[PATCH rtems v2 01/12] bsp/imxrt: Update support library from mcux-sdk
Christian Mauderer christian.mauderer at embedded-brains.de
Tue May 9 12:10:48 UTC 2023
This imports new files from the mcux-sdk support library. NXP now offers
the library as a git repository instead of a zip package. The git
repository supports multiple CPUs from the i.MXRT family:
  https://github.com/nxp-mcuxpresso/mcux-sdk.git
The imported files are from revision
  2b9354539e6e4f722749e87b0bdc22966dc080d9
This revision is the same as MCUXpresso 2.13.0 with small bug fixes.
For importing the files, a script has been used, that parses the
mcux-sdk cmake files and creates the yaml files for RTEMS:
https://raw.githubusercontent.com/c-mauderer/nxp-mcux-sdk/d21c3e61eb8602b2cf8f45fed0afa50c6aee932f/export_to_RTEMS.py
NOTE: Due to the size, this is only the summary of the patch. You can find the
full version here:
https://gitlab.com/c-mauderer/rtems/-/commit/db46669083517749fea88b3440dbfc71adf6347c
 .../mcux-sdk/devices/MIMXRT1052/MIMXRT1052.h  | 53558 +++++++++
 .../devices/MIMXRT1052/MIMXRT1052_features.h  |   785 +
 .../devices/MIMXRT1052/drivers/fsl_clock.c    |  1535 +
 .../devices/MIMXRT1052/drivers/fsl_clock.h    |  2038 +
 .../MIMXRT1052/drivers/fsl_flexram_allocate.c |    86 +
 .../MIMXRT1052/drivers/fsl_flexram_allocate.h |    87 +
 .../devices/MIMXRT1052/drivers/fsl_iomuxc.h   |  1241 +
 .../devices/MIMXRT1052/drivers/fsl_nic301.h   |   308 +
 .../devices/MIMXRT1052/drivers/fsl_romapi.c   |   162 +
 .../devices/MIMXRT1052/drivers/fsl_romapi.h   |   565 +
 .../devices/MIMXRT1052/fsl_device_registers.h |    36 +
 .../MIMXRT1052/gcc/startup_MIMXRT1052.S       |  1077 +
 .../devices/MIMXRT1052/system_MIMXRT1052.c    |   242 +
 .../devices/MIMXRT1052/system_MIMXRT1052.h    |   131 +
 .../MIMXRT1052/xip/fsl_flexspi_nor_boot.c     |    49 +
 .../MIMXRT1052/xip/fsl_flexspi_nor_boot.h     |   124 +
 .../devices/MIMXRT1166/MIMXRT1166_cm4.h       | 93964 ++++++++++++++++
 .../MIMXRT1166/MIMXRT1166_cm4_features.h      |   903 +
 .../devices/MIMXRT1166/MIMXRT1166_cm7.h       | 93031 +++++++++++++++
 .../MIMXRT1166/MIMXRT1166_cm7_features.h      |   890 +
 .../MIMXRT1166/drivers/cm4/fsl_cache.c        |   507 +
 .../MIMXRT1166/drivers/cm4/fsl_cache.h        |   340 +
 .../MIMXRT1166/drivers/cm7/fsl_cache.c        |   602 +
 .../MIMXRT1166/drivers/cm7/fsl_cache.h        |   463 +
 .../MIMXRT1166/drivers/fsl_anatop_ai.c        |   357 +
 .../MIMXRT1166/drivers/fsl_anatop_ai.h        |   533 +
 .../devices/MIMXRT1166/drivers/fsl_clock.c    |  1929 +
 .../devices/MIMXRT1166/drivers/fsl_clock.h    |  3308 +
 .../devices/MIMXRT1166/drivers/fsl_dcdc.c     |   518 +
 .../devices/MIMXRT1166/drivers/fsl_dcdc.h     |  1013 +
 .../MIMXRT1166/drivers/fsl_flexram_allocate.c |    92 +
 .../MIMXRT1166/drivers/fsl_flexram_allocate.h |    87 +
 .../devices/MIMXRT1166/drivers/fsl_gpc.c      |   335 +
 .../devices/MIMXRT1166/drivers/fsl_gpc.h      |   651 +
 .../devices/MIMXRT1166/drivers/fsl_iomuxc.h   |  1770 +
 .../devices/MIMXRT1166/drivers/fsl_memory.h   |    89 +
 .../devices/MIMXRT1166/drivers/fsl_nic301.h   |   293 +
 .../devices/MIMXRT1166/drivers/fsl_pgmc.c     |   461 +
 .../devices/MIMXRT1166/drivers/fsl_pgmc.h     |   783 +
 .../devices/MIMXRT1166/drivers/fsl_pmu.c      |   959 +
 .../devices/MIMXRT1166/drivers/fsl_pmu.h      |   855 +
 .../devices/MIMXRT1166/drivers/fsl_romapi.c   |   250 +
 .../devices/MIMXRT1166/drivers/fsl_romapi.h   |   724 +
 .../MIMXRT1166/drivers/fsl_soc_mipi_csi2rx.c  |    71 +
 .../MIMXRT1166/drivers/fsl_soc_mipi_csi2rx.h  |    66 +
 .../devices/MIMXRT1166/drivers/fsl_soc_src.c  |   183 +
 .../devices/MIMXRT1166/drivers/fsl_soc_src.h  |   754 +
 .../devices/MIMXRT1166/fsl_device_registers.h |    44 +
 .../MIMXRT1166/gcc/startup_MIMXRT1166_cm4.S   |  1421 +
 .../MIMXRT1166/gcc/startup_MIMXRT1166_cm7.S   |  1421 +
 .../MIMXRT1166/system_MIMXRT1166_cm4.c        |   176 +
 .../MIMXRT1166/system_MIMXRT1166_cm4.h        |   118 +
 .../MIMXRT1166/system_MIMXRT1166_cm7.c        |   159 +
 .../MIMXRT1166/system_MIMXRT1166_cm7.h        |   118 +
