 +
 .../mcux-sdk/devices/MIMXRT1064/MIMXRT1064.h  |  55976 ++++++++
 .../devices/MIMXRT1064/MIMXRT1064_features.h  |    793 +
 .../devices/MIMXRT1064/drivers/fsl_clock.c    |   1552 +
 .../devices/MIMXRT1064/drivers/fsl_clock.h    |   2070 +
 .../MIMXRT1064/drivers/fsl_flexram_allocate.c |     86 +
 .../MIMXRT1064/drivers/fsl_flexram_allocate.h |     87 +
 .../devices/MIMXRT1064/drivers/fsl_iomuxc.h   |   1421 +
 .../devices/MIMXRT1064/drivers/fsl_nic301.h   |    313 +
 .../devices/MIMXRT1064/drivers/fsl_romapi.c   |    196 +
 .../devices/MIMXRT1064/drivers/fsl_romapi.h   |    639 +
 .../devices/MIMXRT1064/fsl_device_registers.h |     36 +
 .../MIMXRT1064/gcc/startup_MIMXRT1064.S       |   1128 +
 .../devices/MIMXRT1064/system_MIMXRT1064.c    |    238 +
 .../devices/MIMXRT1064/system_MIMXRT1064.h    |    127 +
 .../MIMXRT1064/xip/fsl_flexspi_nor_boot.c     |     49 +
 .../MIMXRT1064/xip/fsl_flexspi_nor_boot.h     |    119 +
 .../devices/MIMXRT1165/MIMXRT1165_cm4.h       |  88499 ++++++++++++
 .../MIMXRT1165/MIMXRT1165_cm4_features.h      |    872 +
 .../devices/MIMXRT1165/MIMXRT1165_cm7.h       |  87566 ++++++++++++
 .../MIMXRT1165/MIMXRT1165_cm7_features.h      |    859 +
 .../MIMXRT1165/drivers/cm4/fsl_cache.c        |    507 +
 .../MIMXRT1165/drivers/cm4/fsl_cache.h        |    340 +
 .../MIMXRT1165/drivers/cm7/fsl_cache.c        |    602 +
 .../MIMXRT1165/drivers/cm7/fsl_cache.h        |    463 +
 .../MIMXRT1165/drivers/fsl_anatop_ai.c        |    357 +
 .../MIMXRT1165/drivers/fsl_anatop_ai.h        |    533 +
 .../devices/MIMXRT1165/drivers/fsl_clock.c    |   1929 +
 .../devices/MIMXRT1165/drivers/fsl_clock.h    |   3308 +
 .../devices/MIMXRT1165/drivers/fsl_dcdc.c     |    518 +
 .../devices/MIMXRT1165/drivers/fsl_dcdc.h     |   1013 +
 .../MIMXRT1165/drivers/fsl_flexram_allocate.c |     92 +
 .../MIMXRT1165/drivers/fsl_flexram_allocate.h |     87 +
 .../devices/MIMXRT1165/drivers/fsl_gpc.c      |    335 +
 .../devices/MIMXRT1165/drivers/fsl_gpc.h      |    651 +
 .../devices/MIMXRT1165/drivers/fsl_iomuxc.h   |   1770 +
 .../devices/MIMXRT1165/drivers/fsl_memory.h   |     89 +
 .../devices/MIMXRT1165/drivers/fsl_nic301.h   |    293 +
 .../devices/MIMXRT1165/drivers/fsl_pgmc.c     |    461 +
 .../devices/MIMXRT1165/drivers/fsl_pgmc.h     |    783 +
 .../devices/MIMXRT1165/drivers/fsl_pmu.c      |    959 +
 .../devices/MIMXRT1165/drivers/fsl_pmu.h      |    855 +
 .../devices/MIMXRT1165/drivers/fsl_romapi.c   |    250 +
 .../devices/MIMXRT1165/drivers/fsl_romapi.h   |    724 +
 .../MIMXRT1165/drivers/fsl_soc_mipi_csi2rx.c  |     71 +
 .../MIMXRT1165/drivers/fsl_soc_mipi_csi2rx.h  |     66 +
 .../devices/MIMXRT1165/drivers/fsl_soc_src.c  |    183 +
 .../devices/MIMXRT1165/drivers/fsl_soc_src.h  |    754 +
 .../devices/MIMXRT1165/fsl_device_registers.h |     44 +
 .../MIMXRT1165/gcc/startup_MIMXRT1165_cm4.S   |   1421 +
 .../MIMXRT1165/gcc/startup_MIMXRT1165_cm7.S   |   1421 +
 .../MIMXRT1165/system_MIMXRT1165_cm4.c        |    176 +
 .../MIMXRT1165/system_MIMXRT1165_cm4.h        |    118 +
 .../MIMXRT1165/system_MIMXRT1165_cm7.c        |    159 +
 .../MIMXRT1165/system_MIMXRT1165_cm7.h        |    118 +
 .../devices/MIMXRT1166/MIMXRT1166_cm4.h       |  93964 +++++++++++++
 .../MIMXRT1166/MIMXRT1166_cm4_features.h      |    903 +
 .../devices/MIMXRT1166/MIMXRT1166_cm7.h       |  93031 +++++++++++++
 .../MIMXRT1166/MIMXRT1166_cm7_features.h      |    890 +
 .../MIMXRT1166/drivers/cm4/fsl_cache.c        |    507 +
 .../MIMXRT1166/drivers/cm4/fsl_cache.h        |    340 +
 .../MIMXRT1166/drivers/cm7/fsl_cache.c        |    602 +
 .../MIMXRT1166/drivers/cm7/fsl_cache.h        |    463 +
 .../MIMXRT1166/drivers/fsl_anatop_ai.c        |    357 +
 .../MIMXRT1166/drivers/fsl_anatop_ai.h        |    533 +
 .../devices/MIMXRT1166/drivers/fsl_clock.c    |   1929 +
 .../devices/MIMXRT1166/drivers/fsl_clock.h    |   3308 +
 .../devices/MIMXRT1166/drivers/fsl_dcdc.c     |    518 +
 .../devices/MIMXRT1166/drivers/fsl_dcdc.h     |   1013 +
 .../MIMXRT1166/drivers/fsl_flexram_allocate.c |     92 +
 .../MIMXRT1166/drivers/fsl_flexram_allocate.h |     87 +
 .../devices/MIMXRT1166/drivers/fsl_gpc.c      |    335 +
 .../devices/MIMXRT1166/drivers/fsl_gpc.h      |    651 +
 .../devices/MIMXRT1166/drivers/fsl_iomuxc.h   |   1770 +
 .../devices/MIMXRT1166/drivers/fsl_memory.h   |     89 +
 .../devices/MIMXRT1166/drivers/fsl_nic301.h   |    293 +
 .../devices/MIMXRT1166/drivers/fsl_pgmc.c     |    461 +
 .../devices/MIMXRT1166/drivers/fsl_pgmc.h     |    783 +
 .../devices/MIMXRT1166/drivers/fsl_pmu.c      |    959 +
 .../devices/MIMXRT1166/drivers/fsl_pmu.h      |    855 +
 .../devices/MIMXRT1166/drivers/fsl_romapi.c   |    250 +
 .../devices/MIMXRT1166/drivers/fsl_romapi.h   |    724 +
 .../MIMXRT1166/drivers/fsl_soc_mipi_csi2rx.c  |     71 +
 .../MIMXRT1166/drivers/fsl_soc_mipi_csi2rx.h  |     66 +
 .../devices/MIMXRT1166/drivers/fsl_soc_src.c  |    183 +
 .../devices/MIMXRT1166/drivers/fsl_soc_src.h  |    754 +
 .../devices/MIMXRT1166/fsl_device_registers.h |     44 +
 .../MIMXRT1166/gcc/startup_MIMXRT1166_cm4.S   |   1421 +
 .../MIMXRT1166/gcc/startup_MIMXRT1166_cm7.S   |   1421 +
 .../MIMXRT1166/system_MIMXRT1166_cm4.c        |    176 +
 .../MIMXRT1166/system_MIMXRT1166_cm4.h        |    118 +
 .../MIMXRT1166/system_MIMXRT1166_cm7.c        |    159 +
 .../MIMXRT1166/system_MIMXRT1166_cm7.h        |    118 +
 .../MIMXRT1166/xip/fsl_flexspi_nor_boot.c     |     49 +
 .../MIMXRT1166/xip/fsl_flexspi_nor_boot.h     |    149 +
 .../mcux-sdk/devices/MIMXRT1171/MIMXRT1171.h  |  98750 ++++++++++++++
 .../devices/MIMXRT1171/MIMXRT1171_features.h  |    866 +
 .../MIMXRT1171/drivers/cm7/fsl_cache.c        |    602 +
 .../MIMXRT1171/drivers/cm7/fsl_cache.h        |    463 +
 .../MIMXRT1171/drivers/fsl_anatop_ai.c        |    357 +
 .../MIMXRT1171/drivers/fsl_anatop_ai.h        |    533 +
 .../devices/MIMXRT1171/drivers/fsl_clock.c    |   1947 +
 .../devices/MIMXRT1171/drivers/fsl_clock.h    |   3343 +
 .../devices/MIMXRT1171/drivers/fsl_dcdc.c     |    518 +
 .../devices/MIMXRT1171/drivers/fsl_dcdc.h     |   1013 +
 .../MIMXRT1171/drivers/fsl_flexram_allocate.c |     92 +
 .../MIMXRT1171/drivers/fsl_flexram_allocate.h |     87 +
 .../devices/MIMXRT1171/drivers/fsl_gpc.c      |    335 +
 .../devices/MIMXRT1171/drivers/fsl_gpc.h      |    651 +
 .../devices/MIMXRT1171/drivers/fsl_iomuxc.h   |   1770 +
 .../devices/MIMXRT1171/drivers/fsl_nic301.h   |    293 +
 .../devices/MIMXRT1171/drivers/fsl_pgmc.c     |    461 +
 .../devices/MIMXRT1171/drivers/fsl_pgmc.h     |    783 +
 .../devices/MIMXRT1171/drivers/fsl_pmu.c      |    959 +
 .../devices/MIMXRT1171/drivers/fsl_pmu.h      |    855 +
 .../devices/MIMXRT1171/drivers/fsl_romapi.c   |    272 +
 .../devices/MIMXRT1171/drivers/fsl_romapi.h   |    731 +
 .../MIMXRT1171/drivers/fsl_soc_mipi_csi2rx.c  |     71 +
 .../MIMXRT1171/drivers/fsl_soc_mipi_csi2rx.h  |     66 +
 .../devices/MIMXRT1171/drivers/fsl_soc_src.c  |    183 +
 .../devices/MIMXRT1171/drivers/fsl_soc_src.h  |    754 +
 .../devices/MIMXRT1171/fsl_device_registers.h |     35 +
 .../MIMXRT1171/gcc/startup_MIMXRT1171.S       |   1481 +
 .../devices/MIMXRT1171/system_MIMXRT1171.c    |    160 +
 .../devices/MIMXRT1171/system_MIMXRT1171.h    |    120 +
 .../mcux-sdk/devices/MIMXRT1172/MIMXRT1172.h  | 104215 ++++++++++++++
 .../devices/MIMXRT1172/MIMXRT1172_features.h  |    897 +
 .../MIMXRT1172/drivers/cm7/fsl_cache.c        |    602 +
 .../MIMXRT1172/drivers/cm7/fsl_cache.h        |    463 +
 .../MIMXRT1172/drivers/fsl_anatop_ai.c        |    357 +
 .../MIMXRT1172/drivers/fsl_anatop_ai.h        |    533 +
 .../devices/MIMXRT1172/drivers/fsl_clock.c    |   1947 +
 .../devices/MIMXRT1172/drivers/fsl_clock.h    |   3343 +
 .../devices/MIMXRT1172/drivers/fsl_dcdc.c     |    518 +
 .../devices/MIMXRT1172/drivers/fsl_dcdc.h     |   1013 +
 .../MIMXRT1172/drivers/fsl_flexram_allocate.c |     92 +
 .../MIMXRT1172/drivers/fsl_flexram_allocate.h |     87 +
 .../devices/MIMXRT1172/drivers/fsl_gpc.c      |    335 +
 .../devices/MIMXRT1172/drivers/fsl_gpc.h      |    651 +
 .../devices/MIMXRT1172/drivers/fsl_iomuxc.h   |   1770 +
 .../devices/MIMXRT1172/drivers/fsl_nic301.h   |    293 +
 .../devices/MIMXRT1172/drivers/fsl_pgmc.c     |    461 +
 .../devices/MIMXRT1172/drivers/fsl_pgmc.h     |    783 +
 .../devices/MIMXRT1172/drivers/fsl_pmu.c      |    959 +
 .../devices/MIMXRT1172/drivers/fsl_pmu.h      |    855 +
 .../devices/MIMXRT1172/drivers/fsl_romapi.c   |    272 +
 .../devices/MIMXRT1172/drivers/fsl_romapi.h   |    731 +
 .../MIMXRT1172/drivers/fsl_soc_mipi_csi2rx.c  |     71 +
 .../MIMXRT1172/drivers/fsl_soc_mipi_csi2rx.h  |     66 +
 .../devices/MIMXRT1172/drivers/fsl_soc_src.c  |    183 +
 .../devices/MIMXRT1172/drivers/fsl_soc_src.h  |    754 +
 .../devices/MIMXRT1172/fsl_device_registers.h |     35 +
 .../MIMXRT1172/gcc/startup_MIMXRT1172.S       |   1481 +
 .../devices/MIMXRT1172/system_MIMXRT1172.c    |    160 +
 .../devices/MIMXRT1172/system_MIMXRT1172.h    |    120 +
 .../devices/MIMXRT1173/MIMXRT1173_cm4.h       | 105145 ++++++++++++++
 .../MIMXRT1173/MIMXRT1173_cm4_features.h      |    910 +
 .../devices/MIMXRT1173/MIMXRT1173_cm7.h       | 104212 ++++++++++++++
