[PATCH rtems 11/12] bsps/imxrt: Move board specific files
Christian Mauderer
christian.mauderer at embedded-brains.de
Thu May 4 15:00:52 UTC 2023
Move the files that are board specific and not specific to the chip
family into a separate folder.
.../evkbimxrt1050}/clock-arm-pll-config.c | 0
.../boards/evkbimxrt1050/clock_config.c | 0
.../evkbimxrt1050}/flash-dcd.c | 0
.../{nxp => }/boards/evkbimxrt1050/pin_mux.c | 0
spec/build/bsps/arm/imxrt/bspimxrt1052.yml | 19 ++++++++++++++++---
spec/build/bsps/arm/imxrt/obj.yml | 7 -------
6 files changed, 16 insertions(+), 10 deletions(-)
rename bsps/arm/imxrt/{start => boards/evkbimxrt1050}/clock-arm-pll-config.c (100%)
rename bsps/arm/imxrt/{nxp => }/boards/evkbimxrt1050/clock_config.c (100%)
rename bsps/arm/imxrt/{start => boards/evkbimxrt1050}/flash-dcd.c (100%)
rename bsps/arm/imxrt/{nxp => }/boards/evkbimxrt1050/pin_mux.c (100%)
diff --git a/bsps/arm/imxrt/start/clock-arm-pll-config.c b/bsps/arm/imxrt/boards/evkbimxrt1050/clock-arm-pll-config.c
similarity index 100%
rename from bsps/arm/imxrt/start/clock-arm-pll-config.c
rename to bsps/arm/imxrt/boards/evkbimxrt1050/clock-arm-pll-config.c
diff --git a/bsps/arm/imxrt/nxp/boards/evkbimxrt1050/clock_config.c b/bsps/arm/imxrt/boards/evkbimxrt1050/clock_config.c
rename from bsps/arm/imxrt/nxp/boards/evkbimxrt1050/clock_config.c
rename to bsps/arm/imxrt/boards/evkbimxrt1050/clock_config.c
diff --git a/bsps/arm/imxrt/start/flash-dcd.c b/bsps/arm/imxrt/boards/evkbimxrt1050/flash-dcd.c
rename from bsps/arm/imxrt/start/flash-dcd.c
rename to bsps/arm/imxrt/boards/evkbimxrt1050/flash-dcd.c
diff --git a/bsps/arm/imxrt/nxp/boards/evkbimxrt1050/pin_mux.c b/bsps/arm/imxrt/boards/evkbimxrt1050/pin_mux.c
rename from bsps/arm/imxrt/nxp/boards/evkbimxrt1050/pin_mux.c
rename to bsps/arm/imxrt/boards/evkbimxrt1050/pin_mux.c
diff --git a/spec/build/bsps/arm/imxrt/bspimxrt1052.yml b/spec/build/bsps/arm/imxrt/bspimxrt1052.yml
index 348b90bcdb..6c2b3339f9 100644
--- a/spec/build/bsps/arm/imxrt/bspimxrt1052.yml
+++ b/spec/build/bsps/arm/imxrt/bspimxrt1052.yml
@@ -8,10 +8,23 @@ copyrights:
cppflags: []
enabled-by: true
family: imxrt
-includes: []
-install: []
+includes:
+- bsps/arm/imxrt/mcux-sdk/drivers/common
+- bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1052
+- bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1052/drivers
+- bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1052/xip
+install:
+- destination: ${BSP_INCLUDEDIR}/imxrt
+ source:
+ - bsps/arm/imxrt/include/imxrt/imxrt1050.dtsi
+ - bsps/arm/imxrt/include/imxrt/imxrt1050-pinfunc.h
links:
- role: build-dependency
uid: obj-mimxrt1052
-source: []
+source:
+- bsps/arm/imxrt/boards/evkbimxrt1050/clock_config.c
+- bsps/arm/imxrt/boards/evkbimxrt1050/flash-dcd.c
+- bsps/arm/imxrt/boards/evkbimxrt1050/pin_mux.c
+- bsps/arm/imxrt/boards/evkbimxrt1050/clock-arm-pll-config.c
+- bsps/arm/imxrt/dts/imxrt1050-evkb.c
type: build
diff --git a/spec/build/bsps/arm/imxrt/obj.yml b/spec/build/bsps/arm/imxrt/obj.yml
index 96d487dd8b..30ed2fb1d2 100644
--- a/spec/build/bsps/arm/imxrt/obj.yml
+++ b/spec/build/bsps/arm/imxrt/obj.yml
@@ -26,8 +26,6 @@ install:
- bsps/arm/include/bsp/imx-iomux.h
source:
- - bsps/arm/imxrt/include/imxrt/imxrt1050.dtsi
- - bsps/arm/imxrt/include/imxrt/imxrt1050-pinfunc.h
- bsps/arm/imxrt/include/imxrt/lpspi.h
- bsps/arm/imxrt/include/imxrt/memory.h
- bsps/arm/imxrt/include/imxrt/mpu-config.h
@@ -39,16 +37,11 @@ install:
links: []
source:
- bsps/arm/imxrt/console/console.c
-- bsps/arm/imxrt/dts/imxrt1050-evkb.c
- bsps/arm/imxrt/i2c/imxrt-lpi2c.c
-- bsps/arm/imxrt/nxp/boards/evkbimxrt1050/clock_config.c
-- bsps/arm/imxrt/nxp/boards/evkbimxrt1050/pin_mux.c
- bsps/arm/imxrt/spi/imxrt-lpspi.c
- bsps/arm/imxrt/start/bspstart.c
- bsps/arm/imxrt/start/bspstarthooks.c
-- bsps/arm/imxrt/start/clock-arm-pll-config.c
- bsps/arm/imxrt/start/flash-boot-data.c
-- bsps/arm/imxrt/start/flash-dcd.c
- bsps/arm/imxrt/start/flash-flexspi-config.c
- bsps/arm/imxrt/start/flash-ivt.c
- bsps/arm/imxrt/start/imxrt-ffec-init.c
2.35.3