 .../MIMXRT1166/xip/fsl_flexspi_nor_boot.c     |    49 +
 .../MIMXRT1166/xip/fsl_flexspi_nor_boot.h     |   149 +
 .../imxrt/mcux-sdk/drivers/acmp/fsl_acmp.c    |   662 +
 .../imxrt/mcux-sdk/drivers/acmp/fsl_acmp.h    |   536 +
 .../drivers/adc_12b1msps_sar/fsl_adc.c        |   395 +
 .../drivers/adc_12b1msps_sar/fsl_adc.h        |   427 +
 .../mcux-sdk/drivers/adc_etc/fsl_adc_etc.c    |   464 +
 .../mcux-sdk/drivers/adc_etc/fsl_adc_etc.h    |   352 +
 bsps/arm/imxrt/mcux-sdk/drivers/aoi/fsl_aoi.c |   214 +
 bsps/arm/imxrt/mcux-sdk/drivers/aoi/fsl_aoi.h |   186 +
 .../imxrt/mcux-sdk/drivers/asrc/fsl_asrc.c    |  1031 +
 .../imxrt/mcux-sdk/drivers/asrc/fsl_asrc.h    |   761 +
 .../mcux-sdk/drivers/asrc/fsl_asrc_edma.c     |   470 +
 .../mcux-sdk/drivers/asrc/fsl_asrc_edma.h     |   245 +
 bsps/arm/imxrt/mcux-sdk/drivers/bee/fsl_bee.c |   303 +
 bsps/arm/imxrt/mcux-sdk/drivers/bee/fsl_bee.h |   254 +
 .../drivers/cache/armv7-m7/fsl_cache.c        |   602 +
 .../drivers/cache/armv7-m7/fsl_cache.h        |   463 +
 .../imxrt/mcux-sdk/drivers/cdog/fsl_cdog.c    |   314 +
 .../imxrt/mcux-sdk/drivers/cdog/fsl_cdog.h    |   325 +
 bsps/arm/imxrt/mcux-sdk/drivers/cmp/fsl_cmp.c |   371 +
 bsps/arm/imxrt/mcux-sdk/drivers/cmp/fsl_cmp.h |   321 +
 .../mcux-sdk/drivers/common/fsl_common.c      |    86 +
 .../mcux-sdk/drivers/common/fsl_common.h      |   331 +
 .../mcux-sdk/drivers/common/fsl_common_arm.c  |   249 +
 .../mcux-sdk/drivers/common/fsl_common_arm.h  |   837 +
 .../mcux-sdk/drivers/common/fsl_common_dsp.h  |   170 +
 bsps/arm/imxrt/mcux-sdk/drivers/csi/fsl_csi.c |  1417 +
 bsps/arm/imxrt/mcux-sdk/drivers/csi/fsl_csi.h |   730 +
 .../imxrt/mcux-sdk/drivers/dac12/fsl_dac12.c  |   200 +
 .../imxrt/mcux-sdk/drivers/dac12/fsl_dac12.h  |   418 +
 .../imxrt/mcux-sdk/drivers/dcdc_1/fsl_dcdc.c  |   913 +
 .../imxrt/mcux-sdk/drivers/dcdc_1/fsl_dcdc.h  |   735 +
 .../imxrt/mcux-sdk/drivers/dcic/fsl_dcic.c    |   174 +
 .../imxrt/mcux-sdk/drivers/dcic/fsl_dcic.h    |   380 +
 bsps/arm/imxrt/mcux-sdk/drivers/dcp/fsl_dcp.c |  1461 +
 bsps/arm/imxrt/mcux-sdk/drivers/dcp/fsl_dcp.h |   580 +
 .../mcux-sdk/drivers/dmamux/fsl_dmamux.c      |    91 +
 .../mcux-sdk/drivers/dmamux/fsl_dmamux.h      |   189 +
 .../imxrt/mcux-sdk/drivers/edma/fsl_edma.c    |  2858 +
 .../imxrt/mcux-sdk/drivers/edma/fsl_edma.h    |  1018 +
 .../mcux-sdk/drivers/elcdif/fsl_elcdif.c      |   387 +
 .../mcux-sdk/drivers/elcdif/fsl_elcdif.h      |   767 +
 bsps/arm/imxrt/mcux-sdk/drivers/enc/fsl_enc.c |   625 +
 bsps/arm/imxrt/mcux-sdk/drivers/enc/fsl_enc.h |   562 +
 .../imxrt/mcux-sdk/drivers/enet/fsl_enet.c    |  3993 +
 .../imxrt/mcux-sdk/drivers/enet/fsl_enet.h    |  2046 +
 bsps/arm/imxrt/mcux-sdk/drivers/ewm/fsl_ewm.c |   140 +
 bsps/arm/imxrt/mcux-sdk/drivers/ewm/fsl_ewm.h |   218 +
 .../mcux-sdk/drivers/flexcan/fsl_flexcan.c    |  4613 +
 .../mcux-sdk/drivers/flexcan/fsl_flexcan.h    |  2241 +
 .../drivers/flexcan/fsl_flexcan_edma.h        |   188 +
 .../mcux-sdk/drivers/flexio/fsl_flexio.c      |   433 +
 .../mcux-sdk/drivers/flexio/fsl_flexio.h      |   735 +
 .../drivers/flexio/fsl_flexio_camera.h        |   230 +
 .../drivers/flexio/fsl_flexio_camera_edma.h   |   130 +
 .../drivers/flexio/fsl_flexio_i2c_master.c    |  1377 +
 .../drivers/flexio/fsl_flexio_i2c_master.h    |   485 +
 .../mcux-sdk/drivers/flexio/fsl_flexio_i2s.c  |   903 +
 .../mcux-sdk/drivers/flexio/fsl_flexio_i2s.h  |   560 +
 .../drivers/flexio/fsl_flexio_i2s_dma.h       |   198 +
 .../drivers/flexio/fsl_flexio_i2s_edma.c      |   445 +
 .../drivers/flexio/fsl_flexio_i2s_edma.h      |   201 +
 .../drivers/flexio/fsl_flexio_mculcd.h        |   685 +
 .../drivers/flexio/fsl_flexio_mculcd_edma.h   |   153 +
 .../flexio/fsl_flexio_mculcd_smartdma.h       |   158 +
 .../mcux-sdk/drivers/flexio/fsl_flexio_spi.c  |  1553 +
 .../mcux-sdk/drivers/flexio/fsl_flexio_spi.h  |   719 +
 .../drivers/flexio/fsl_flexio_spi_dma.h       |   205 +
 .../drivers/flexio/fsl_flexio_spi_edma.c      |   565 +
 .../drivers/flexio/fsl_flexio_spi_edma.h      |   207 +