 .../MIMXRT1173/MIMXRT1173_cm7_features.h      |    897 +
 .../MIMXRT1173/drivers/cm4/fsl_cache.c        |    507 +
 .../MIMXRT1173/drivers/cm4/fsl_cache.h        |    340 +
 .../MIMXRT1173/drivers/cm7/fsl_cache.c        |    602 +
 .../MIMXRT1173/drivers/cm7/fsl_cache.h        |    463 +
 .../MIMXRT1173/drivers/fsl_anatop_ai.c        |    357 +
 .../MIMXRT1173/drivers/fsl_anatop_ai.h        |    533 +
 .../devices/MIMXRT1173/drivers/fsl_clock.c    |   1947 +
 .../devices/MIMXRT1173/drivers/fsl_clock.h    |   3343 +
 .../devices/MIMXRT1173/drivers/fsl_dcdc.c     |    518 +
 .../devices/MIMXRT1173/drivers/fsl_dcdc.h     |   1013 +
 .../MIMXRT1173/drivers/fsl_flexram_allocate.c |     92 +
 .../MIMXRT1173/drivers/fsl_flexram_allocate.h |     87 +
 .../devices/MIMXRT1173/drivers/fsl_gpc.c      |    335 +
 .../devices/MIMXRT1173/drivers/fsl_gpc.h      |    651 +
 .../devices/MIMXRT1173/drivers/fsl_iomuxc.h   |   1770 +
 .../devices/MIMXRT1173/drivers/fsl_memory.h   |     89 +
 .../devices/MIMXRT1173/drivers/fsl_nic301.h   |    293 +
 .../devices/MIMXRT1173/drivers/fsl_pgmc.c     |    461 +
 .../devices/MIMXRT1173/drivers/fsl_pgmc.h     |    783 +
 .../devices/MIMXRT1173/drivers/fsl_pmu.c      |    959 +
 .../devices/MIMXRT1173/drivers/fsl_pmu.h      |    855 +
 .../devices/MIMXRT1173/drivers/fsl_romapi.c   |    272 +
 .../devices/MIMXRT1173/drivers/fsl_romapi.h   |    731 +
 .../MIMXRT1173/drivers/fsl_soc_mipi_csi2rx.c  |     71 +
 .../MIMXRT1173/drivers/fsl_soc_mipi_csi2rx.h  |     66 +
 .../devices/MIMXRT1173/drivers/fsl_soc_src.c  |    183 +
 .../devices/MIMXRT1173/drivers/fsl_soc_src.h  |    754 +
 .../devices/MIMXRT1173/fsl_device_registers.h |     44 +
 .../MIMXRT1173/gcc/startup_MIMXRT1173_cm4.S   |   1439 +
 .../MIMXRT1173/gcc/startup_MIMXRT1173_cm7.S   |   1439 +
 .../MIMXRT1173/system_MIMXRT1173_cm4.c        |    175 +
 .../MIMXRT1173/system_MIMXRT1173_cm4.h        |    117 +
 .../MIMXRT1173/system_MIMXRT1173_cm7.c        |    158 +
 .../MIMXRT1173/system_MIMXRT1173_cm7.h        |    117 +
 .../devices/MIMXRT1175/MIMXRT1175_cm4.h       |  99683 ++++++++++++++
 .../MIMXRT1175/MIMXRT1175_cm4_features.h      |    879 +
 .../devices/MIMXRT1175/MIMXRT1175_cm7.h       |  98750 ++++++++++++++
 .../MIMXRT1175/MIMXRT1175_cm7_features.h      |    866 +
 .../MIMXRT1175/drivers/cm4/fsl_cache.c        |    507 +
 .../MIMXRT1175/drivers/cm4/fsl_cache.h        |    340 +
 .../MIMXRT1175/drivers/cm7/fsl_cache.c        |    602 +
 .../MIMXRT1175/drivers/cm7/fsl_cache.h        |    463 +
 .../MIMXRT1175/drivers/fsl_anatop_ai.c        |    357 +
 .../MIMXRT1175/drivers/fsl_anatop_ai.h        |    533 +
 .../devices/MIMXRT1175/drivers/fsl_clock.c    |   1947 +
 .../devices/MIMXRT1175/drivers/fsl_clock.h    |   3343 +
 .../devices/MIMXRT1175/drivers/fsl_dcdc.c     |    518 +
 .../devices/MIMXRT1175/drivers/fsl_dcdc.h     |   1013 +
 .../MIMXRT1175/drivers/fsl_flexram_allocate.c |     92 +
 .../MIMXRT1175/drivers/fsl_flexram_allocate.h |     87 +
 .../devices/MIMXRT1175/drivers/fsl_gpc.c      |    335 +
 .../devices/MIMXRT1175/drivers/fsl_gpc.h      |    651 +
 .../devices/MIMXRT1175/drivers/fsl_iomuxc.h   |   1770 +
 .../devices/MIMXRT1175/drivers/fsl_memory.h   |     89 +
 .../devices/MIMXRT1175/drivers/fsl_nic301.h   |    293 +
 .../devices/MIMXRT1175/drivers/fsl_pgmc.c     |    461 +
 .../devices/MIMXRT1175/drivers/fsl_pgmc.h     |    783 +
 .../devices/MIMXRT1175/drivers/fsl_pmu.c      |    959 +
 .../devices/MIMXRT1175/drivers/fsl_pmu.h      |    855 +
 .../devices/MIMXRT1175/drivers/fsl_romapi.c   |    272 +
 .../devices/MIMXRT1175/drivers/fsl_romapi.h   |    731 +
 .../MIMXRT1175/drivers/fsl_soc_mipi_csi2rx.c  |     71 +
 .../MIMXRT1175/drivers/fsl_soc_mipi_csi2rx.h  |     66 +
 .../devices/MIMXRT1175/drivers/fsl_soc_src.c  |    183 +
 .../devices/MIMXRT1175/drivers/fsl_soc_src.h  |    754 +
 .../devices/MIMXRT1175/fsl_device_registers.h |     44 +
 .../MIMXRT1175/gcc/startup_MIMXRT1175_cm4.S   |   1439 +
 .../MIMXRT1175/gcc/startup_MIMXRT1175_cm7.S   |   1439 +
 .../MIMXRT1175/system_MIMXRT1175_cm4.c        |    178 +
 .../MIMXRT1175/system_MIMXRT1175_cm4.h        |    120 +
 .../MIMXRT1175/system_MIMXRT1175_cm7.c        |    161 +
 .../MIMXRT1175/system_MIMXRT1175_cm7.h        |    120 +
 .../devices/MIMXRT1176/MIMXRT1176_cm4.h       | 105148 +++++++++++++++
 .../MIMXRT1176/MIMXRT1176_cm4_features.h      |    911 +
 .../devices/MIMXRT1176/MIMXRT1176_cm7.h       | 104215 ++++++++++++++
 .../MIMXRT1176/MIMXRT1176_cm7_features.h      |    898 +
 .../MIMXRT1176/drivers/cm4/fsl_cache.c        |    507 +
 .../MIMXRT1176/drivers/cm4/fsl_cache.h        |    340 +
 .../MIMXRT1176/drivers/cm7/fsl_cache.c        |    602 +
 .../MIMXRT1176/drivers/cm7/fsl_cache.h        |    463 +
 .../MIMXRT1176/drivers/fsl_anatop_ai.c        |    357 +
 .../MIMXRT1176/drivers/fsl_anatop_ai.h        |    533 +
 .../devices/MIMXRT1176/drivers/fsl_clock.c    |   1947 +
 .../devices/MIMXRT1176/drivers/fsl_clock.h    |   3343 +
 .../devices/MIMXRT1176/drivers/fsl_dcdc.c     |    518 +
 .../devices/MIMXRT1176/drivers/fsl_dcdc.h     |   1013 +
 .../MIMXRT1176/drivers/fsl_flexram_allocate.c |     92 +
 .../MIMXRT1176/drivers/fsl_flexram_allocate.h |     87 +
 .../devices/MIMXRT1176/drivers/fsl_gpc.c      |    335 +
 .../devices/MIMXRT1176/drivers/fsl_gpc.h      |    651 +
 .../devices/MIMXRT1176/drivers/fsl_iomuxc.h   |   1770 +
 .../devices/MIMXRT1176/drivers/fsl_memory.h   |     89 +
 .../devices/MIMXRT1176/drivers/fsl_nic301.h   |    293 +
 .../devices/MIMXRT1176/drivers/fsl_pgmc.c     |    461 +
 .../devices/MIMXRT1176/drivers/fsl_pgmc.h     |    783 +
 .../devices/MIMXRT1176/drivers/fsl_pmu.c      |    959 +
 .../devices/MIMXRT1176/drivers/fsl_pmu.h      |    855 +
 .../devices/MIMXRT1176/drivers/fsl_romapi.c   |    272 +
 .../devices/MIMXRT1176/drivers/fsl_romapi.h   |    731 +
 .../MIMXRT1176/drivers/fsl_soc_mipi_csi2rx.c  |     71 +
 .../MIMXRT1176/drivers/fsl_soc_mipi_csi2rx.h  |     66 +
 .../devices/MIMXRT1176/drivers/fsl_soc_src.c  |    183 +
 .../devices/MIMXRT1176/drivers/fsl_soc_src.h  |    754 +
 .../devices/MIMXRT1176/fsl_device_registers.h |     44 +
 .../MIMXRT1176/gcc/startup_MIMXRT1176_cm4.S   |   1439 +
 .../MIMXRT1176/gcc/startup_MIMXRT1176_cm7.S   |   1439 +
 .../MIMXRT1176/system_MIMXRT1176_cm4.c        |    178 +
 .../MIMXRT1176/system_MIMXRT1176_cm4.h        |    120 +
 .../MIMXRT1176/system_MIMXRT1176_cm7.c        |    161 +
 .../MIMXRT1176/system_MIMXRT1176_cm7.h        |    120 +
 .../MIMXRT1176/xip/fsl_flexspi_nor_boot.c     |     49 +
 .../MIMXRT1176/xip/fsl_flexspi_nor_boot.h     |    149 +
 .../imxrt/mcux-sdk/drivers/acmp/fsl_acmp.c    |    662 +
 .../imxrt/mcux-sdk/drivers/acmp/fsl_acmp.h    |    536 +
 .../drivers/adc_12b1msps_sar/fsl_adc.c        |    395 +
 .../drivers/adc_12b1msps_sar/fsl_adc.h        |    427 +
 .../mcux-sdk/drivers/adc_etc/fsl_adc_etc.c    |    464 +
 .../mcux-sdk/drivers/adc_etc/fsl_adc_etc.h    |    352 +
 bsps/arm/imxrt/mcux-sdk/drivers/aoi/fsl_aoi.c |    214 +
 bsps/arm/imxrt/mcux-sdk/drivers/aoi/fsl_aoi.h |    186 +
 .../imxrt/mcux-sdk/drivers/asrc/fsl_asrc.c    |   1031 +
 .../imxrt/mcux-sdk/drivers/asrc/fsl_asrc.h    |    761 +
 .../mcux-sdk/drivers/asrc/fsl_asrc_edma.c     |    470 +
 .../mcux-sdk/drivers/asrc/fsl_asrc_edma.h     |    245 +
 bsps/arm/imxrt/mcux-sdk/drivers/bee/fsl_bee.c |    303 +
 bsps/arm/imxrt/mcux-sdk/drivers/bee/fsl_bee.h |    254 +
 .../drivers/cache/armv7-m7/fsl_cache.c        |    602 +
 .../drivers/cache/armv7-m7/fsl_cache.h        |    463 +
 .../imxrt/mcux-sdk/drivers/cdog/fsl_cdog.c    |    314 +
 .../imxrt/mcux-sdk/drivers/cdog/fsl_cdog.h    |    325 +
 bsps/arm/imxrt/mcux-sdk/drivers/cmp/fsl_cmp.c |    371 +
 bsps/arm/imxrt/mcux-sdk/drivers/cmp/fsl_cmp.h |    321 +
 .../mcux-sdk/drivers/common/fsl_common.c      |     86 +
 .../mcux-sdk/drivers/common/fsl_common.h      |    331 +
 .../mcux-sdk/drivers/common/fsl_common_arm.c  |    249 +
 .../mcux-sdk/drivers/common/fsl_common_arm.h  |    837 +
 .../mcux-sdk/drivers/common/fsl_common_dsp.h  |    170 +
 bsps/arm/imxrt/mcux-sdk/drivers/csi/fsl_csi.c |   1417 +
 bsps/arm/imxrt/mcux-sdk/drivers/csi/fsl_csi.h |    730 +
 .../imxrt/mcux-sdk/drivers/dac12/fsl_dac12.c  |    200 +
 .../imxrt/mcux-sdk/drivers/dac12/fsl_dac12.h  |    418 +
 .../imxrt/mcux-sdk/drivers/dcdc_1/fsl_dcdc.c  |    913 +
 .../imxrt/mcux-sdk/drivers/dcdc_1/fsl_dcdc.h  |    735 +
 .../imxrt/mcux-sdk/drivers/dcic/fsl_dcic.c    |    174 +
 .../imxrt/mcux-sdk/drivers/dcic/fsl_dcic.h    |    380 +
 bsps/arm/imxrt/mcux-sdk/drivers/dcp/fsl_dcp.c |   1461 +
 bsps/arm/imxrt/mcux-sdk/drivers/dcp/fsl_dcp.h |    580 +
 .../mcux-sdk/drivers/dmamux/fsl_dmamux.c      |     91 +
 .../mcux-sdk/drivers/dmamux/fsl_dmamux.h      |    189 +
 .../imxrt/mcux-sdk/drivers/edma/fsl_edma.c    |   2858 +
 .../imxrt/mcux-sdk/drivers/edma/fsl_edma.h    |   1018 +
 .../mcux-sdk/drivers/elcdif/fsl_elcdif.c      |    387 +
 .../mcux-sdk/drivers/elcdif/fsl_elcdif.h      |    767 +
 bsps/arm/imxrt/mcux-sdk/drivers/enc/fsl_enc.c |    625 +
 bsps/arm/imxrt/mcux-sdk/drivers/enc/fsl_enc.h |    562 +
 .../imxrt/mcux-sdk/drivers/enet/fsl_enet.c    |   3993 +
 .../imxrt/mcux-sdk/drivers/enet/fsl_enet.h    |   2046 +
