[rtems-source-builder] devel/qemu-xilinx: Fix source URL
    Alex White
    alex.white at oarcorp.com
    Fri May  5 14:17:41 UTC 2023
The source URL for Xilinx QEMU appears to have been incorrect from the
start. Since we are cloning a git repository, we should use 'git://'.
 bare/config/devel/qemu-xilinx-v2020.2-1.cfg | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/bare/config/devel/qemu-xilinx-v2020.2-1.cfg b/bare/config/devel/qemu-xilinx-v2020.2-1.cfg
index 180b621..2c3fb94 100644
--- a/bare/config/devel/qemu-xilinx-v2020.2-1.cfg
+++ b/bare/config/devel/qemu-xilinx-v2020.2-1.cfg
@@ -15,7 +15,7 @@
 # Checkout the version tag and initialize all submodules.
-%source set qemu https://github.com/Xilinx/qemu.git?checkout=%{qemu_version}?submodule=dtc?submodule=slirp?submodule=ui/keycodemapdb?submodule=tests/fp/berkeley-softfloat-3?submodule=tests/fp/berkeley-testfloat-3
+%source set qemu git://github.com/Xilinx/qemu.git?protocol=https?checkout=%{qemu_version}?submodule=dtc?submodule=slirp?submodule=ui/keycodemapdb?submodule=tests/fp/berkeley-softfloat-3?submodule=tests/fp/berkeley-testfloat-3
 # The Qemu build instructions. We use 5.x.x Release 1.
2.34.1
