Flash device - Fwd: New Defects reported by Coverity Scan for RTEMS
Joel Sherrill
joel at rtems.org
Tue May 16 11:41:57 UTC 2023
At least one of them is clear how to fix.
---------- Forwarded message ---------
Date: Tue, May 16, 2023, 12:57 AM
Subject: New Defects reported by Coverity Scan for RTEMS
To: <build at rtems.org>
Hi,
Please find the latest report on new defect(s) introduced to RTEMS found
with Coverity Scan.
2 new defect(s) introduced to RTEMS found with Coverity Scan.
New defect(s) Reported-by: Coverity Scan
Showing 2 of 2 defect(s)
** CID 1530126: Resource leaks (RESOURCE_LEAK)
/cpukit/libmisc/shell/main_flashdev.c: 184 in flashdev_shell_read()
________________________________________________________________________________________________________
*** CID 1530126: Resource leaks (RESOURCE_LEAK)
178 }
179
180 /* Create a buffer to read into */
181 buffer = calloc((bytes + bytes%4), 1);
182 if (buffer == NULL) {
183 printf("Failed to allocate read buffer\n");
>>> Handle variable "fd" going out of scope leaks the handle.
184 return -1;
185 }
186
187 /* Read into buffer */
188 status = read(fd, buffer, bytes);
189 if (status == -1) {
** CID 1530125: (FORWARD_NULL)
*** CID 1530125: (FORWARD_NULL)
/cpukit/libmisc/shell/main_flashdev.c: 105 in rtems_flashdev_shell_main()
99 return flashdev_shell_page_off(dev_path, argc, &argv[i]);
100 case ('i'):
101 /* Page info by index */
102 return flashdev_shell_page_idx(dev_path, argc, &argv[i]);
103 case ('p'):
104 /* Page count */
>>> Passing null pointer "dev_path" to "flashdev_shell_pg_count", which
dereferences it.
105 return flashdev_shell_pg_count(dev_path);
106 case ('b'):
107 /* Write block size */
108 return flashdev_shell_wb_size(dev_path);
109 case ('h'):
110 default:
/cpukit/libmisc/shell/main_flashdev.c: 96 in rtems_flashdev_shell_main()
90 return flashdev_shell_erase(dev_path, argc, &argv[i]);
91 case ('t'):
92 /* Flash Type */
93 return flashdev_shell_type(dev_path);
94 case ('d'):
95 /* JEDEC Id */
>>> Passing null pointer "dev_path" to "flashdev_shell_jedecid", which
dereferences it.
96 return flashdev_shell_jedecid(dev_path);
97 case ('o'):
98 /* Page info by offset */
100 case ('i'):
/cpukit/libmisc/shell/main_flashdev.c: 108 in rtems_flashdev_shell_main()
103 case ('p'):
106 case ('b'):
>>> Passing null pointer "dev_path" to "flashdev_shell_wb_size", which
dereferences it.
109 case ('h'):
110 default:
111 /* Help */
112 printf(rtems_flashdev_shell_usage);
113 break;
/cpukit/libmisc/shell/main_flashdev.c: 93 in rtems_flashdev_shell_main()
87 return flashdev_shell_write(dev_path, argc, &argv[i]);
88 case ('e'):
89 /* Erase */
91 case ('t'):
92 /* Flash Type */
>>> Passing null pointer "dev_path" to "flashdev_shell_type", which
dereferences it.
94 case ('d'):
95 /* JEDEC Id */
97 case ('o'):
To view the defects in Coverity Scan visit,
https://u15810271.ct.sendgrid.net/ls/click?upn=HRESupC-2F2Czv4BOaCWWCy7my0P0qcxCbhZ31OYv50ypUUzi-2FdSNmuyRB7BEFT8xQ4-2B8hpujh0hTgQljRGId4Dg-3D-3DXEx5_EU3W9teASMK00lBXX9WT4lsogDrkCcNZLvg-2FVxwAXMpqJ0-2Bfnv2-2FSXUlg52TUkS4uxSk3QPG8iWcXRzrk-2B9RKzEXdImy7vPVPfobCitkPqycfORs5dqm5DRNtKzDWMe2v8pZfERgB4abKyzpcD14thNAda8IeCRimcHZTHa1TrkAIwnda90httchtDZlqlkvbTydvDbLO0dR2nGlQejj4Q-3D-3D
build mailing list
build at rtems.org
http://lists.rtems.org/mailman/listinfo/build
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230516/121d64b2/attachment.htm>