 .../mcux-sdk/drivers/enet_qos/fsl_enet_qos.c  |   3864 +
 .../mcux-sdk/drivers/enet_qos/fsl_enet_qos.h  |   1834 +
 bsps/arm/imxrt/mcux-sdk/drivers/ewm/fsl_ewm.c |    140 +
 bsps/arm/imxrt/mcux-sdk/drivers/ewm/fsl_ewm.h |    218 +
 .../mcux-sdk/drivers/flexcan/fsl_flexcan.c    |   4613 +
 .../mcux-sdk/drivers/flexcan/fsl_flexcan.h    |   2241 +
 .../drivers/flexcan/fsl_flexcan_edma.c        |    373 +
 .../drivers/flexcan/fsl_flexcan_edma.h        |    188 +
 .../mcux-sdk/drivers/flexio/fsl_flexio.c      |    433 +
 .../mcux-sdk/drivers/flexio/fsl_flexio.h      |    735 +
 .../drivers/flexio/fsl_flexio_camera.h        |    230 +
 .../drivers/flexio/fsl_flexio_camera_edma.h   |    130 +
 .../drivers/flexio/fsl_flexio_i2c_master.c    |   1377 +
 .../drivers/flexio/fsl_flexio_i2c_master.h    |    485 +
 .../mcux-sdk/drivers/flexio/fsl_flexio_i2s.c  |    903 +
 .../mcux-sdk/drivers/flexio/fsl_flexio_i2s.h  |    560 +
 .../drivers/flexio/fsl_flexio_i2s_dma.h       |    198 +
 .../drivers/flexio/fsl_flexio_i2s_edma.c      |    445 +
 .../drivers/flexio/fsl_flexio_i2s_edma.h      |    201 +
 .../drivers/flexio/fsl_flexio_mculcd.h        |    685 +
 .../drivers/flexio/fsl_flexio_mculcd_edma.h   |    153 +
 .../flexio/fsl_flexio_mculcd_smartdma.h       |    158 +
 .../mcux-sdk/drivers/flexio/fsl_flexio_spi.c  |   1553 +
 .../mcux-sdk/drivers/flexio/fsl_flexio_spi.h  |    719 +
 .../drivers/flexio/fsl_flexio_spi_dma.h       |    205 +
 .../drivers/flexio/fsl_flexio_spi_edma.c      |    565 +
 .../drivers/flexio/fsl_flexio_spi_edma.h      |    207 +
 .../mcux-sdk/drivers/flexio/fsl_flexio_uart.c |   1009 +
 .../mcux-sdk/drivers/flexio/fsl_flexio_uart.h |    581 +
 .../drivers/flexio/fsl_flexio_uart_dma.h      |    176 +
 .../drivers/flexio/fsl_flexio_uart_edma.c     |    407 +
 .../drivers/flexio/fsl_flexio_uart_edma.h     |    178 +
 .../mcux-sdk/drivers/flexram/fsl_flexram.c    |    423 +
 .../mcux-sdk/drivers/flexram/fsl_flexram.h    |    508 +
 .../mcux-sdk/drivers/flexspi/fsl_flexspi.c    |   1271 +
 .../mcux-sdk/drivers/flexspi/fsl_flexspi.h    |    886 +
 .../drivers/flexspi/fsl_flexspi_dma.h         |    144 +
 .../drivers/flexspi/fsl_flexspi_edma.c        |    366 +
 .../drivers/flexspi/fsl_flexspi_edma.h        |    150 +
 .../imxrt/mcux-sdk/drivers/gpc_1/fsl_gpc.c    |    103 +
 .../imxrt/mcux-sdk/drivers/gpc_1/fsl_gpc.h    |    231 +
 bsps/arm/imxrt/mcux-sdk/drivers/gpt/fsl_gpt.c |    127 +
 bsps/arm/imxrt/mcux-sdk/drivers/gpt/fsl_gpt.h |    509 +
 bsps/arm/imxrt/mcux-sdk/drivers/iee/fsl_iee.c |    141 +
 bsps/arm/imxrt/mcux-sdk/drivers/iee/fsl_iee.h |    181 +
 .../mcux-sdk/drivers/iee_apc/fsl_iee_apc.c    |    391 +
 .../mcux-sdk/drivers/iee_apc/fsl_iee_apc.h    |    124 +
 .../imxrt/mcux-sdk/drivers/igpio/fsl_gpio.c   |    183 +
 .../imxrt/mcux-sdk/drivers/igpio/fsl_gpio.h   |    344 +
 .../drivers/key_manager/fsl_key_manager.c     |    218 +
 .../drivers/key_manager/fsl_key_manager.h     |    181 +
 bsps/arm/imxrt/mcux-sdk/drivers/kpp/fsl_kpp.c |    203 +
 bsps/arm/imxrt/mcux-sdk/drivers/kpp/fsl_kpp.h |    180 +
 .../mcux-sdk/drivers/lcdifv2/fsl_lcdifv2.c    |    527 +
 .../mcux-sdk/drivers/lcdifv2/fsl_lcdifv2.h    |    655 +
 .../imxrt/mcux-sdk/drivers/lpadc/fsl_lpadc.c  |    708 +
 .../imxrt/mcux-sdk/drivers/lpadc/fsl_lpadc.h  |   1070 +
 .../imxrt/mcux-sdk/drivers/lpi2c/fsl_lpi2c.c  |   2608 +
 .../imxrt/mcux-sdk/drivers/lpi2c/fsl_lpi2c.h  |   1320 +
 .../mcux-sdk/drivers/lpi2c/fsl_lpi2c_edma.c   |    616 +
 .../mcux-sdk/drivers/lpi2c/fsl_lpi2c_edma.h   |    158 +
 .../drivers/lpi2c/fsl_lpi2c_freertos.h        |    107 +
 .../imxrt/mcux-sdk/drivers/lpspi/fsl_lpspi.c  |   2421 +
 .../imxrt/mcux-sdk/drivers/lpspi/fsl_lpspi.h  |   1158 +
 .../mcux-sdk/drivers/lpspi/fsl_lpspi_edma.c   |   1052 +
 .../mcux-sdk/drivers/lpspi/fsl_lpspi_edma.h   |    301 +
 .../drivers/lpspi/fsl_lpspi_freertos.h        |    107 +
 .../mcux-sdk/drivers/lpuart/fsl_lpuart.c      |   2351 +
 .../mcux-sdk/drivers/lpuart/fsl_lpuart.h      |   1064 +
 .../mcux-sdk/drivers/lpuart/fsl_lpuart_dma.h  |    186 +
 .../mcux-sdk/drivers/lpuart/fsl_lpuart_edma.c |    503 +
 .../mcux-sdk/drivers/lpuart/fsl_lpuart_edma.h |    189 +
 .../drivers/lpuart/fsl_lpuart_freertos.h      |    192 +
 .../imxrt/mcux-sdk/drivers/mecc/fsl_mecc.c    |    340 +
 .../imxrt/mcux-sdk/drivers/mecc/fsl_mecc.h    |    396 +
 .../drivers/mipi_csi2rx/fsl_mipi_csi2rx.c     |    260 +
 .../drivers/mipi_csi2rx/fsl_mipi_csi2rx.h     |    383 +
 .../drivers/mipi_dsi_split/fsl_mipi_dsi.c     |   1433 +
 .../drivers/mipi_dsi_split/fsl_mipi_dsi.h     |    824 +
 bsps/arm/imxrt/mcux-sdk/drivers/mu/fsl_mu.c   |    414 +
 bsps/arm/imxrt/mcux-sdk/drivers/mu/fsl_mu.h   |    752 +
 .../imxrt/mcux-sdk/drivers/ocotp/fsl_ocotp.c  |    406 +
 .../imxrt/mcux-sdk/drivers/ocotp/fsl_ocotp.h  |    211 +
 .../imxrt/mcux-sdk/drivers/otfad/fsl_otfad.c  |    271 +
 .../imxrt/mcux-sdk/drivers/otfad/fsl_otfad.h  |    209 +
 bsps/arm/imxrt/mcux-sdk/drivers/pdm/fsl_pdm.c |    963 +
 bsps/arm/imxrt/mcux-sdk/drivers/pdm/fsl_pdm.h |   1213 +
 .../imxrt/mcux-sdk/drivers/pdm/fsl_pdm_edma.c |    459 +
 .../imxrt/mcux-sdk/drivers/pdm/fsl_pdm_edma.h |    254 +
 .../imxrt/mcux-sdk/drivers/pdm/fsl_pdm_sdma.h |    140 +
 bsps/arm/imxrt/mcux-sdk/drivers/pit/fsl_pit.c |    146 +
 bsps/arm/imxrt/mcux-sdk/drivers/pit/fsl_pit.h |    334 +
 bsps/arm/imxrt/mcux-sdk/drivers/puf/fsl_puf.c |    949 +
 bsps/arm/imxrt/mcux-sdk/drivers/puf/fsl_puf.h |    335 +
 bsps/arm/imxrt/mcux-sdk/drivers/pwm/fsl_pwm.c |   1328 +
 bsps/arm/imxrt/mcux-sdk/drivers/pwm/fsl_pwm.h |   1225 +
 bsps/arm/imxrt/mcux-sdk/drivers/pxp/fsl_pxp.c |   2188 +
 bsps/arm/imxrt/mcux-sdk/drivers/pxp/fsl_pxp.h |   2712 +
 .../imxrt/mcux-sdk/drivers/qtmr_1/fsl_qtmr.c  |    729 +
 .../imxrt/mcux-sdk/drivers/qtmr_1/fsl_qtmr.h  |    529 +
 bsps/arm/imxrt/mcux-sdk/drivers/rdc/fsl_rdc.c |    310 +
 bsps/arm/imxrt/mcux-sdk/drivers/rdc/fsl_rdc.h |    447 +
 .../drivers/rdc_sema42/fsl_rdc_sema42.c       |    236 +
 .../drivers/rdc_sema42/fsl_rdc_sema42.h       |    194 +
 .../mcux-sdk/drivers/rtwdog/fsl_rtwdog.c      |    148 +
 .../mcux-sdk/drivers/rtwdog/fsl_rtwdog.h      |    425 +
 bsps/arm/imxrt/mcux-sdk/drivers/sai/fsl_sai.c |   3831 +
 bsps/arm/imxrt/mcux-sdk/drivers/sai/fsl_sai.h |   1586 +
 .../imxrt/mcux-sdk/drivers/sai/fsl_sai_edma.c |   1033 +
 .../imxrt/mcux-sdk/drivers/sai/fsl_sai_edma.h |    367 +
 .../imxrt/mcux-sdk/drivers/sai/fsl_sai_sdma.h |    238 +
 .../imxrt/mcux-sdk/drivers/sema4/fsl_sema4.c  |    252 +
 .../imxrt/mcux-sdk/drivers/sema4/fsl_sema4.h  |    260 +
 .../imxrt/mcux-sdk/drivers/semc/fsl_semc.c    |   1385 +
 .../imxrt/mcux-sdk/drivers/semc/fsl_semc.h    |    924 +
 .../drivers/smartcard/fsl_smartcard.h         |    274 +
 .../drivers/smartcard/fsl_smartcard_emvsim.c  |   1143 +
 .../drivers/smartcard/fsl_smartcard_emvsim.h  |    182 +
 .../drivers/smartcard/fsl_smartcard_phy.h     |    127 +
 .../smartcard/fsl_smartcard_phy_emvsim.c      |    227 +
 .../mcux-sdk/drivers/snvs_hp/fsl_snvs_hp.c    |    565 +
 .../mcux-sdk/drivers/snvs_hp/fsl_snvs_hp.h    |    649 +
 .../mcux-sdk/drivers/snvs_lp/fsl_snvs_lp.c    |   1358 +
 .../mcux-sdk/drivers/snvs_lp/fsl_snvs_lp.h    |    733 +
 .../imxrt/mcux-sdk/drivers/spdif/fsl_spdif.c  |    849 +
 .../imxrt/mcux-sdk/drivers/spdif/fsl_spdif.h  |    753 +
 .../mcux-sdk/drivers/spdif/fsl_spdif_edma.c   |    598 +
 .../mcux-sdk/drivers/spdif/fsl_spdif_edma.h   |    192 +
 bsps/arm/imxrt/mcux-sdk/drivers/src/fsl_src.c |     49 +
 bsps/arm/imxrt/mcux-sdk/drivers/src/fsl_src.h |    602 +
 .../imxrt/mcux-sdk/drivers/ssarc/fsl_ssarc.c  |    179 +
 .../imxrt/mcux-sdk/drivers/ssarc/fsl_ssarc.h  |    474 +
 .../mcux-sdk/drivers/tempmon/fsl_tempmon.c    |    204 +
 .../mcux-sdk/drivers/tempmon/fsl_tempmon.h    |    127 +
 .../drivers/tempsensor/fsl_tempsensor.c       |    368 +
 .../drivers/tempsensor/fsl_tempsensor.h       |    186 +
 .../imxrt/mcux-sdk/drivers/trng/fsl_trng.c    |   2009 +
 .../imxrt/mcux-sdk/drivers/trng/fsl_trng.h    |    239 +
 .../imxrt/mcux-sdk/drivers/usdhc/fsl_usdhc.c  |   2480 +
 .../imxrt/mcux-sdk/drivers/usdhc/fsl_usdhc.h  |   1703 +
 .../imxrt/mcux-sdk/drivers/wdog01/fsl_wdog.c  |    214 +
 .../imxrt/mcux-sdk/drivers/wdog01/fsl_wdog.h  |    305 +
 .../imxrt/mcux-sdk/drivers/xbara/fsl_xbara.c  |    229 +
 .../imxrt/mcux-sdk/drivers/xbara/fsl_xbara.h  |    186 +
 .../imxrt/mcux-sdk/drivers/xbarb/fsl_xbarb.c  |    126 +
 .../imxrt/mcux-sdk/drivers/xbarb/fsl_xbarb.h  |     82 +
 .../imxrt/mcux-sdk/drivers/xecc/fsl_xecc.c    |    148 +
 .../imxrt/mcux-sdk/drivers/xecc/fsl_xecc.h    |    322 +
 .../imxrt/mcux-sdk/drivers/xrdc2/fsl_xrdc2.c  |    925 +
 .../imxrt/mcux-sdk/drivers/xrdc2/fsl_xrdc2.h  |    690 +
 spec/build/bsps/arm/imxrt/obj-mimxrt1011.yml  |    174 +
 spec/build/bsps/arm/imxrt/obj-mimxrt1015.yml  |    182 +
 spec/build/bsps/arm/imxrt/obj-mimxrt1024.yml  |    204 +
 spec/build/bsps/arm/imxrt/obj-mimxrt1042.yml  |    207 +
 spec/build/bsps/arm/imxrt/obj-mimxrt1051.yml  |    200 +
 spec/build/bsps/arm/imxrt/obj-mimxrt1052.yml  |    212 +
 spec/build/bsps/arm/imxrt/obj-mimxrt1061.yml  |    201 +
 spec/build/bsps/arm/imxrt/obj-mimxrt1062.yml  |    214 +
 spec/build/bsps/arm/imxrt/obj-mimxrt1064.yml  |    214 +
