GSoC Contributor Introduction: Integrating Renode to RTEMS
Joel Sherrill
joel at rtems.org
Fri May 12 16:46:37 UTC 2023
On Fri, May 12, 2023 at 7:46 AM Muhammad Sulthan Mazaya <
msulthanmazaya at gmail.com> wrote:
> Thanks for the feedback Joel,
> This is known to work. I think Alan Cudmore has reproduced this and there
>> is some information on the web about this:
>> https://antmicro.com/blog/2021/09/leon3-support-in-renode/
>> I don't think you will be adding code to renode. I hope you will submit
>> documentattion to them on running RTEMS on renode. I also expect additions
>> to the RTEMS documentation on running each BSP you succeed with on renode
> My mistake, the first point is kind of poorly written. The main work of
> the first point is to document how to use the virtual network switch from
> Renode as the Renode documentation is not that complete when it comes to
> setting up the virtual switch and connecting it to a virtual network
> interface on the Linux host. The documentation also should include other
> Renode feature that is essential for RTEMS user such as the gdb for
> debugging.
Yep. For each BSP that can run on renode.io, being able to use it with
rtems-test, debug using it, and (if applicable) use networking is needed.
And document what's needed in the RTEMS Users Guide.
It would be good for it also to be in the renode.io documentation. That's
also helpful and, although it may sound crass, it is as close to
"marketing" as we ever get. Someone looking for RTEMS and some board may
find that it is supported on renode.io. Plus knowing how to use the
configuration is obviously good.
> I would hope that you are able to run multiple BSPs on renode. That's one
>> of the goals of this project in my mind. How many BSPs can you run on
>> renode?
>> STM32 is one which looks like it is well supported and we don't have
>> another simulator option.
>> https://interrupt.memfault.com/blog/intro-to-renode
> Currently, I am capable of running leon3 and kendrytek210 on Renode thanks
> to Alan. There are several lists I have for possible compatible BSPs that
> could run on renode that I will try to document this summer. I will also
> take a look at the possibility of running STM32 on Renode.
That should work and Alan will certainly be helpful.
> You want to use the rtems-test framework to run renode from the command
>> line. This should be an early goal. It should not be particularly hard. If
>> you can run it from the command line without a GUI, then it should be easy.
>> We can model this support after qemu or sis.
>> Now what they have for a framework is another matter. It would be nice to
>> exercise more of the BSPs supported but testing more BSPs using renode.io is
>> the first order. Make that easy for everyone.
> Agreed, I guess this will be the most useful thing to achieve this summer.
> I will try my best to make sure this is implemented.
> Again, thanks for the feedback.
There are a lot of details given the variety of BSPs but hopefully between
the leon3 and kendrytek210, you can see the patterns for support. May be
helpful to do both in parallel so commonality stands out.
--joel
> - Mazaya
> On Wed, May 10, 2023 at 8:45 PM Joel Sherrill <joel at rtems.org> wrote:
>> First, congratulations on being accepted. This project was my idea
>> initially so I hope it is as fruitful to the community as I hope.
>> Second, use the devel@ mailing list since that is where most of the
>> developers are.
>> Other comments inline.
>> On Wed, May 10, 2023 at 4:06 AM Muhammad Sulthan Mazaya <
>>> Hi everyone,
>>> My name is Mazaya, I am one of the Google Summer of Code
>>> contributors for this summer. I will be working on integrating the
>>> renode.io simulator into RTEMS. Renode (http://renode.io/) is an open
>>> source software development framework with commercial support from Antmicro
>>> that lets you develop, debug and test multi-node device systems for System
>>> on Chips (SoC) and Internet of Things (IoT) devices. To learn more about my
>>> project, you can go to the RTEMS wiki where you can access my proposal (
>>> https://devel.rtems.org/wiki/GSoC/2023) or you can see it from the GSoC
>>> website (
>>> https://summerofcode.withgoogle.com/programs/2023/projects/bQeiZzHB).
>>> I hope to accomplish the following things this summer:
>>> 1. document running RTEMS/leon3 on renode (including networking and
>>> debugging)
>> to the RTEMS documentation on running each BSP you succeed with on renode.
>>> 2. provide at least a basic resc script for other RTEMS bsps that can
>>> run on renode
>> renode?
>>> 3. provide a build and install recipe for Renode in the RTEMS source
>>> builder
>> Yep. Although this can evolve over the project. Focus on using it first.
>>> 4. potentially figure out how to run the RTEMS test suite on the
>>> renode-test framework
>> is the first order. Make that easy for everyone.
>>> I will document the contribution in the RTEMS wiki (
>>> https://devel.rtems.org/wiki/GSoC/2023/add-support-for-renode-simulator)
>>> and my personal website blog (https://www.mazaya.id/blogs?tag=GSoC). I
>>> am truly looking forward to contributing to the RTEMS community. Hopefully,
>>> the things that I eventually achieve this summer will be useful for the
>>> community.
>> :) I'm looking forward to this.
>> --joel
>>> users mailing list
>>> users at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230512/e49bec61/attachment-0001.htm>
