[PATCH 03/12] eng: Add conditional build dependencies
Fri May 5 08:46:00 UTC 2023
Update #3715.
 eng/req/items.rst | 18 ++++++++++++++++++
 1 file changed, 18 insertions(+)
diff --git a/eng/req/items.rst b/eng/req/items.rst
index 6b2f91b..61ba54d 100644
--- a/eng/req/items.rst
+++ b/eng/req/items.rst
@@ -3037,6 +3037,20 @@ This type is used by the following types:
 * :ref:`SpecTypeBuildTestProgramItemType`
+.. _SpecTypeBuildDependencyConditionalLinkRole:
+Build Dependency Conditional Link Role
+This type refines the :ref:`SpecTypeLink` through the ``role`` attribute if the
+value is ``build-dependency-conditional``. It defines the build dependency
+conditional role of links. All explicit attributes shall be specified. The
+explicit attributes for this type are:
+enabled-by
+    The attribute value shall be an :ref:`SpecTypeEnabledByExpression`. It
+    shall define under which conditions the build dependency is enabled.
 .. _SpecTypeBuildDependencyLinkRole:
 Build Dependency Link Role
@@ -3681,6 +3695,8 @@ This type is used by the following types:
 * :ref:`SpecTypeActionRequirementTransition`
+* :ref:`SpecTypeBuildDependencyConditionalLinkRole`
 * :ref:`SpecTypeBuildOptionDefaultValue`
 * :ref:`SpecTypeEnabledByExpression`
@@ -4507,6 +4523,8 @@ This type is refined by the following types:
 * :ref:`SpecTypeApplicationConfigurationGroupMemberLinkRole`
 * :ref:`SpecTypeBuildDependencyLinkRole`
 * :ref:`SpecTypeConstraintLinkRole`
2.35.3
