[PATCH v1] bsps/aarch64: Fix 128bit q register print bug
Kinsey Moore
kinsey.moore at oarcorp.com
Tue May 16 12:32:29 UTC 2023
This change looks good. Thanks!
On Mon, May 15, 2023 at 10:32 PM <tianye at sugon.com> wrote:
> From: Tian Ye <tianye at sugon.com>
> cpukit/score/cpu/aarch64/aarch64-exception-frame-print.c | 2 +-
> 1 file changed, 1 insertion(+), 1 deletion(-)
> diff --git a/cpukit/score/cpu/aarch64/aarch64-exception-frame-print.c
> b/cpukit/score/cpu/aarch64/aarch64-exception-frame-print.c
> index e207a5a81d..c5b477c72f 100644
> --- a/cpukit/score/cpu/aarch64/aarch64-exception-frame-print.c
> +++ b/cpukit/score/cpu/aarch64/aarch64-exception-frame-print.c
> @@ -216,7 +216,7 @@ void _CPU_Exception_frame_print( const
> CPU_Exception_frame *frame )
> for ( i = 0 ; i < 32 ; ++i ) {
> uint64_t low = (uint64_t) qx[i];
> - uint64_t high = (uint64_t) (qx[i] >> 32);
> + uint64_t high = (uint64_t) (qx[i] >> 64);
> printk( "Q%02i = 0x%016" PRIx64 "%016" PRIx64 "\n", i, high, low );
> 2.27.0
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230516/cb439663/attachment.htm>