 .../mcux-sdk/drivers/flexio/fsl_flexio_uart.c |  1009 +
 .../mcux-sdk/drivers/flexio/fsl_flexio_uart.h |   581 +
 .../drivers/flexio/fsl_flexio_uart_dma.h      |   176 +
 .../drivers/flexio/fsl_flexio_uart_edma.c     |   407 +
 .../drivers/flexio/fsl_flexio_uart_edma.h     |   178 +
 .../mcux-sdk/drivers/flexram/fsl_flexram.c    |   423 +
 .../mcux-sdk/drivers/flexram/fsl_flexram.h    |   508 +
 .../mcux-sdk/drivers/flexspi/fsl_flexspi.c    |  1271 +
 .../mcux-sdk/drivers/flexspi/fsl_flexspi.h    |   886 +
 .../drivers/flexspi/fsl_flexspi_dma.h         |   144 +
 .../drivers/flexspi/fsl_flexspi_edma.c        |   366 +
 .../drivers/flexspi/fsl_flexspi_edma.h        |   150 +
 .../imxrt/mcux-sdk/drivers/gpc_1/fsl_gpc.c    |   103 +
 .../imxrt/mcux-sdk/drivers/gpc_1/fsl_gpc.h    |   231 +
 bsps/arm/imxrt/mcux-sdk/drivers/gpt/fsl_gpt.c |   127 +
 bsps/arm/imxrt/mcux-sdk/drivers/gpt/fsl_gpt.h |   509 +
 bsps/arm/imxrt/mcux-sdk/drivers/iee/fsl_iee.c |   141 +
 bsps/arm/imxrt/mcux-sdk/drivers/iee/fsl_iee.h |   181 +
 .../mcux-sdk/drivers/iee_apc/fsl_iee_apc.c    |   391 +
 .../mcux-sdk/drivers/iee_apc/fsl_iee_apc.h    |   124 +
 .../imxrt/mcux-sdk/drivers/igpio/fsl_gpio.c   |   183 +
 .../imxrt/mcux-sdk/drivers/igpio/fsl_gpio.h   |   344 +
 .../drivers/key_manager/fsl_key_manager.c     |   218 +
 .../drivers/key_manager/fsl_key_manager.h     |   181 +
 bsps/arm/imxrt/mcux-sdk/drivers/kpp/fsl_kpp.c |   203 +
 bsps/arm/imxrt/mcux-sdk/drivers/kpp/fsl_kpp.h |   180 +
 .../mcux-sdk/drivers/lcdifv2/fsl_lcdifv2.c    |   527 +
 .../mcux-sdk/drivers/lcdifv2/fsl_lcdifv2.h    |   655 +
 .../imxrt/mcux-sdk/drivers/lpadc/fsl_lpadc.c  |   708 +
 .../imxrt/mcux-sdk/drivers/lpadc/fsl_lpadc.h  |  1070 +
 .../imxrt/mcux-sdk/drivers/lpi2c/fsl_lpi2c.c  |  2608 +
 .../imxrt/mcux-sdk/drivers/lpi2c/fsl_lpi2c.h  |  1320 +
 .../mcux-sdk/drivers/lpi2c/fsl_lpi2c_edma.c   |   616 +
 .../mcux-sdk/drivers/lpi2c/fsl_lpi2c_edma.h   |   158 +
 .../drivers/lpi2c/fsl_lpi2c_freertos.h        |   107 +
 .../imxrt/mcux-sdk/drivers/lpspi/fsl_lpspi.c  |  2421 +
 .../imxrt/mcux-sdk/drivers/lpspi/fsl_lpspi.h  |  1158 +
 .../mcux-sdk/drivers/lpspi/fsl_lpspi_edma.c   |  1052 +
 .../mcux-sdk/drivers/lpspi/fsl_lpspi_edma.h   |   301 +
 .../drivers/lpspi/fsl_lpspi_freertos.h        |   107 +
 .../mcux-sdk/drivers/lpuart/fsl_lpuart.c      |  2351 +
 .../mcux-sdk/drivers/lpuart/fsl_lpuart.h      |  1064 +
 .../mcux-sdk/drivers/lpuart/fsl_lpuart_dma.h  |   186 +
 .../mcux-sdk/drivers/lpuart/fsl_lpuart_edma.c |   503 +
 .../mcux-sdk/drivers/lpuart/fsl_lpuart_edma.h |   189 +
 .../drivers/lpuart/fsl_lpuart_freertos.h      |   192 +
 .../imxrt/mcux-sdk/drivers/mecc/fsl_mecc.c    |   340 +
 .../imxrt/mcux-sdk/drivers/mecc/fsl_mecc.h    |   396 +
 .../drivers/mipi_csi2rx/fsl_mipi_csi2rx.c     |   260 +
 .../drivers/mipi_csi2rx/fsl_mipi_csi2rx.h     |   383 +
 .../drivers/mipi_dsi_split/fsl_mipi_dsi.c     |  1433 +
 .../drivers/mipi_dsi_split/fsl_mipi_dsi.h     |   824 +
 bsps/arm/imxrt/mcux-sdk/drivers/mu/fsl_mu.c   |   414 +
 bsps/arm/imxrt/mcux-sdk/drivers/mu/fsl_mu.h   |   752 +
 .../imxrt/mcux-sdk/drivers/ocotp/fsl_ocotp.c  |   406 +
 .../imxrt/mcux-sdk/drivers/ocotp/fsl_ocotp.h  |   211 +
 bsps/arm/imxrt/mcux-sdk/drivers/pdm/fsl_pdm.c |   963 +
 bsps/arm/imxrt/mcux-sdk/drivers/pdm/fsl_pdm.h |  1213 +
 .../imxrt/mcux-sdk/drivers/pdm/fsl_pdm_edma.c |   459 +
 .../imxrt/mcux-sdk/drivers/pdm/fsl_pdm_edma.h |   254 +
 .../imxrt/mcux-sdk/drivers/pdm/fsl_pdm_sdma.h |   140 +
 bsps/arm/imxrt/mcux-sdk/drivers/pit/fsl_pit.c |   146 +
 bsps/arm/imxrt/mcux-sdk/drivers/pit/fsl_pit.h |   334 +
 bsps/arm/imxrt/mcux-sdk/drivers/puf/fsl_puf.c |   949 +
 bsps/arm/imxrt/mcux-sdk/drivers/puf/fsl_puf.h |   335 +
 bsps/arm/imxrt/mcux-sdk/drivers/pwm/fsl_pwm.c |  1328 +
 bsps/arm/imxrt/mcux-sdk/drivers/pwm/fsl_pwm.h |  1225 +
 bsps/arm/imxrt/mcux-sdk/drivers/pxp/fsl_pxp.c |  2188 +
 bsps/arm/imxrt/mcux-sdk/drivers/pxp/fsl_pxp.h |  2712 +
 .../imxrt/mcux-sdk/drivers/qtmr_1/fsl_qtmr.c  |   729 +
 .../imxrt/mcux-sdk/drivers/qtmr_1/fsl_qtmr.h  |   529 +
 bsps/arm/imxrt/mcux-sdk/drivers/rdc/fsl_rdc.c |   310 +
