[PATCH rtems 00/12] bsp/imxrt: Update SDK and prepare for new variant
Fri May 5 13:56:24 UTC 2023
On Thu, May 4, 2023 at 9:01 AM Christian Mauderer
<christian.mauderer at embedded-brains.de> wrote:
> Hello,
> this patch set for the arm/imxrt BSP family updates the SDK files to the
> latest version of the mcux-sdk from NXP and prepares the BSP for further
> chip variants. I plan to add a BSP that uses the IMXRT1166 soon.
> As a base for the mcux-sdk files, I now use the NXP git repository
> instead of zip files that can be downloaded from NXP. I kept the exact
> file system structure to make future updates simpler.
> To import the files, I used a script. It is not a clean script and it
> was only tested on a Linux machine. Despite that, I added that script to
> the BSP directory in case someone else ever wants to update the
> mcux-sdk. Updating the SDK is also possible without the script. It's
> just a lot more manual work. So if we don't want a script in that state
> in the repository, I can also just keep it on a private branch.
I would recommend that you document the import/update process for the
SDK in this BSP (or family) documentation. You could provide a stable
external link to the script there instead of including it in the
rtems.git tree. I'm not convinced that including scripts etc in the
same tree as the source they manipulate is a great practice. It seems
to violate separation of concerns.
> The patches that import the new SDK files (patch 0002) and remove the
> old ones (patch 0004) are too big for the list. I'll only send the
> summary. You can find the full patches here:
>   0002: https://gitlab.com/c-mauderer/rtems/-/commit/2a871672767a95598e5af42373bfebd3eb9440d3
>   0004: https://gitlab.com/c-mauderer/rtems/-/commit/2a3e104fa808d7f34a1930344d7b39d11cf39f3d
> The complete patch set is on this branch:
>   https://gitlab.com/c-mauderer/rtems/-/commits/cm/20230504_imxrt/
> At the moment, I import the support files for all currently available
> i.MXRT* variants. The headers for the CPU registers are really big (a
> few megabytes per header) which makes the complete source tree of the
> mcux-sdk bigger than 90MB. If preferred, I can remove most variants and
> only keep the ones that are currently used or will be used soon
> (IMXRT1052 and IMXRT1166) to reduce the size.
Thanks, I think this is fine. The increase in the number of HAL/SDK
that we have to import is starting to concern me in general. I wonder
if there is a better way to manage these external sources.
> Best regards
> Christian
> devel mailing list
> devel at rtems.org
