[PATCH 07/10] validation: Improve formatting
Sebastian Huber
Mon May 8 20:11:58 UTC 2023
This enables automatic Doxygen links.
Update #3716.
testsuites/validation/tc-attr.c | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/testsuites/validation/tc-attr.c b/testsuites/validation/tc-attr.c
index 1b4cea0fe6..aae115cc72 100644
--- a/testsuites/validation/tc-attr.c
+++ b/testsuites/validation/tc-attr.c
@@ -124,7 +124,7 @@
* - Check the value of RTEMS_DEFAULT_ATTRIBUTES.
- * - Check RTEMS_DEFAULT_ATTRIBUTES equals ``RTEMS_FIFO | RTEMS_LOCAL``.
+ * - Check RTEMS_DEFAULT_ATTRIBUTES equals RTEMS_FIFO | RTEMS_LOCAL.
@@ -324,7 +324,7 @@ static void RtemsAttrValAttr_Action_4( void )
/* No action */
- * Check RTEMS_DEFAULT_ATTRIBUTES equals ``RTEMS_FIFO | RTEMS_LOCAL``.
+ * Check RTEMS_DEFAULT_ATTRIBUTES equals RTEMS_FIFO | RTEMS_LOCAL.
T_step_eq_int(
22,
2.35.3