 bsps/arm/imxrt/mcux-sdk/drivers/rdc/fsl_rdc.h |   447 +
 .../drivers/rdc_sema42/fsl_rdc_sema42.c       |   236 +
 .../drivers/rdc_sema42/fsl_rdc_sema42.h       |   194 +
 .../mcux-sdk/drivers/rtwdog/fsl_rtwdog.c      |   148 +
 .../mcux-sdk/drivers/rtwdog/fsl_rtwdog.h      |   425 +
 bsps/arm/imxrt/mcux-sdk/drivers/sai/fsl_sai.c |  3831 +
 bsps/arm/imxrt/mcux-sdk/drivers/sai/fsl_sai.h |  1586 +
 .../imxrt/mcux-sdk/drivers/sai/fsl_sai_edma.c |  1033 +
 .../imxrt/mcux-sdk/drivers/sai/fsl_sai_edma.h |   367 +
 .../imxrt/mcux-sdk/drivers/sai/fsl_sai_sdma.h |   238 +
 .../imxrt/mcux-sdk/drivers/sema4/fsl_sema4.c  |   252 +
 .../imxrt/mcux-sdk/drivers/sema4/fsl_sema4.h  |   260 +
 .../imxrt/mcux-sdk/drivers/semc/fsl_semc.c    |  1385 +
 .../imxrt/mcux-sdk/drivers/semc/fsl_semc.h    |   924 +
 .../drivers/smartcard/fsl_smartcard.h         |   274 +
 .../drivers/smartcard/fsl_smartcard_emvsim.c  |  1143 +
 .../drivers/smartcard/fsl_smartcard_emvsim.h  |   182 +
 .../drivers/smartcard/fsl_smartcard_phy.h     |   127 +
 .../smartcard/fsl_smartcard_phy_emvsim.c      |   227 +
 .../mcux-sdk/drivers/snvs_hp/fsl_snvs_hp.c    |   565 +
 .../mcux-sdk/drivers/snvs_hp/fsl_snvs_hp.h    |   649 +
 .../mcux-sdk/drivers/snvs_lp/fsl_snvs_lp.c    |  1358 +
 .../mcux-sdk/drivers/snvs_lp/fsl_snvs_lp.h    |   733 +
 .../imxrt/mcux-sdk/drivers/spdif/fsl_spdif.c  |   849 +
 .../imxrt/mcux-sdk/drivers/spdif/fsl_spdif.h  |   753 +
 .../mcux-sdk/drivers/spdif/fsl_spdif_edma.c   |   598 +
 .../mcux-sdk/drivers/spdif/fsl_spdif_edma.h   |   192 +
 bsps/arm/imxrt/mcux-sdk/drivers/src/fsl_src.c |    49 +
 bsps/arm/imxrt/mcux-sdk/drivers/src/fsl_src.h |   602 +
 .../imxrt/mcux-sdk/drivers/ssarc/fsl_ssarc.c  |   179 +
 .../imxrt/mcux-sdk/drivers/ssarc/fsl_ssarc.h  |   474 +
 .../mcux-sdk/drivers/tempmon/fsl_tempmon.c    |   204 +
 .../mcux-sdk/drivers/tempmon/fsl_tempmon.h    |   127 +
 .../drivers/tempsensor/fsl_tempsensor.c       |   368 +
 .../drivers/tempsensor/fsl_tempsensor.h       |   186 +
 .../imxrt/mcux-sdk/drivers/trng/fsl_trng.c    |  2009 +
 .../imxrt/mcux-sdk/drivers/trng/fsl_trng.h    |   239 +
 .../imxrt/mcux-sdk/drivers/usdhc/fsl_usdhc.c  |  2480 +
 .../imxrt/mcux-sdk/drivers/usdhc/fsl_usdhc.h  |  1703 +
 .../imxrt/mcux-sdk/drivers/wdog01/fsl_wdog.c  |   214 +
 .../imxrt/mcux-sdk/drivers/wdog01/fsl_wdog.h  |   305 +
 .../imxrt/mcux-sdk/drivers/xbara/fsl_xbara.c  |   229 +
 .../imxrt/mcux-sdk/drivers/xbara/fsl_xbara.h  |   186 +
 .../imxrt/mcux-sdk/drivers/xbarb/fsl_xbarb.c  |   126 +
 .../imxrt/mcux-sdk/drivers/xbarb/fsl_xbarb.h  |    82 +
 .../imxrt/mcux-sdk/drivers/xecc/fsl_xecc.c    |   148 +
 .../imxrt/mcux-sdk/drivers/xecc/fsl_xecc.h    |   322 +
 .../imxrt/mcux-sdk/drivers/xrdc2/fsl_xrdc2.c  |   925 +
 .../imxrt/mcux-sdk/drivers/xrdc2/fsl_xrdc2.h  |   690 +
 spec/build/bsps/arm/imxrt/obj-mimxrt1052.yml  |   212 +
 .../bsps/arm/imxrt/obj-mimxrt1166-cm4.yml     |   268 +
 .../bsps/arm/imxrt/obj-mimxrt1166-cm7.yml     |   289 +
 249 files changed, 397048 insertions(+)
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1052/MIMXRT1052.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1052/MIMXRT1052_features.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1052/drivers/fsl_clock.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1052/drivers/fsl_clock.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1052/drivers/fsl_flexram_allocate.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1052/drivers/fsl_flexram_allocate.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1052/drivers/fsl_iomuxc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1052/drivers/fsl_nic301.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1052/drivers/fsl_romapi.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1052/drivers/fsl_romapi.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1052/fsl_device_registers.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1052/gcc/startup_MIMXRT1052.S