 .../bsps/arm/imxrt/obj-mimxrt1165-cm4.yml     |    250 +
 .../bsps/arm/imxrt/obj-mimxrt1165-cm7.yml     |    268 +
 .../bsps/arm/imxrt/obj-mimxrt1166-cm4.yml     |    268 +
 .../bsps/arm/imxrt/obj-mimxrt1166-cm7.yml     |    289 +
 .../bsps/arm/imxrt/obj-mimxrt1171-cm7.yml     |    250 +
 .../bsps/arm/imxrt/obj-mimxrt1172-cm7.yml     |    259 +
 .../bsps/arm/imxrt/obj-mimxrt1173-cm4.yml     |    263 +
 .../bsps/arm/imxrt/obj-mimxrt1173-cm7.yml     |    281 +
 .../bsps/arm/imxrt/obj-mimxrt1175-cm4.yml     |    254 +
 .../bsps/arm/imxrt/obj-mimxrt1175-cm7.yml     |    272 +
 .../bsps/arm/imxrt/obj-mimxrt1176-cm4.yml     |    272 +
 .../bsps/arm/imxrt/obj-mimxrt1176-cm7.yml     |    293 +
 608 files changed, 1991131 insertions(+)
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1011/MIMXRT1011.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1011/MIMXRT1011_features.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1011/drivers/fsl_clock.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1011/drivers/fsl_clock.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1011/drivers/fsl_flexram_allocate.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1011/drivers/fsl_flexram_allocate.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1011/drivers/fsl_iomuxc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1011/drivers/fsl_nic301.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1011/fsl_device_registers.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1011/gcc/startup_MIMXRT1011.S
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1011/system_MIMXRT1011.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1011/system_MIMXRT1011.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1011/xip/fsl_flexspi_nor_boot.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1011/xip/fsl_flexspi_nor_boot.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1015/MIMXRT1015.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1015/MIMXRT1015_features.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1015/drivers/fsl_clock.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1015/drivers/fsl_clock.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1015/drivers/fsl_flexram_allocate.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1015/drivers/fsl_flexram_allocate.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1015/drivers/fsl_iomuxc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1015/drivers/fsl_nic301.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1015/drivers/fsl_romapi.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1015/drivers/fsl_romapi.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1015/fsl_device_registers.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1015/gcc/startup_MIMXRT1015.S
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1015/system_MIMXRT1015.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1015/system_MIMXRT1015.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1015/xip/fsl_flexspi_nor_boot.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1015/xip/fsl_flexspi_nor_boot.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1024/MIMXRT1024.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1024/MIMXRT1024_features.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1024/drivers/fsl_clock.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1024/drivers/fsl_clock.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1024/drivers/fsl_flexram_allocate.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1024/drivers/fsl_flexram_allocate.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1024/drivers/fsl_iomuxc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1024/drivers/fsl_nic301.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1024/drivers/fsl_romapi.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1024/drivers/fsl_romapi.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1024/fsl_device_registers.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1024/gcc/startup_MIMXRT1024.S
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1024/system_MIMXRT1024.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1024/system_MIMXRT1024.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1024/xip/fsl_flexspi_nor_boot.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1024/xip/fsl_flexspi_nor_boot.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1042/MIMXRT1042.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1042/MIMXRT1042_features.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1042/drivers/fsl_clock.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1042/drivers/fsl_clock.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1042/drivers/fsl_flexram_allocate.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1042/drivers/fsl_flexram_allocate.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1042/drivers/fsl_iomuxc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1042/drivers/fsl_nic301.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1042/drivers/fsl_romapi.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1042/drivers/fsl_romapi.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1042/fsl_device_registers.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1042/gcc/startup_MIMXRT1042.S
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1042/system_MIMXRT1042.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1042/system_MIMXRT1042.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1042/xip/fsl_flexspi_nor_boot.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1042/xip/fsl_flexspi_nor_boot.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1051/MIMXRT1051.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1051/MIMXRT1051_features.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1051/drivers/fsl_clock.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1051/drivers/fsl_clock.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1051/drivers/fsl_flexram_allocate.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1051/drivers/fsl_flexram_allocate.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1051/drivers/fsl_iomuxc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1051/drivers/fsl_nic301.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1051/drivers/fsl_romapi.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1051/drivers/fsl_romapi.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1051/fsl_device_registers.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1051/gcc/startup_MIMXRT1051.S
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1051/system_MIMXRT1051.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1051/system_MIMXRT1051.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1052/MIMXRT1052.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1052/MIMXRT1052_features.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1052/drivers/fsl_clock.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1052/drivers/fsl_clock.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1052/drivers/fsl_flexram_allocate.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1052/drivers/fsl_flexram_allocate.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1052/drivers/fsl_iomuxc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1052/drivers/fsl_nic301.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1052/drivers/fsl_romapi.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1052/drivers/fsl_romapi.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1052/fsl_device_registers.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1052/gcc/startup_MIMXRT1052.S
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1052/system_MIMXRT1052.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1052/system_MIMXRT1052.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1052/xip/fsl_flexspi_nor_boot.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1052/xip/fsl_flexspi_nor_boot.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1061/MIMXRT1061.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1061/MIMXRT1061_features.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1061/drivers/fsl_clock.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1061/drivers/fsl_clock.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1061/drivers/fsl_flexram_allocate.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1061/drivers/fsl_flexram_allocate.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1061/drivers/fsl_iomuxc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1061/drivers/fsl_nic301.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1061/drivers/fsl_romapi.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1061/drivers/fsl_romapi.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1061/fsl_device_registers.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1061/gcc/startup_MIMXRT1061.S
