Static analysis
Sam Price
thesamprice at gmail.com
Tue May 16 01:31:08 UTC 2023
Thanks Alex,
I was able to run cppcheck.
I had to install the newest cppcheck from source to get access to the
--project flag.
i ran
bear ./waf
and then
cppcheck --project=compile_commands.json
It returned a few static analysis errors if interested.
I'll attach the results when it finishes running.
It is possible I don't have this configured properly, and its using
its own #defines
On Mon, May 15, 2023 at 11:03 AM Alex White <alex.white at oarcorp.com> wrote:
> You should be able to use `bear` (https://github.com/rizsotto/Bear). I have it installed via my package manager.
> After a `./waf clean`, run `bear -- ./waf` to generate compile_commands.json. Then you should be able to run `cppcheck --project=compile_commands.json`.
> Alex
Sincerely,
Sam Price