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1052/system_MIMXRT1052.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1052/system_MIMXRT1052.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1052/xip/fsl_flexspi_nor_boot.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1052/xip/fsl_flexspi_nor_boot.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/MIMXRT1166_cm4.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/MIMXRT1166_cm4_features.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/MIMXRT1166_cm7.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/MIMXRT1166_cm7_features.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/cm4/fsl_cache.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/cm4/fsl_cache.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/cm7/fsl_cache.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/cm7/fsl_cache.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_anatop_ai.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_anatop_ai.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_clock.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_clock.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_dcdc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_dcdc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_flexram_allocate.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_flexram_allocate.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_gpc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_gpc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_iomuxc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_memory.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_nic301.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_pgmc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_pgmc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_pmu.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_pmu.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_romapi.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_romapi.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_soc_mipi_csi2rx.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_soc_mipi_csi2rx.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_soc_src.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_soc_src.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/fsl_device_registers.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/gcc/startup_MIMXRT1166_cm4.S
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/gcc/startup_MIMXRT1166_cm7.S
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/system_MIMXRT1166_cm4.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/system_MIMXRT1166_cm4.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/system_MIMXRT1166_cm7.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/system_MIMXRT1166_cm7.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/xip/fsl_flexspi_nor_boot.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/xip/fsl_flexspi_nor_boot.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/acmp/fsl_acmp.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/acmp/fsl_acmp.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/adc_12b1msps_sar/fsl_adc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/adc_12b1msps_sar/fsl_adc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/adc_etc/fsl_adc_etc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/adc_etc/fsl_adc_etc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/aoi/fsl_aoi.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/aoi/fsl_aoi.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/asrc/fsl_asrc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/asrc/fsl_asrc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/asrc/fsl_asrc_edma.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/asrc/fsl_asrc_edma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/bee/fsl_bee.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/bee/fsl_bee.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/cache/armv7-m7/fsl_cache.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/cache/armv7-m7/fsl_cache.