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1061/system_MIMXRT1061.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1061/system_MIMXRT1061.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1062/MIMXRT1062.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1062/MIMXRT1062_features.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1062/drivers/fsl_clock.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1062/drivers/fsl_clock.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1062/drivers/fsl_flexram_allocate.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1062/drivers/fsl_flexram_allocate.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1062/drivers/fsl_iomuxc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1062/drivers/fsl_nic301.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1062/drivers/fsl_romapi.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1062/drivers/fsl_romapi.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1062/fsl_device_registers.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1062/gcc/startup_MIMXRT1062.S
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1062/system_MIMXRT1062.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1062/system_MIMXRT1062.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1062/xip/fsl_flexspi_nor_boot.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1062/xip/fsl_flexspi_nor_boot.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1064/MIMXRT1064.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1064/MIMXRT1064_features.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1064/drivers/fsl_clock.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1064/drivers/fsl_clock.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1064/drivers/fsl_flexram_allocate.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1064/drivers/fsl_flexram_allocate.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1064/drivers/fsl_iomuxc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1064/drivers/fsl_nic301.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1064/drivers/fsl_romapi.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1064/drivers/fsl_romapi.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1064/fsl_device_registers.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1064/gcc/startup_MIMXRT1064.S
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1064/system_MIMXRT1064.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1064/system_MIMXRT1064.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1064/xip/fsl_flexspi_nor_boot.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1064/xip/fsl_flexspi_nor_boot.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1165/MIMXRT1165_cm4.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1165/MIMXRT1165_cm4_features.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1165/MIMXRT1165_cm7.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1165/MIMXRT1165_cm7_features.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1165/drivers/cm4/fsl_cache.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1165/drivers/cm4/fsl_cache.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1165/drivers/cm7/fsl_cache.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1165/drivers/cm7/fsl_cache.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1165/drivers/fsl_anatop_ai.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1165/drivers/fsl_anatop_ai.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1165/drivers/fsl_clock.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1165/drivers/fsl_clock.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1165/drivers/fsl_dcdc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1165/drivers/fsl_dcdc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1165/drivers/fsl_flexram_allocate.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1165/drivers/fsl_flexram_allocate.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1165/drivers/fsl_gpc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1165/drivers/fsl_gpc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1165/drivers/fsl_iomuxc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1165/drivers/fsl_memory.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1165/drivers/fsl_nic301.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1165/drivers/fsl_pgmc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1165/drivers/fsl_pgmc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1165/drivers/fsl_pmu.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1165/drivers/fsl_pmu.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1165/drivers/fsl_romapi.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1165/drivers/fsl_romapi.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1165/drivers/fsl_soc_mipi_csi2rx.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1165/drivers/fsl_soc_mipi_csi2rx.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1165/drivers/fsl_soc_src.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1165/drivers/fsl_soc_src.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1165/fsl_device_registers.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1165/gcc/startup_MIMXRT1165_cm4.S
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1165/gcc/startup_MIMXRT1165_cm7.S
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1165/system_MIMXRT1165_cm4.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1165/system_MIMXRT1165_cm4.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1165/system_MIMXRT1165_cm7.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1165/system_MIMXRT1165_cm7.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/MIMXRT1166_cm4.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/MIMXRT1166_cm4_features.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/MIMXRT1166_cm7.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/MIMXRT1166_cm7_features.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/cm4/fsl_cache.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/cm4/fsl_cache.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/cm7/fsl_cache.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/cm7/fsl_cache.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_anatop_ai.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_anatop_ai.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_clock.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_clock.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_dcdc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_dcdc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_flexram_allocate.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_flexram_allocate.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_gpc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_gpc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_iomuxc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_memory.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_nic301.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_pgmc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_pgmc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_pmu.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_pmu.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_romapi.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_romapi.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_soc_mipi_csi2rx.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_soc_mipi_csi2rx.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_soc_src.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_soc_src.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/fsl_device_registers.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/gcc/startup_MIMXRT1166_cm4.S
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/gcc/startup_MIMXRT1166_cm7.S
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/system_MIMXRT1166_cm4.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/system_MIMXRT1166_cm4.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/system_MIMXRT1166_cm7.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/system_MIMXRT1166_cm7.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/xip/fsl_flexspi_nor_boot.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/xip/fsl_flexspi_nor_boot.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1171/MIMXRT1171.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1171/MIMXRT1171_features.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1171/drivers/cm7/fsl_cache.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1171/drivers/cm7/fsl_cache.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1171/drivers/fsl_anatop_ai.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1171/drivers/fsl_anatop_ai.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1171/drivers/fsl_clock.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1171/drivers/fsl_clock.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1171/drivers/fsl_dcdc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1171/drivers/fsl_dcdc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1171/drivers/fsl_flexram_allocate.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1171/drivers/fsl_flexram_allocate.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1171/drivers/fsl_gpc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1171/drivers/fsl_gpc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1171/drivers/fsl_iomuxc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1171/drivers/fsl_nic301.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1171/drivers/fsl_pgmc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1171/drivers/fsl_pgmc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1171/drivers/fsl_pmu.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1171/drivers/fsl_pmu.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1171/drivers/fsl_romapi.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1171/drivers/fsl_romapi.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1171/drivers/fsl_soc_mipi_csi2rx.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1171/drivers/fsl_soc_mipi_csi2rx.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1171/drivers/fsl_soc_src.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1171/drivers/fsl_soc_src.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1171/fsl_device_registers.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1171/gcc/startup_MIMXRT1171.S
