[PATCH] rtems: Reference types in construct directives
Sebastian Huber
Tue May 9 12:03:40 UTC 2023
cpukit/include/rtems/rtems/message.h | 3 ++-
cpukit/include/rtems/rtems/tasks.h | 3 ++-
2 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/cpukit/include/rtems/rtems/message.h b/cpukit/include/rtems/rtems/message.h
index cd951f584b..d1432ffbb8 100644
--- a/cpukit/include/rtems/rtems/message.h
+++ b/cpukit/include/rtems/rtems/message.h
@@ -292,7 +292,8 @@ rtems_status_code rtems_message_queue_create(
* @brief Constructs a message queue from the specified the message queue
* configuration.
- * @param config is the message queue configuration.
+ * @param config is the pointer to an rtems_message_queue_config object. It
+ * configures the message queue.
* @param[out] id is the pointer to an ::rtems_id object. When the directive
* call is successful, the identifier of the constructed message queue will
diff --git a/cpukit/include/rtems/rtems/tasks.h b/cpukit/include/rtems/rtems/tasks.h
index 3214dad3f8..57ca618c48 100644
--- a/cpukit/include/rtems/rtems/tasks.h
+++ b/cpukit/include/rtems/rtems/tasks.h
@@ -671,7 +671,8 @@ rtems_status_code rtems_task_create(
* @brief Constructs a task from the specified task configuration.
- * @param config is the task configuration.
+ * @param config is the pointer to an rtems_task_config object. It configures
+ * the task.
* call is successful, the identifier of the constructed task will be stored
2.35.3