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/cdog/fsl_cdog.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/cdog/fsl_cdog.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/cmp/fsl_cmp.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/cmp/fsl_cmp.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/common/fsl_common.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/common/fsl_common.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/common/fsl_common_arm.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/common/fsl_common_arm.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/common/fsl_common_dsp.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/csi/fsl_csi.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/csi/fsl_csi.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/dac12/fsl_dac12.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/dac12/fsl_dac12.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/dcdc_1/fsl_dcdc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/dcdc_1/fsl_dcdc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/dcic/fsl_dcic.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/dcic/fsl_dcic.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/dcp/fsl_dcp.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/dcp/fsl_dcp.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/dmamux/fsl_dmamux.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/dmamux/fsl_dmamux.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/edma/fsl_edma.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/edma/fsl_edma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/elcdif/fsl_elcdif.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/elcdif/fsl_elcdif.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/enc/fsl_enc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/enc/fsl_enc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/enet/fsl_enet.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/enet/fsl_enet.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/ewm/fsl_ewm.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/ewm/fsl_ewm.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexcan/fsl_flexcan.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexcan/fsl_flexcan.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexcan/fsl_flexcan_edma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_camera.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_camera_edma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_i2c_master.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_i2c_master.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_i2s.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_i2s.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_i2s_dma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_i2s_edma.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_i2s_edma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_mculcd.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_mculcd_edma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_mculcd_smartdma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_spi.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_spi.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_spi_dma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_spi_edma.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_spi_edma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_uart.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_uart.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_uart_dma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_uart_edma.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexio/fsl_flexio_uart_edma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexram/fsl_flexram.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexram/fsl_flexram.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexspi/fsl_flexspi.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexspi/fsl_flexspi.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexspi/fsl_flexspi_dma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexspi/fsl_flexspi_edma.