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1171/system_MIMXRT1171.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1171/system_MIMXRT1171.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1172/MIMXRT1172.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1172/MIMXRT1172_features.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1172/drivers/cm7/fsl_cache.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1172/drivers/cm7/fsl_cache.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1172/drivers/fsl_anatop_ai.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1172/drivers/fsl_anatop_ai.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1172/drivers/fsl_clock.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1172/drivers/fsl_clock.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1172/drivers/fsl_dcdc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1172/drivers/fsl_dcdc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1172/drivers/fsl_flexram_allocate.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1172/drivers/fsl_flexram_allocate.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1172/drivers/fsl_gpc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1172/drivers/fsl_gpc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1172/drivers/fsl_iomuxc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1172/drivers/fsl_nic301.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1172/drivers/fsl_pgmc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1172/drivers/fsl_pgmc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1172/drivers/fsl_pmu.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1172/drivers/fsl_pmu.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1172/drivers/fsl_romapi.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1172/drivers/fsl_romapi.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1172/drivers/fsl_soc_mipi_csi2rx.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1172/drivers/fsl_soc_mipi_csi2rx.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1172/drivers/fsl_soc_src.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1172/drivers/fsl_soc_src.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1172/fsl_device_registers.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1172/gcc/startup_MIMXRT1172.S
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1172/system_MIMXRT1172.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1172/system_MIMXRT1172.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1173/MIMXRT1173_cm4.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1173/MIMXRT1173_cm4_features.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1173/MIMXRT1173_cm7.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1173/MIMXRT1173_cm7_features.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1173/drivers/cm4/fsl_cache.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1173/drivers/cm4/fsl_cache.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1173/drivers/cm7/fsl_cache.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1173/drivers/cm7/fsl_cache.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1173/drivers/fsl_anatop_ai.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1173/drivers/fsl_anatop_ai.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1173/drivers/fsl_clock.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1173/drivers/fsl_clock.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1173/drivers/fsl_dcdc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1173/drivers/fsl_dcdc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1173/drivers/fsl_flexram_allocate.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1173/drivers/fsl_flexram_allocate.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1173/drivers/fsl_gpc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1173/drivers/fsl_gpc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1173/drivers/fsl_iomuxc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1173/drivers/fsl_memory.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1173/drivers/fsl_nic301.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1173/drivers/fsl_pgmc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1173/drivers/fsl_pgmc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1173/drivers/fsl_pmu.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1173/drivers/fsl_pmu.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1173/drivers/fsl_romapi.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1173/drivers/fsl_romapi.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1173/drivers/fsl_soc_mipi_csi2rx.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1173/drivers/fsl_soc_mipi_csi2rx.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1173/drivers/fsl_soc_src.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1173/drivers/fsl_soc_src.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1173/fsl_device_registers.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1173/gcc/startup_MIMXRT1173_cm4.S
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1173/gcc/startup_MIMXRT1173_cm7.S
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1173/system_MIMXRT1173_cm4.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1173/system_MIMXRT1173_cm4.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1173/system_MIMXRT1173_cm7.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1173/system_MIMXRT1173_cm7.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1175/MIMXRT1175_cm4.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1175/MIMXRT1175_cm4_features.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1175/MIMXRT1175_cm7.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1175/MIMXRT1175_cm7_features.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1175/drivers/cm4/fsl_cache.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1175/drivers/cm4/fsl_cache.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1175/drivers/cm7/fsl_cache.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1175/drivers/cm7/fsl_cache.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1175/drivers/fsl_anatop_ai.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1175/drivers/fsl_anatop_ai.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1175/drivers/fsl_clock.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1175/drivers/fsl_clock.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1175/drivers/fsl_dcdc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1175/drivers/fsl_dcdc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1175/drivers/fsl_flexram_allocate.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1175/drivers/fsl_flexram_allocate.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1175/drivers/fsl_gpc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1175/drivers/fsl_gpc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1175/drivers/fsl_iomuxc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1175/drivers/fsl_memory.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1175/drivers/fsl_nic301.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1175/drivers/fsl_pgmc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1175/drivers/fsl_pgmc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1175/drivers/fsl_pmu.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1175/drivers/fsl_pmu.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1175/drivers/fsl_romapi.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1175/drivers/fsl_romapi.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1175/drivers/fsl_soc_mipi_csi2rx.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1175/drivers/fsl_soc_mipi_csi2rx.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1175/drivers/fsl_soc_src.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1175/drivers/fsl_soc_src.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1175/fsl_device_registers.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1175/gcc/startup_MIMXRT1175_cm4.S
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1175/gcc/startup_MIMXRT1175_cm7.S
