[PATCH rtems 00/12] bsp/imxrt: Update SDK and prepare for new variant
Mon May 15 03:18:30 UTC 2023
On 6/5/2023 2:02 am, Gedare Bloom wrote:
> On Fri, May 5, 2023 at 9:02 AM <oss at c-mauderer.de> wrote:
>> Hello Gedare,
>> thanks for taking a look at the patch set.
>> Am 05.05.23 um 15:56 schrieb Gedare Bloom:
>>> On Thu, May 4, 2023 at 9:01 AM Christian Mauderer
>>> <christian.mauderer at embedded-brains.de> wrote:
>>>> Hello,
>>>> this patch set for the arm/imxrt BSP family updates the SDK files to the
>>>> latest version of the mcux-sdk from NXP and prepares the BSP for further
>>>> chip variants. I plan to add a BSP that uses the IMXRT1166 soon.
>>>> As a base for the mcux-sdk files, I now use the NXP git repository
>>>> instead of zip files that can be downloaded from NXP. I kept the exact
>>>> file system structure to make future updates simpler.
>>>> To import the files, I used a script. It is not a clean script and it
>>>> was only tested on a Linux machine. Despite that, I added that script to
>>>> the BSP directory in case someone else ever wants to update the
>>>> mcux-sdk. Updating the SDK is also possible without the script. It's
>>>> just a lot more manual work. So if we don't want a script in that state
>>>> in the repository, I can also just keep it on a private branch.
>>> I would recommend that you document the import/update process for the
>>> SDK in this BSP (or family) documentation. You could provide a stable
>>> external link to the script there instead of including it in the
>>> rtems.git tree. I'm not convinced that including scripts etc in the
>>> same tree as the source they manipulate is a great practice. It seems
>>> to violate separation of concerns.
>> Disadvantage is that the script (and documentation) is a bit less simple
>> to find. But that's not a problem for me (I know where to search) so I
>> will adapt that.
>> De we have an official preferred stable location? Otherwise, I think
>> either a small repo in my https://git.rtems.org/christianm or a repo on
>> github should be a good place (most likely the later one).
> This should be fine. ftp.rtems.org should also be usable (in theory)
>>>> The patches that import the new SDK files (patch 0002) and remove the
>>>> old ones (patch 0004) are too big for the list. I'll only send the
>>>> summary. You can find the full patches here:
>>>>    0002: https://gitlab.com/c-mauderer/rtems/-/commit/2a871672767a95598e5af42373bfebd3eb9440d3
>>>>    0004: https://gitlab.com/c-mauderer/rtems/-/commit/2a3e104fa808d7f34a1930344d7b39d11cf39f3d
>>>> The complete patch set is on this branch:
>>>>    https://gitlab.com/c-mauderer/rtems/-/commits/cm/20230504_imxrt/
>>>> At the moment, I import the support files for all currently available
>>>> i.MXRT* variants. The headers for the CPU registers are really big (a
>>>> few megabytes per header) which makes the complete source tree of the
>>>> mcux-sdk bigger than 90MB. If preferred, I can remove most variants and
>>>> only keep the ones that are currently used or will be used soon
>>>> (IMXRT1052 and IMXRT1166) to reduce the size.
>>> Thanks, I think this is fine. The increase in the number of HAL/SDK
>>> that we have to import is starting to concern me in general. I wonder
>>> if there is a better way to manage these external sources.
>> I think I have a language problem here: Is it fine that I push 96MB or
>> is it fine that I reduce the size of the patch before pushing?
> My apologies, I missed this also. If it's not that much more work, it
> might be best to remove the unused variants. We don't like to carry
> around dead code in the repo as another general rule.
>> In this case I only updated the existing HAL with more chips, but I
>> agree that having a better solution to manage HALs than the
>> clone-and-own approach would be great.
>> One possible solutions could be to use subrepos. We can clone the lib to
>> the git.rtems.org, add necessary patches and add that as a subrepo. If
>> an update is necessary, patches can just be rebased on the latest
>> version of the upstream lib. Another one could be something like the
>> west tool that is used in Zephyr. Maybe can also make it simpler to
>> include libs with vendor specific licenses.
>> But approaches like that will have a big impact on how to handle a lot
>> of tasks in RTEMS. For example you would have to init submodules before
>> building BSPs. The submodules have to be handled during release. And a
>> lot more. So we shouldn't discuss that as a side note to a patch set but
>> rather as a new mail thread.
> Agreed.
Do these HAL systems provide stable API interfaces? If so is all RTEMS needs to
interface to is the API headers?