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/flexspi/fsl_flexspi_edma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/gpc_1/fsl_gpc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/gpc_1/fsl_gpc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/gpt/fsl_gpt.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/gpt/fsl_gpt.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/iee/fsl_iee.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/iee/fsl_iee.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/iee_apc/fsl_iee_apc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/iee_apc/fsl_iee_apc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/igpio/fsl_gpio.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/igpio/fsl_gpio.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/key_manager/fsl_key_manager.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/key_manager/fsl_key_manager.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/kpp/fsl_kpp.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/kpp/fsl_kpp.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/lcdifv2/fsl_lcdifv2.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/lcdifv2/fsl_lcdifv2.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/lpadc/fsl_lpadc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/lpadc/fsl_lpadc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/lpi2c/fsl_lpi2c.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/lpi2c/fsl_lpi2c.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/lpi2c/fsl_lpi2c_edma.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/lpi2c/fsl_lpi2c_edma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/lpi2c/fsl_lpi2c_freertos.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/lpspi/fsl_lpspi.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/lpspi/fsl_lpspi.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/lpspi/fsl_lpspi_edma.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/lpspi/fsl_lpspi_edma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/lpspi/fsl_lpspi_freertos.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/lpuart/fsl_lpuart.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/lpuart/fsl_lpuart.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/lpuart/fsl_lpuart_dma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/lpuart/fsl_lpuart_edma.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/lpuart/fsl_lpuart_edma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/lpuart/fsl_lpuart_freertos.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/mecc/fsl_mecc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/mecc/fsl_mecc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/mipi_csi2rx/fsl_mipi_csi2rx.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/mipi_csi2rx/fsl_mipi_csi2rx.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/mipi_dsi_split/fsl_mipi_dsi.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/mipi_dsi_split/fsl_mipi_dsi.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/mu/fsl_mu.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/mu/fsl_mu.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/ocotp/fsl_ocotp.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/ocotp/fsl_ocotp.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/pdm/fsl_pdm.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/pdm/fsl_pdm.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/pdm/fsl_pdm_edma.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/pdm/fsl_pdm_edma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/pdm/fsl_pdm_sdma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/pit/fsl_pit.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/pit/fsl_pit.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/puf/fsl_puf.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/puf/fsl_puf.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/pwm/fsl_pwm.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/pwm/fsl_pwm.