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1175/system_MIMXRT1175_cm4.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1175/system_MIMXRT1175_cm4.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1175/system_MIMXRT1175_cm7.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1175/system_MIMXRT1175_cm7.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1176/MIMXRT1176_cm4.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1176/MIMXRT1176_cm4_features.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1176/MIMXRT1176_cm7.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1176/MIMXRT1176_cm7_features.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1176/drivers/cm4/fsl_cache.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1176/drivers/cm4/fsl_cache.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1176/drivers/cm7/fsl_cache.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1176/drivers/cm7/fsl_cache.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1176/drivers/fsl_anatop_ai.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1176/drivers/fsl_anatop_ai.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1176/drivers/fsl_clock.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1176/drivers/fsl_clock.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1176/drivers/fsl_dcdc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1176/drivers/fsl_dcdc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1176/drivers/fsl_flexram_allocate.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1176/drivers/fsl_flexram_allocate.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1176/drivers/fsl_gpc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1176/drivers/fsl_gpc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1176/drivers/fsl_iomuxc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1176/drivers/fsl_memory.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1176/drivers/fsl_nic301.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1176/drivers/fsl_pgmc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1176/drivers/fsl_pgmc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1176/drivers/fsl_pmu.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1176/drivers/fsl_pmu.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1176/drivers/fsl_romapi.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1176/drivers/fsl_romapi.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1176/drivers/fsl_soc_mipi_csi2rx.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1176/drivers/fsl_soc_mipi_csi2rx.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1176/drivers/fsl_soc_src.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1176/drivers/fsl_soc_src.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1176/fsl_device_registers.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1176/gcc/startup_MIMXRT1176_cm4.S
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1176/gcc/startup_MIMXRT1176_cm7.S
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1176/system_MIMXRT1176_cm4.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1176/system_MIMXRT1176_cm4.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1176/system_MIMXRT1176_cm7.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1176/system_MIMXRT1176_cm7.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1176/xip/fsl_flexspi_nor_boot.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1176/xip/fsl_flexspi_nor_boot.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/acmp/fsl_acmp.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/acmp/fsl_acmp.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/adc_12b1msps_sar/fsl_adc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/adc_12b1msps_sar/fsl_adc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/adc_etc/fsl_adc_etc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/adc_etc/fsl_adc_etc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/aoi/fsl_aoi.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/aoi/fsl_aoi.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/asrc/fsl_asrc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/asrc/fsl_asrc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/asrc/fsl_asrc_edma.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/asrc/fsl_asrc_edma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/bee/fsl_bee.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/bee/fsl_bee.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/cache/armv7-m7/fsl_cache.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/cache/armv7-m7/fsl_cache.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/cdog/fsl_cdog.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/cdog/fsl_cdog.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/cmp/fsl_cmp.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/cmp/fsl_cmp.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/common/fsl_common.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/common/fsl_common.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/common/fsl_common_arm.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/common/fsl_common_arm.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/common/fsl_common_dsp.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/csi/fsl_csi.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/csi/fsl_csi.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/dac12/fsl_dac12.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/dac12/fsl_dac12.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/dcdc_1/fsl_dcdc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/dcdc_1/fsl_dcdc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/dcic/fsl_dcic.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/dcic/fsl_dcic.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/dcp/fsl_dcp.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/dcp/fsl_dcp.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/dmamux/fsl_dmamux.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/dmamux/fsl_dmamux.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/edma/fsl_edma.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/edma/fsl_edma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/elcdif/fsl_elcdif.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/elcdif/fsl_elcdif.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/enc/fsl_enc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/enc/fsl_enc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/enet/fsl_enet.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/enet/fsl_enet.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/enet_qos/fsl_enet_qos.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/enet_qos/fsl_enet_qos.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/ewm/fsl_ewm.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/ewm/fsl_ewm.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexcan/fsl_flexcan.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexcan/fsl_flexcan.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexcan/fsl_flexcan_edma.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexcan/fsl_flexcan_edma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_camera.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_camera_edma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_i2c_master.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_i2c_master.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_i2s.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_i2s.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_i2s_dma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_i2s_edma.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_i2s_edma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_mculcd.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_mculcd_edma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_mculcd_smartdma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_spi.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_spi.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_spi_dma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_spi_edma.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_spi_edma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_uart.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_uart.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_uart_dma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_uart_edma.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_uart_edma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexram/fsl_flexram.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexram/fsl_flexram.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexspi/fsl_flexspi.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexspi/fsl_flexspi.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexspi/fsl_flexspi_dma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexspi/fsl_flexspi_edma.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexspi/fsl_flexspi_edma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/gpc_1/fsl_gpc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/gpc_1/fsl_gpc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/gpt/fsl_gpt.