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/pxp/fsl_pxp.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/pxp/fsl_pxp.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/qtmr_1/fsl_qtmr.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/qtmr_1/fsl_qtmr.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/rdc/fsl_rdc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/rdc/fsl_rdc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/rdc_sema42/fsl_rdc_sema42.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/rdc_sema42/fsl_rdc_sema42.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/rtwdog/fsl_rtwdog.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/rtwdog/fsl_rtwdog.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/sai/fsl_sai.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/sai/fsl_sai.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/sai/fsl_sai_edma.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/sai/fsl_sai_edma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/sai/fsl_sai_sdma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/sema4/fsl_sema4.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/sema4/fsl_sema4.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/semc/fsl_semc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/semc/fsl_semc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/smartcard/fsl_smartcard.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/smartcard/fsl_smartcard_emvsim.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/smartcard/fsl_smartcard_emvsim.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/smartcard/fsl_smartcard_phy.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/smartcard/fsl_smartcard_phy_emvsim.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/snvs_hp/fsl_snvs_hp.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/snvs_hp/fsl_snvs_hp.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/snvs_lp/fsl_snvs_lp.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/snvs_lp/fsl_snvs_lp.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/spdif/fsl_spdif.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/spdif/fsl_spdif.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/spdif/fsl_spdif_edma.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/spdif/fsl_spdif_edma.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/src/fsl_src.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/src/fsl_src.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/ssarc/fsl_ssarc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/ssarc/fsl_ssarc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/tempmon/fsl_tempmon.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/tempmon/fsl_tempmon.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/tempsensor/fsl_tempsensor.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/tempsensor/fsl_tempsensor.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/trng/fsl_trng.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/trng/fsl_trng.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/usdhc/fsl_usdhc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/usdhc/fsl_usdhc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/wdog01/fsl_wdog.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/wdog01/fsl_wdog.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/xbara/fsl_xbara.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/xbara/fsl_xbara.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/xbarb/fsl_xbarb.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/xbarb/fsl_xbarb.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/xecc/fsl_xecc.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/xecc/fsl_xecc.h
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/xrdc2/fsl_xrdc2.c
 create mode 100644 bsps/arm/imxrt/mcux-sdk/drivers/xrdc2/fsl_xrdc2.h
 create mode 100644 spec/build/bsps/arm/imxrt/obj-mimxrt1052.yml
 create mode 100644 spec/build/bsps/arm/imxrt/obj-mimxrt1166-cm4.yml
 create mode 100644 spec/build/bsps/arm/imxrt/obj-mimxrt1166-cm7.yml