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/gpt/fsl_gpt.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/iee/fsl_iee.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/iee/fsl_iee.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/iee_apc/fsl_iee_apc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/iee_apc/fsl_iee_apc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/igpio/fsl_gpio.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/igpio/fsl_gpio.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/key_manager/fsl_key_manager.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/key_manager/fsl_key_manager.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/kpp/fsl_kpp.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/kpp/fsl_kpp.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/lcdifv2/fsl_lcdifv2.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/lcdifv2/fsl_lcdifv2.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/lpadc/fsl_lpadc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/lpadc/fsl_lpadc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/lpi2c/fsl_lpi2c.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/lpi2c/fsl_lpi2c.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/lpi2c/fsl_lpi2c_edma.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/lpi2c/fsl_lpi2c_edma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/lpi2c/fsl_lpi2c_freertos.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/lpspi/fsl_lpspi.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/lpspi/fsl_lpspi.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/lpspi/fsl_lpspi_edma.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/lpspi/fsl_lpspi_edma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/lpspi/fsl_lpspi_freertos.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/lpuart/fsl_lpuart.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/lpuart/fsl_lpuart.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/lpuart/fsl_lpuart_dma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/lpuart/fsl_lpuart_edma.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/lpuart/fsl_lpuart_edma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/lpuart/fsl_lpuart_freertos.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/mecc/fsl_mecc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/mecc/fsl_mecc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/mipi_csi2rx/fsl_mipi_csi2rx.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/mipi_csi2rx/fsl_mipi_csi2rx.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/mipi_dsi_split/fsl_mipi_dsi.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/mipi_dsi_split/fsl_mipi_dsi.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/mu/fsl_mu.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/mu/fsl_mu.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/ocotp/fsl_ocotp.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/ocotp/fsl_ocotp.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/otfad/fsl_otfad.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/otfad/fsl_otfad.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/pdm/fsl_pdm.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/pdm/fsl_pdm.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/pdm/fsl_pdm_edma.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/pdm/fsl_pdm_edma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/pdm/fsl_pdm_sdma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/pit/fsl_pit.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/pit/fsl_pit.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/puf/fsl_puf.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/puf/fsl_puf.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/pwm/fsl_pwm.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/pwm/fsl_pwm.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/pxp/fsl_pxp.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/pxp/fsl_pxp.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/qtmr_1/fsl_qtmr.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/qtmr_1/fsl_qtmr.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/rdc/fsl_rdc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/rdc/fsl_rdc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/rdc_sema42/fsl_rdc_sema42.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/rdc_sema42/fsl_rdc_sema42.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/rtwdog/fsl_rtwdog.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/rtwdog/fsl_rtwdog.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/sai/fsl_sai.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/sai/fsl_sai.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/sai/fsl_sai_edma.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/sai/fsl_sai_edma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/sai/fsl_sai_sdma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/sema4/fsl_sema4.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/sema4/fsl_sema4.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/semc/fsl_semc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/semc/fsl_semc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/smartcard/fsl_smartcard.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/smartcard/fsl_smartcard_emvsim.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/smartcard/fsl_smartcard_emvsim.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/smartcard/fsl_smartcard_phy.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/smartcard/fsl_smartcard_phy_emvsim.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/snvs_hp/fsl_snvs_hp.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/snvs_hp/fsl_snvs_hp.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/snvs_lp/fsl_snvs_lp.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/snvs_lp/fsl_snvs_lp.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/spdif/fsl_spdif.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/spdif/fsl_spdif.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/spdif/fsl_spdif_edma.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/spdif/fsl_spdif_edma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/src/fsl_src.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/src/fsl_src.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/ssarc/fsl_ssarc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/ssarc/fsl_ssarc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/tempmon/fsl_tempmon.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/tempmon/fsl_tempmon.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/tempsensor/fsl_tempsensor.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/tempsensor/fsl_tempsensor.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/trng/fsl_trng.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/trng/fsl_trng.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/usdhc/fsl_usdhc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/usdhc/fsl_usdhc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/wdog01/fsl_wdog.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/wdog01/fsl_wdog.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/xbara/fsl_xbara.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/xbara/fsl_xbara.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/xbarb/fsl_xbarb.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/xbarb/fsl_xbarb.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/xecc/fsl_xecc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/xecc/fsl_xecc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/xrdc2/fsl_xrdc2.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/xrdc2/fsl_xrdc2.h
 create mode 100644 spec/build/bsps/arm/imxrt/obj-mimxrt1011.yml
 create mode 100644 spec/build/bsps/arm/imxrt/obj-mimxrt1015.yml
 create mode 100644 spec/build/bsps/arm/imxrt/obj-mimxrt1024.yml
 create mode 100644 spec/build/bsps/arm/imxrt/obj-mimxrt1042.yml
 create mode 100644 spec/build/bsps/arm/imxrt/obj-mimxrt1051.yml
 create mode 100644 spec/build/bsps/arm/imxrt/obj-mimxrt1052.yml
 create mode 100644 spec/build/bsps/arm/imxrt/obj-mimxrt1061.yml
 create mode 100644 spec/build/bsps/arm/imxrt/obj-mimxrt1062.yml
 create mode 100644 spec/build/bsps/arm/imxrt/obj-mimxrt1064.yml
 create mode 100644 spec/build/bsps/arm/imxrt/obj-mimxrt1165-cm4.yml
 create mode 100644 spec/build/bsps/arm/imxrt/obj-mimxrt1165-cm7.yml
 create mode 100644 spec/build/bsps/arm/imxrt/obj-mimxrt1166-cm4.yml
 create mode 100644 spec/build/bsps/arm/imxrt/obj-mimxrt1166-cm7.yml
 create mode 100644 spec/build/bsps/arm/imxrt/obj-mimxrt1171-cm7.yml
 create mode 100644 spec/build/bsps/arm/imxrt/obj-mimxrt1172-cm7.yml
 create mode 100644 spec/build/bsps/arm/imxrt/obj-mimxrt1173-cm4.yml
 create mode 100644 spec/build/bsps/arm/imxrt/obj-mimxrt1173-cm7.yml
 create mode 100644 spec/build/bsps/arm/imxrt/obj-mimxrt1175-cm4.yml
 create mode 100644 spec/build/bsps/arm/imxrt/obj-mimxrt1175-cm7.yml
 create mode 100644 spec/build/bsps/arm/imxrt/obj-mimxrt1176-cm4.yml
 create mode 100644 spec/build/bsps/arm/imxrt/obj-mimxrt1176-cm7.yml
